I purchased this 2005 STi from a car dealer in Cartersville, GA, just northwest of Atlanta. It had 105,000 miles. I was looking specifically for a car in excellent Shape cosmetically, mostly stock look, inside and out. I had a local shop inspect the car for any major issues. It seemed to pass general inspection, no accidents, nothing major was obvious.
I have made changes and improved almost every aspect of the cars performance. Below are the details.
Items in Black were installed when I purchased the vehicle
Items In GREEN are improvements I made
2005 SUBARU WRX STi FULLY MODIFIED, Tuned By Pure Tuning, Toledo, Ohio
366 WHP, 368 WTQ, Mustang Dyno, 93 Octane, @ 21 psi Boost, Feb 2014 (Blouch 18g XTR)
Current Weight: 3240 lbs
Engine
New Pure Tuning Custom Short Block assembly (April, 2013)
Spec A+ Cylinder heads
SuperTech valves (NI-In / Inconel-Ex)
OE Valve Bucket / shims
SuperTech Dual Valve Spring kit
JE forged Pistons, 99.5 mm bore, 8.5 : 1 compression ratio (April 2013)
CALICO Piston coatings Calico Coatings | CT-2
Manley H beam connecting rods Honed and Balanced, (June 1013)
New OE Crankshaft, Induction hardened, High speed balance and Omni Polish
ACL coated race bearings Calico Coatings | Bearings
Cosworth Head gaskets .78mm
GSC Stage 2 cams
Blouch 18g XTR w/ Dart DC2 Heat reflective Coating on the hot side (April 2013) DC2 Reflective Heat Barrier - Coatings - Services
Tomi Turbo Inlet Hose (August 2013)
Cobb tuning access port
Grimmspeed Electronic Boost Control Solenoid
Power Enterprises 850cc side feed Fuel injectors
Walbro GSS342 255 LPH Fuel Pump
[URL="http://perrinperformance.com/i-13324045-front-mount-intercooler-for-2002-07-wrx-sti.html"]Perrin Front Mount Intercooler
[/URL]Crawford Air/Oil Separator
Moroso 5 Qt Oil Pan
Moroso Oil Pickup (Updated Moroso Oil Pickup 24965 March 2013)
[URL="http://www.hks-power.co.jp/usa/products/Pid=2937.html"]HKS timing belt 24999-AF001
[/URL]Forge Motorsports recirculating race blow off valve
Perrin coolent overflow tank ( Feb 2014)
Suspension
STi Front and rear strut tower braces,
Hotchkis front sway bar, 25.4 mm Hollow (+50% increased stiffness over Stock)
Hotchkis adjustable rear sway bar, 25.4 mm Hollow. ( +50, +90%, 160% over stock)
Racecomp Tarmac II, 450/350 springs ( April 2014)
Group N front strut mounts (May 2014)
Group N rear Strut mounts (April 2014)
Whiteline Spherical Front and rear sway bar end links (April 2014)
Whiteline Anti Lift Kit (April 2014)
Stock rear lateral Links With TiC Polyurethane, teflon infused Bushings (April 2014)
Stock Rear Trailing Arms With TiC Polyurethane, teflon infused Bushings (April 2014)
Turn-in-Concepts fender cowel braces (Jan 2012)
New OEM Front lower ball joints (June 2014)
Brakes
Goodridge stainless brake lines
DBA 4000 slotted brake rotors Front
New Set of DBA 4000's March 2015
Brembo Stock rear Rotors
Carbotech XP8 brake pads front and rear ( Sept 2012)
Carbotech Bobcat 1521 for daily use and autocross, front only (March 2014) (Added Rears March 2015)
Girodisc Front Titanium Pad Shields (Installed May 2014)
OEM Brembo Calipers
Brake Duct Kit with Fog light entry and RooDuct transitions (Installed May 2012)
Quantum Motorsports Brake duct plates (Installed May 2012)
Grimmspeed Master Cylinder Brace (Insalled August 2012)
Racing Brake Stainless Steel caliper Pistons. (Installed March 2015)
Drive Train
ACT Clutch kit, Sprung 6 Puck Disc
TWM Short shifter w/ front and rear Stay Bushings ( installed Feb 2012)
TiC 6MT Pivot Bushings and Shift Linkage Bushings (installed Feb 2012)
Perrin Subframe Differential Lockdown Kit ( installed Feb 2012)
TiC Rear Differential Mount Bushings ( installed Feb 2012)
Rear subframe Outrigger Bushings. ( installed Feb 2012)
Subaru Group N Engine Mount Bushings (installed Sept 2014)
Subaru Group N Transmission Mount Bushing (installed March 2015)
Perrin Pitch Stop (installed Dec 2014)
TiC Tranny Cross member Bushings (installed March 2015)
Whiteline Steering rack bushings ( installed August 2013)
Right front axle, replaced February 2012
Left front axle replaced December 2014
Interior
Stock Radio
Dual gauge instrument cluster bezel ( installed Feb 2012)
PROSPORT Boost and oil temp gauges ( installed Feb 2012)
RED LED conversion, Window buttons, Radio, HVAC, Clock, Ignition ring, Cigatette ( installed Nov 2012)
Exterior
De-Badged
STi V-limited style Front Bumper lip spoiler ( installed June 2012)
Perrin Rear Wing Stablizer (2) ( installed Dec 2011)
KSTech Hood vent (Scoop delete) (installed Dec 2011)
Enkei Tuning Series SC03 17x8 Silver rims Dunlop DZ101 245/40/17 for Street use
[URL="http://enkei.com/shop/racing/rpf1/"]Enkei Racing RPF1 Silver 17 x 8.5 x 114[/URL] Nitto NT05 235/40/17 for the track (acquired May 2012)
Exhaust
Tomei EL Header and Up Pipe w/ Dart DC2 Heat reflective Coating (installed April 2013)
[URL="http://www.mann-engineering.com/index.php/exhaust/exhaust/sti-2004-2007-milltek-sport-hi-power-turboback-exhaust-13457.html"][URL="https://www.mann-engineering.com/index.php/sti-2004-2007-milltek-sport-hi-power-turboback-exhaust-13460.html"]Milltek Sport High Power turbo back exhaust[/URL][/URL] ( installed Feb 2012)
· Full 3” stainless piping
· Resonated down pipe
· Resonated mid pipe w/ hi flow HJS catalytic converter
· Polished Stainless steel muffler
Engine
GSC Stage 2 cams
Moroso 5 Qt Oil Pan
Suspension
Brakes
OEM Brembo Calipers
Drive Train
Interior
Stock Radio
Exterior
De-Badged
Exhaust
