The Phoenix Mod List
--> Installed
--> Temporarily Installed
--> Near Future
--> Ordered
--> On-Hand / Not Installed
--> Debating
Engine:
- 701 Short-Block Castings ( Semi-Closed )
- Dan Benson Signature Series Sleeves / 3rd Generation ( Dry Ductile Iron )
- Cosworth 81mm - Stroker EN40B Cross-Drilled Billet Crankshaft / 18.25 lbs / 20002316
- Lachute Performance LightWeight Aluminum Pulley
- RCM / Arrow Precision M2000 H-Beam Connecting Rods ( Stock Length = 130.43 mm ) ( 543g Per w/Bolts ) / RCM2043
- ARP Custom Age 625 Plus Rod Bolts / ARP 300-6703
- Cosworth CosAl 010 Forged Alloy Piston & Ring Kit - Stroker (2.6L) - 99.5mm Bore - 9.2:1 Compression Ratio / 20004534
- King Racing P-Max Black XPG Race Series Rod Bearings
- King Racing P-Max Black XPG Race Series Main Bearings
- RCM WRC 14mm Head Stud Kit / RCMS593
- RCM 14mm WRC Head Dowels / RCMS658
- ARP Engine Case Bolts / ARP-260-5401
- Cosworth Head Gaskets
- OEM Subaru Gasket Kit
- Lachute Performance AK3 Serial Number ( Custom )
- Lachute Performance CNC 14mm Head Stud Conversion Upgrade
- Balanced & Blue-Print Assembly
- Subaru W25 Heads ( HeadGames MotorWorks Fully Prepped And Assembled )
- OEM Size Intake And Exhaust Ports
- Ferrea Racing Components / Competition Plus Intake And Exhaust Valves
- GSC Power-Division beehive spring kit With Titanium Retainer
- GSC Power-Division S2 Camshafts [ Intake 272 / 230 @ .040" / Peak Lift 10.7MM / Centerline AVCS ] [ Exhaust 272 / 228 @ .040" / Peak Lift 10.4MM / Centerline AVCS ]
- Manley 6mm Hardened Heat-Treated Steel Valve Locks
- Multi Angle Valve Job
- CNC Machined Port Finish
- Knife Edge Port Divider
- Valve Lash Set
- Boomba Racing 75mm DBW Throttle Body - Bolt On / Black Anodize
- Specialty Fasteners & Components Ltd / 3" Hydraflow 14J21 Clamshell Flexible Coupling ( For I/M+T/B )
- Cosworth High Volume Intake Manifold / 20006438
- Cosworth Tumbler Delete Housings ( TGV ) / 20015678
- Cosworth Oil Filter Cap / COS1-20014380
- Cosworth Air Pump Delete Plates / COS1-20004539
- Cosworth Billet Timing Belt Guide / COS1-SB0001
- STi Timing Belt ( JDM Pinky ) / ST130284S000
Engine Treatments:
- Case Halves ( Exterior ): Thermal Displacement High Temp Black
- Pistons: ‘Xylan’ Anti-Scuff Skirt Coated + Crown CBX Powerkote
- Heads ( Exterior ): Thermal Displacement High Temp Black
- Heads: Surfaces Rendered "true" + " Anti-Casewalk Fine Scuffed
- Combustion Chambers: CBX Powerkote
- Port Intakes: CBX Powerkote
- Port Exhausts: CBX Powerkote
- Wrist Pins: CavidurN Treated
- Buckets: CavidurN Treated
- Camshafts: CavidurN Treated
- Valve Covers = Fine Textured Thermal Displacement High Temp Red
- Intake Manifold: CBX Coated inside/Out + Gloss White Powder Coated
Oil System:
- Killer B Motorsport Aluminum Racing Oil Pan
- Killer B Motorsport Oil Baffle Windage Tray
- Killer B Motorsport Ultimate Oil Pickup
- Killer B Motorsport Oil Temperature Sensor Adapter ( 1/2NPT To 1/8NPT )
- Subaru Turbo Oil Filter / SUB-15208AA12A
- Aeromotive Braided Stainless Steel Hoses
- Aeromotive Fittings ( Black )
- Lachute Performance Air/Oil Separator - Breather
- Lachute Performance Power Steering Reservoir
- Lachute Performance Turbo Coolant Expansion Tank
Drivetrain / Transmission:
- Kaps Short-Ratio Straight-Cut 5 Speed Dog-Box
- Exedy Stage 5 Cerametallic Multiplate Clutch Kit / FM023SB
- Lachute Performanc Stainless Steel Braided Clutch Line
- Tommi Mäkinen Racing Short Throw Shifter / 35010ZR010
- Whiteline Gearbox Positive Shift Bushing Kit / KDT901
- Cosworth Pitch Stop Mount / 20026100
- DriveShaft Shop Carbon Fiber Unit (12.2Lbs) / SUSH9-C
- Perrin High Capacity Differential Cover / PSPSUS51X
- Torque Solutions Motor Mounts / TS-SU-200
- Torque SolutionsTransmission Mount / TS-SU-300
Power Bolt-On:
- Lachute Performance 4.0" Cold Air Intake
- K&N Cone Filter / RE-0870
- Lachute Performance Twin Scroll E/L Header ( Swain Tech Coated White )
- Lachute Performance External WasteGated Rotated Turbo Up-Pipe ( Twin Scroll Layout --> 02 X Wastegate Plumbed Back Into Mid-Pipe )
- Lachute Performance 4" Rotated Cattless Downpipe ( Swain Tech Coated Black )
- Lachute Performance 3.5" Turboback Exhaust / No Resonator / MagnaFlow Mufflers ( Swain Tech Coated Black )
- Cart Boy Exhaust Hangers
- Air Conditioning Delete
Long Track / Dyno Queen ~ BorgWarner ( 79 lb/min ) EFR 8374 T4 EWG 1.05 A/R ( V-Band Out ) - 2000 Degree Coated
- Vibrant Performance 4" Aluminium Bellmouth Velocity Stack ( AKA: Trumpet )
Short Track / Street ~ Borg Warner ( 64 Lbs/Min ) EFR 7670 T4 EWG 1.05 A/R ( V-Band Out )
- Full-Race EFR Aluminum BOV Cover ( For Both EFR Turbos )
- BorgWarner EFR Turbo Speed Sensor Kit ( For Both EFR Turbos )
- PTP T3/T4 Turbo Blanket - Lava / PTP-FPRO35-011-04
- Tial 02 X MV-S 38mm Wastegate W/ Extreme High Temp Casting Option ( Red )
- Aeromotive Swivel Fittings ( Black )
- AMS FMIC Core ( Swain Tech Coated Black ) / 1250 CFM / 1 psi drop @ 800HP / 3.5" Thick / 23 Lbs
- AMS replacement 1.5”, 1018 steel crash bar
Fuel System:
- Cosworth Billet Top-Feed Fuel Rail Kit ( Return-less Set-Up ) / 20026741
- DeatschWerks DW300 (340LPH In-Tank Fuel Pump) / DW-301
- Injector Dynamics Fuel Injectors 1300cc / IND 1300.18.02.48.11.4
- Aquamist HFS-3 V2 Methanol - Water Injection Kit - Blue Gauge ( 9.70 lbs ) / AQU-806-083BL
- Aeromotive 10 Micron Filter ( Black ) / 12321
- Aeromotive A1000 Injected By-pass Regulator ( Black ) / 13101
- Aeromotive Y-Block Fuel Distributor ( Black )/ 15673
- Aeromotive ORB-10 To AN-08 Male Flare Reducer Fitting ( Qty: 04 ) / 15610
- Aeromotive ORB-10 To AN-06 Male Flare Reducer Fitting ( Qty: 01 ) / 15609
- Radium Engineering Universal Dual Bosch 044 Vertical Fuel Surge Tank / 20-0021
- Vibrant Performance Quick Disconnect AN Fittings
Ignition System:
- NGK Iridium Spark Plugs LFR7AIX
Electrical System:
- 2 AWG Power Wired Front / Back
- 4 AWG Power Wire ( Alternator / Starter / Fuse-Box )
- Braker
- Front Distribution Block
- Rear Distribution Block
- CTEK MUS 4.3 Test & Charge / 56-864
- CTEK Comfort Connect M6 / 56-260
- CTEK Rubber Bumper Case / 56-915
- OEM Alternator ( Relocated - A/C Delete )
- Odyssey Lightweight Battery With Terminals / 15lbs / ODY PC680T
- Odyssey PC680 Aluminum Billet Battery Mount & Battery Tray
- Small Lightweight Racing Alternator
Coolant System:
- Cosworth 154 Degree Low Temperature Thermostat / COS1 20021032
- Moroso Radiator Recovery Billet Tank / 85505
- Lachute Performance Radiator Shroud ( Black )
- KoyoRad Aluminum Racing Radiator / KOY A13093
- KoyoRad Hyper Rad Cap / KOY SK-C13
- Lachute Performance Upper Radiator Aluminum Tube
- Samco Lower Radiator Silicone Hose ( Black ) / SAM TCS272C-BLK
- Torque Solution Radiator Mounts ( Black ) / TS-SU-205B
- Vibrant 4ply Radiator Upper Tube Couplers ( Blue )
- Vibrant Stainless T-Bolt Clamps ( 2 X 2 On Upper Couplers / 2 X 2 On Lower Samco Hose )
- Ron Davis Drop-In 2 Row / 1" Wide Per/Tube Radiator W/ 7 Row A/W Engine Oil Cooler
Steering / Directional System:
- GTSPEC D-Shaped Steering Wheel ( Carbon Fiber / Red Trim ) / GTS-MIS-1430C
- Cusco Power Crossmember Brace / CUS 692 492 M
- Cusco Power Steering Rack Brace / CUS-692-026-ALHD
- Subaru 2015 STI 13:1 Steering Rack / 34110VA120
- Perrin Anti-Lift Kit P.S.R.S 3.00" Offset / PSP-SUS-415
- PowerFlex ( Black Series ) Steering Rack Mounting Kit / PFF69-504BLK
- GTSPEC Roll Center/Bump Steer kit – Ball-Joints & Tie Rod Ends / GTS-SUS-1409
- CEV Electrical Power Steering Kit / 1.7 Gallon-Min ( Relocated / 70% Hose Delete )
Fluids:
- Engine =.......…........Gulf Racing 10W60
- Gear = ...................Gulf Competition LSD 75W140
- Differential = ...........Gulf Competition LSD 75W140
- Brake = ..................Gulf DOT 5.1
- Power Steering = .....Gulf Fluid Max
- Pump Gas = ............94 Octane
- Race Gas = .............ELF Perfo 105
- Methanol/Water % = 50/50
Tuning:
* MAHA LPS 3000 4wd Dynomometer *
- LINK Engine Management G4+ Xtreme
- Deutsch Hermetic Circular Connectors / HDP 20 Series (24-24-47PE-L017)
- MapDCCD - Motorsports Differential Control System
Vehicle Data Acquisition / Telemetry:
- AIM MXL-2 / Pista Dash Unit W/OBD2 Cable & Harness
- Aim SmartyCam HD GP
- AIM GPS 05 MODULE
- Lachute Carbon Fiber Cluster Plate With Custom Identification Stickers
- LED Status Lights Additionally Installed In Carbon Fiber Cluster Plate --> DCCD +/- * VCD/ABS * Cruise Control * Hi-Beams * Left/Right Turn Signal * Fuel Tank Reserve Indicator
- Water Temperature Read-Out
- Voltage Meter Read-Out
- Fuel Level Read-Out
- Oil Pressure Read-out / Additional Sensor
- Oil Temperature Read-out / Additional Sensor
- Fuel Pressure Read-out / Additional Sensor
- Exhaust Gas Temperature Read-Out / Additional Sensor
- Aquamist HFS3-v2 52mm Digital Gauge
- MB 52mm Single Gauge Cluster Pod ( For Aquamist Gauge )
- White LED Lights Installed Under Each Separate S-Drive Option To Newly Illustrate Which Is Currently In Use ( Intelligent / Sport / Sport # )
- Innovate Motorsports LC-2
Suspension ~ Bracings ~ Bushings:
- GTSPEC Front Strut Brace / GTS-SUS-1322
- GTSPEC Fender Reinforcement Braces / GTS-SUS-1344
- GTSPEC 4 Point Ladder Brace / GTS-SUS-1327
- GTSPEC 4 Point Mid Ladder Brace / GTS-SUS-1328
- GTSPEC Rear Strut Brace / GTS SUS-1335 ( 1450 Trunk Cage Kit )
- GTSPEC Trunk Reinforcement Brace / GTS SUS-1340 ( 1450 Trunk Cage Kit )
- GTSPEC Rear 4 Points Cross Linkage Brace / GTS SUS-1449 ( 1450 Trunk Cage Kit )
- GTSPEC Lightweight Rear Bumper Beam / GTS-SUS-1377
- GTSPEC Rear 4 Point Sub Frame Tie Brace / GTS-SUS-1329
- GTSPEC Rear Control Arm With Camber Adjustment ( Version 2 ) / GTS-SUS-1376
- GTSPEC Rear Adjustable Toe Arms / GTS-SUS-1407
- GTSPEC Rear A Brace ( Version 2 ) / GTS-SUS-1339
- GTSPEC Rear Trailing Arms / GTS-SUS-1408
- JRZ RS PRO Double Adjustable Club Sport Damper / Coilovers ( Top-Plates & Gas Canisters Upgraded To N14 Versions )
- PowerFlex Black Series Control Arm Brace Support
- PowerFlex Black Series Control Arm - Lower Inner Front Bushing
- PowerFlex Black Series Camber Correction Control Arm Upper Inner Bushing Kit
- PowerFlex Black Series Cross Member Mount Bushing Kit
- PowerFlex Black Series Diff - Mount In Cradle Insert Bushing Kit
- PowerFlex Black Series Diff – Mount Front Bushing kit
- PowerFlex Black Series Diff - Mount In Cradle Bushing Kit
- Whiteline Control Arm Support / KBR14
- Whiteline 22mm Adjustable Front Sway Bar / BSF39Z
- Whiteline 22mm Adjustable Rear Sway Bar / BSR49XZ
- AVO 55mm Front Adjustable End-Links / S2B03G1GU055J
- AVO Rear Adjustable End-Links / S2C07G1HU001J
Brakes / Hoses:
- GrimmSpeed Master Brake Cylinder Brace / GRM-091001
~ Front Brakes:
- AP Racing Pro 5000+ 6 Piston Calipers ( Red )
- DBA 5000 T3 2-Piece Slotted Rotors
- Ferodo DS2500 Brake Pads
- Goodridge Stainless Steel Break Lines
~ Rear Brakes:
AP Racing Pro 5000+ 4 Piston Calipers ( Red )
- DBA 4000 T3 1-Piece Slotted Rotors
- OEM Brake Pads
Wheels / Tires / Lugs:
~ #1: Show & Shine / Street:
- Volk Racing - Rays TE37SL 18" x 11.0" ( Pressed Graphite )
- Offset: +18
- Weight: 19.5 Lbs
- Volk Racing - Rays Valve Stem Caps ( Red )
- Toyo Proxes R888 295/30 ZR18 ( Racetrack & Autocross )
- Weight: 28.0 Lbs.
- Nitrogen Gas Filled ( 33psi Front / 32psi Rear )
- Project Kics R40 20 Piece M12 x 1.25 Composite Lug Nuts
~ #2: Track / Lapping:
- To Come
- Offset: To Come
- Weight: To Come
- Stem Caps: To Come
- To Come
- To Come
- To Come
- To Come
Safety:
- H3R Performance HG250C Clean Agent Fire Extinguisher Bottle ( Chrome )
- H3R Performance 250 Size Fire Extinguisher Band Clamp BB250P ( Polished )
- H3R Performance 1 5⁄8" Diameter Roll-Bar Mount BMR01P ( 5.1" Circumference ) ( Polished )
- H3R Performance Flat Surface mount Bracket BMF01P ( Polished )- Subaru All-Weather Floor Mats
- Recaro Profil XL Driver ( Lachute Performance LP Logo Stitched On )
- Recaro Profil XL Passanger ( Lachute Performance LP Logo Stitched On )
- Hans Device
- Full Cage
- 6 Point Harnesses ( Driver & Passenger )
- On-Board Extinguisher System
Track Gear:
- Race Ramps 3" Trak-Jax ( Qty: 04 ) / RR-TJ
In Car Entertainment:
- OEM Audio System: Fully Deleted
Lighting:
ProLightz HeadLamp RetroFit Project
- 2012 / 2014 Crystal Head Lamp Units
- Lamin-X Yellow Overlay ( LeMans Style )
- Morimoto Mini D2S 3.0 Bi-Xenon Projectors
- Matsushita Gen IV Ballasts
- Osram D2S Xenarc Cool Blue HID Bulbs / 5000K
- Osram H3B/9005 Cool Hyper Blue Halogen Bulbs / 5000K
- ProLightz Chrome/Amber Turn Signal Bulbs
- Custom Hi-Beam Splitters
- JDM DEPO 2008/2014 Subaru Impreza 4DR Sedan Red / Clear LED Rear Tail Lights
- Premium Automotive Styling Tail Light Overlays ( Top Half OEM Red / Bottom Half 25% Smoke Combo )
- Reverse Light
- Licence Plate
- STi JDM Rear Fog Light Assembly ( Wired As Brake Light )
- Subaru Footwell Illumination Kit ( Blue )
- Dome Lights: ProLightz
- Map Lights: ProLightz
Interior:
- Lachute Performance LP Aluminium Shift Knob ( Black )
- Eikosha Air Spencer Giga Clip Marine Squash ( ASP 56403 )
- JPM Coachworks Pure Black Alcantara Red Stitch E-Break Boot
- JPM Coachworks Pure Black Alcantara Red Stitch Shifter Boot
- Prova SI-Drive Knob ( Black )
- Subaru Footwell Illumination Kit ( Red )
- USDM Armrest Extension
- Subaru Compass / Auto Dim Rear View Mirror
- JDM/SMY STI Push-Start Button With Keyless Entry / AK-105
- JPM Coachworks Pure Black Alcantara Red Stitch Cluster Hood
- JPM Coachworks Pure Black Alcantara Red Stitch Full Dash
- Vermont Sportscar M-Tech Carbon Fiber Door Panel
Exterior:
* Varis GV Wide-Body Kit Installed By Cove Custom Autowerks *
* B-WP Paint Acronym: Blossom-White Pearl *
- LP700R Custom Livery
- JOES Racing Product ( 12078 ) Aircraft Anodized Aluminum / Laser Etched 8" Spoiler Support Rods
- Varis GVB-F / GRB-F Carbon Weight Adapted Bonnet Damper Kit / Wet-Carbon ( Non-Painted )
- Varis GVB-F / GRB-F Cooling Bonnet ( Painted Under B-WP )
- Varis GVB-F Wide Body Hyper Double Canard Kit / Wet-Carbon ( Non-Painted )
- Varis GVB-F Wide Body Front Bumper / Wet-Carbon ( Painted B-WP )
- Varis GVB-F Wide Body Front Diffuser / VSDC ( Varis Semi-Dry Carbon ) ( Non-Painted )
- Varis GVB-F Wide Body Rear Fender Hitting Protecter Kit / ( FRP ) Fiberglass Reinforced Plastic ( Non-Painted )
- Varis GVB-F Wide Body Front Fender Kit / ( FRP ) Fiberglass Reinforced Plastic ( Painted B-WP )
- Varis GVB-F Wide Body Front Fender Under Lip Kit / Wet-Carbon ( Non-Painted )
- Varis GVB-F Wide Body Side Air Panel / Wet-Carbon ( Painted B-WP )
- Varis GVB-F Wide Body Big Under Board / Wet-Carbon ( Non-Painted )
- Varis GVB-F Wide Body Rear Fender Kit / ( FRP ) Fiberglass Reinforced Plastic ( Painted B-WP )
- Varis GVB-F Wide Body Side Splitter Fins / Wet-Carbon ( Non-Painted )
- Varis GVB-F Exhaust Heat Shields / Wet-Carbon ( Non-Painted )
- Varis GVB-F Rear Diffuser / Wet-Carbon ( Non-Painted )
- Varis GVB-F Trunk Hood With Extra Reinforcement Option For GT Wing / ( Wet-Carbon And Painted Under B-WP )
- Varis GVB-F Wide-Body Dual Hyper Canards ( Dry-Carbon )
- OEM GVB Rear Garnish ( Painted B-WP )
- OEM Chrome Door Trims + Full Door Contours Blacked-out ( Painted Satin Black )
- OEM Antenna Delete / Full Roof Restoration-Repair
- Aerocatch Hood Pins / Plus-Flush Non-Locking Kit / 120-2000 ( Matte Black / Inside Painted Red )
- Craft Square Generic Touring Competition TCA-F/W 1000R Mirrors ( Anti-Glare Blue )
- Cove Custom Autowerks OEM Custom Fabricated OEM Mirror Block-Off Plates ( Painted Satin Black )
- Hella Supertones ( Red ) With Subimods Bracket And Harness
- Project Kics License Plate Locks Bolt Kit
- HKS Kansai Front Tow Hook ( To Be Powder Coated TE37SL Red ) ( Function )
- HKS Kansai Rear Tow Hook ( To Be Powder Coated TE37SL Red ) ( Function )
- Beatrush Front Tow Hook Red Subaru STI 2008-2010 ( Red & Black ) ( Form )
- Beatrush Rear Tow Hook Red Subaru STI 2008-2010 ( Red & Black ) ( Form )
- Voltex Racing Type 5 1650mm GT-Wing / Wet-Carbon
- Volex Racing 1650mm Gurney Flap / Wet-Carbon
- Voltex Racing 275mm Bracket-Feet / Aluminum ( Matte Black )
- Voltex Racing GVB-F Specific Mounts / Aluminum ( Painted B-WP )
- LP Badge ( Front )
- LP Badge ( Rear )
- OEM Roof Blacked-Out ( Custom Vinyl Rap )
Weight Saving + Deletes:
- OEM Spare Tire Delete
- OEM Car Jack Delete
- OEM Car Tools Delete
- OEM Trunk Floor Support Delete
- OEM Rear Floor Matts Delete
- OEM Washer Fluid Reservoir
- OEM Air Conditioning Compressor Delete
- OEM Air Conditioning Core Delete
- OEM ELCM Canister
- OEM ELCM Module
- OEM Fuel Lines
- OEM Engine Bay Master Cylinder Brake Lines
- OEM Engine Air Pump Delete
- OEM Electrical Wiring *
Many*
- OEM Under Carriage Metal Shields Delete
- OEM Badge Delete
- Lighter Seats
- Lighter Battery ( 14.5 Lbs ) ( Relocated At Back )
- C/F Driveshaft ( 12.2 Lbs )
- Lighter Wheels ( 19.5 Lbs )
- Two-Piece Front Brake Rotors
- Carbon Fiber Bonnet
- Carbon Fiber / Kevlar Hood Trunk
- Carbon Fiber Mirrors
- Carbon Bonnet Dampers
- Fiberglass Reinforced Plastic Front Bumper
- Fiberglass Reinforced Plastic Front Fenders
- Dry Carbon GT3 Rear Wing
- Deleted Windshield Washer Tank
Photo / Video Gear:
- Custom Built Camera / Mic Rear Console Tri-Pod ( Painted SWP Ceramic coated )
- GoPro Hero2 ( Motorsport Edition )
- Wi-Fi BackPac + Wi-Fi Remote Combo Kit
- Ram Mount GoPro Mounting Base 1" Diameter Ball
- Ram Mount Double Socket Arm With 1" Diameter Ball / "B" Length
- Ram Mount U-Bolt Base With 1" Diameter Ball
- Optional iPhone 4S GoPro WiFi Remote ( GoPro App 1.0 Downloaded & Installed )
- Ram Mount Universal X-Grip Phone Holder With 1" Ball
- Ram Mount Double Socket Arm With 1" Diameter / "A" Lenght
- Ram Mount Diamond Mounting Base With 1" Diameter Ball
- Rode Stereo VideoMic Pro
- Rode Dead Kitten Windshield
- Ram Mount 1" Diameter Ball Base With 3/8"-16 STST Stud
- Ram Mount Double Socket Arm With 1" Diameter Ball / "A" Length
- Manfrotto 804RC2 3D Pan-Tilt Tripod Head With Quick Lock
- Manfrotto 055XPROB Professional Tripod
