Joey's mistress: nothing new here - Subaru Impreza WRX STI Forums: IWSTI.com
STI Forum
Join
Go Back   STI Forums > > > Joey's mistress: nothing new here
Old 05-15-10, 01:56 PM   #1
joey.lisano
Gold Member
Feedback Score: 18 reviews
Fav Mod: mod bug
My Subaru Parts for sale
joey.lisano is an unknown quantity at this point
Default Joey's mistress: nothing new here
Table of Contents
General stuff
Mod list
The beginning
Current problems
Tech Stuff
fluid dynamics pictures
good ol' thermostat testing
Bushings: Rubber vs. Polyurethane
Why the GD chassis needs an X-brace
Pictures
first photo shoot
winter setup
Videos
in car NVH while street driving
homemade air oil separators
how to remove headunit and install aftermarket headunit
Teaser pics
books, my favorite!
Koyo radiator, coated in Swaintech's BBE
ACPT driveshaft
Dunkin' Turbo injection, what?
Whiteline makeover
winter wheels
Other
maintenance log
things I wish I would have done differently
Special Thanks to
Geoff @ Cygnus Performance
Adam @ Litespeed Performance
T3h_Clap as himself
Got2Boostit2 @ The Shop
DIY painted headlights and Hella Tones
CYGNUS X license plate for Geoff at Cygnus Performance
engine bay, no longer up to date
winter setup: Enkei RPF1 17x8 +45mm with Bridgestone Blizzak REVO1 225/45/17
https://www.youtube.com/v/jiW1NwRmmaU
https://www.youtube.com/v/HOY_8SZfQQc
https://www.youtube.com/v/4GiVaIU9FB4
Thanks for looking.
Joey's mistress: nothing new here-dsc03089-jpg
joey.lisano is offline
Likes 0 Dislikes 0
Sponsored Links
Advertisement
Old 05-15-10, 01:56 PM   #2
joey.lisano
Gold Member
Fav Mod: mod bug
Default Re: Joey's pathetic grocery getter (editing, finally made one)
Mod list
Engine
Cobb APv2 with protune from Eric @ IPS Motorsports
Perrin cold air intake
stock turbo, turbo inlet, throttle body, intake manifold, TGV's, longblock
Litespeed UEL header; ceramic coated in Swain Tech's White Lightning
IAG up pipe and dump tube for 38mm EWG; ceramic coated in Swain Tech's White Lightning
TiAL MV-S 38mm EWG, 1.3 bar spring, black tophat;
ERZ (CNT) bellmouth, catted downpipe; ceramic coated in Swain Tech's White Lightning
SRS catback; ceramic coated in Swain Tech's White Lightning, muffler painted black
HyperFlow TMIC
Forge BPV
GrimmSpeed EBCS
NGK one step colder iridium spark plugs
Perrin lightweight crank pulley
Unorthodox Racing lightweight power steering pulley
Unorthodox Racing lightweight alternator pulley
KS Tech air pump delete
magnetic engine oil drain plug with a thick reusable washer
DIY homemade air oil separators
GMS hood dampers
Cooling
Koyo radiator, coated in Swain Tech's BBE
GrimmSpeed 160*F thermostat (MotoRad failsafe)
Mishimoto 1.3 bar upper radiator cap
Mishimoto radiator hoses
WC Lathe Werks radiator shroud
stainless steel T-bolt clamps
Heat Shielding
Litespeed titanium heat shield
DEI Reflect-A-Gold - heat shield
ThermoTec turbo wrap kit - turbine housing
Swain Tech White Lightning ceramic coating - headers, up pipe, EWG, downpipe, and catback
ThermoTec cool-air tube heat shield - cold air intake
Fuel
DW 1000cc top feed injectors
Walbro 255 lph fuel pump
Suspension
ZZYZX competition coilovers
- Koni 8611 dampers, double adjustable twin tubes, ~5.5-6" of damper travel
- aluminum housing and clevis, double height adjustable
- special slotted upper strut clevis holes for insane camber adjustment
- 600/500 Eibach springs (~11k/9k), 6" length, stroke of 3.32"/3.62"
- front & rear helper springs
- Noltec front camber-caster plates
- Cusco rear camber plates
- Torrington needle roller thrust bearings
OEM struts
- Swift Spec-R springs on
- cut OEM bump stops with Mobile1 synthetic grease
- Whiteline Com C front strut top mounts
- Group N rear strut top mounts
- Paranoid Fabrications 0.5" saggy butt spacers with extended studs
MSI rear subframe, 1.5" roll center correction and motorsport quality bearings
04-06 STI lower control arms
Whiteline 27mm front sway bar, set to stiff setting
Whiteline 24mm rear sway bar, set to soft setting
Whiteline front ball-link endlinks
Whiteline rear ball-link endlinks
Whiteline heavy duty 24mm rear sway bar mounts
Whiteline anti-lift kit (ALK), race stiffness
free caster mod
Litespeed lateral links with Group N bushings
Whiteline roll center adjustment (RCA) kit
Whiteline steering rack bushings
MSI trailing arms
Group N front trailing arm bushings
Group N rear trailing arm bushings (thanks to BigSky for the tool)
Enkei RPF1 wheels in black, 17x8 +45mm
*with Dunlop Direzza Sport Z1 Star Spec 245/40/17
Chassis Bracing and Modification
Lightspeed rear chassis bridge
Lightspeed rear bumper beam
AMS front bumper beam
TiC Giuyngmyo fender cowl braces
Whiteline front strut bar
Whiteline rear strut bar
Whiteline KSB700 lower control arm H-brace
removed front U subframe
removed spare tire, jack, tools
removed gray bar and brackets under rear seat
removed LATCH bars and brackets behind rear seat
removed sound deadening material behind rear seat
Drivetrain
ACPT carbon fiber driveshaft
MSI engine mounts
Beatrush transmission mount
Beatrush forged pitchstop mount
TiC rear diff mount bushings, race stiffness
Whiteline gearbox / transmission crossmember bushings, race stiffness
Metal outigger bushings
Whiteline rear subframe lockdown bolts
Kartboy short throw shift lever
Kartboy front shifter bushings
Kartboy rear shifter bushing
TiC linkage bushings
TiC pivot bushings
WC Lathe Werks shift knob
Cobb exhaust hanger (1)
Kartboy XL exhaust hangers (2)
Brakes
DBA 4000 series slotted rotors, front and rear (waiting for stock rotors to wear out)
Hawk HP+ pads
Goodrich stainless steel lines (stock lines are seized)
TiC titanium brake shims
TiC titanium wheel bearing shims
(brake rotors are seized)
Perrin master cylinder brace
Exterior
20% tint around, 70% tint on windshield
04/05 tail light swap
Rally Armour UR mudflaps
Perrin wing stiffis (2)
Hella Super Tones car horns
debadged trunk
de-stickered and de-emblemed grill
disabled daytime running lights
LED license plate lights
Interior
HD Motorsports GoPro camera
Innovate Motorsports LC-1 wideband with XD-16 gauge
Mach-V IC temperature gauges
Prosport premium peak/warn 52mm amber/white gauges
*boost
*exhaust gas temperature
*oil temperature
*oil pressure
*fuel pressure
*water temperature
*voltage
Prosport gauge installation accessories
ATI 3 gauge clock pod
ATI 2 gauge steering column pod
GlowShift 4 gauge A pillar pod
Panasonic CQ-9800U headunit
black STI floor mats
Autospeed dead pedal
LED map lights
disabled seat belt alarm
Fluids
engine: Shell Rotella T6 synthetic 5w40
transmission: Motul gear300 75w90 synthetic
read diff: Motul gear300 75w90 synthetic
brakes: Motul RBF600
coolant: Subaru coolant
Other
Perrin foam filter cleaner
Etymotic Research earplugs for highway cruising
Old parts
Torque Solution V3 pitch mount - switched to Beatrush since it's louder
Whiteline 24mm front sway bar, set to stiff 26mm setting - wanted a flatter front end when cornering
Whiteline gearbox / transmission crossmember bushings, regular stiffness - wanted race stiffness to make the gear whine even louder
GMS 170*F thermostat - kept coolant at 195*F under all conditions, not my preference
Perrin front strut bar - did not like the fitment
GrimmSpeed up pipe - dump tube did not fit with catted downpipe
Beatrush engine mounts - upgraded to solid mounts
Whiteline rear diff support lock / outrigger bushings - upgraded to metal
Hawk HPS pads - upgraded to Hawk HP+
Special thanks to
Got2Boostit2@ The Shop
T3h_Clap as himself
black = installed
red = purchased, but have not installed
green = not yet purchased
Dyno chart
290 whp & 321 wtq on a Mustang
tuned by Eric @ IPS Motorsports
dashed line = stock manifold, tuned to its potential
solid line = Litespeed header, tuned to its potential (more midrange boost, more timing up top)
the final pull
https://www.youtube.com/v/WWUrSxmst7I
Likes 0 Dislikes 0
Old 05-15-10, 01:56 PM   #3
joey.lisano
Gold Member
Fav Mod: mod bug
The beginning
The two loves of my life. One has my heart; the other is bone stock, except for the winter tires.
Another shot. My dog is now chasing squirrels in doggie heaven.
Likes 0 Dislikes 0
Sponsored Links
Advertisement
Old 05-15-10, 01:57 PM   #4
joey.lisano
Gold Member
Fav Mod: mod bug
reserved
Likes 0 Dislikes 0
Old 05-15-10, 02:07 PM   #5
joey.lisano
Gold Member
Fav Mod: mod bug
Current problems
1. The left rear window tint is peeling since it rubs against the rubber. The shop said they'd warranty it for free, but it's in Annapolis, MD and I'm far away now.
Likes 0 Dislikes 0
Old 05-15-10, 02:52 PM   #6
chargedvette02
Account Inactive
Feedback Score: 1 reviews
Fav Mod: I'm just a regular everyday normal guy.
chargedvette02 is an unknown quantity at this point
I had the same problem with my RA mud flaps on my 05. I called up RA and they sent me new hardware free of charge including shipping.
chargedvette02 is offline
Likes 0 Dislikes 0
Old 05-15-10, 04:19 PM   #7
litespeed
Advanced Contributor Level 3
Feedback Score: 8 reviews
Car: 07 STI
Fav Mod: Litespeed UEL Header
My Threads
litespeed is an unknown quantity at this point
Default Re: Joey's pathetic grocery getter (finally made a journal)
Car looks good man . Keep it going.
By the way, depending on your time frame, I might have an UEL header for you to try.
Adam
Litespeed
litespeed is offline
Likes 0 Dislikes 0
Old 05-15-10, 05:56 PM   #8
joey.lisano
Gold Member
Fav Mod: mod bug
Thanks for the comments guys.
It seems UM still cannot find a professor to teach internal combustion engines.
That's almost as bad as the handful of muscle cars I see when I go to the grocery store - none of them are modded, not even an exhaust!
Well, I have my ways...
Okay, so the rebuilding manual transmissions book is just for fun.
Likes 0 Dislikes 0
Old 05-25-10, 06:15 PM   #9
armyssoldierboy
Advanced Mastery Level IV
Feedback Score: 9 reviews
Fav Mod: seat time
armyssoldierboy is on a distinguished road
I have the Fuel Injection book and there's alot of stuff in there I don't quite understand...almost but not fully. There's formulas that I don't feel I need, kinda like engineering of parts I guess. I'm only a couple chapters into it though. When I get back from Germany, I plan to take EFI's week long ACP program for tuning.
GL with the protune and enjoy the ride!!
armyssoldierboy is online now
Likes 0 Dislikes 0
Old 05-26-10, 11:19 AM   #10
joey.lisano
Gold Member
Fav Mod: mod bug
Thanks. I wish I could start reading them, but I have waaaaay too many things to install. I've never had this much stuff before. Lots of good fun is in the works for this summer.
Here's a teaser pic I guess - Koyo radiator with Swaintech's BBE coating.
Likes 0 Dislikes 0
Sponsored Links
Advertisement
Forum Jump
Similar Threads
JPWEraser's Vanilla Deliciousness**Updated 12/2/10** Suspension refresh JPWEraser GD-Members' Journals 325 01-08-11 05:25 AM
- Custom BIG Front Sway Bars: 31.75mm --- Finally taking orders! AndrewSS GD-Vendor Classified Ads 79 05-21-08 05:58 PM
My Axis motor/GT30R build is finally done and tuned awdmonsta 2.5 Liter/Litre Factory Motor 5 11-01-06 09:59 PM
Tires/Wheels Finally ordered tires for my BBS RE's... ONEQUIKSTI GD-General 9 10-24-05 12:33 AM
Powered by vBulletin
