yamahaSHO's.... About time I start working on this piece!
CURRENT PROGRESS
ENGINE/INTAKE/FUEL/EXHAUST/MANAGEMENT
- COBB catless TBE (Ceramic Coated DP)
- Grimmspeed 38mm EWG UP w/TiAL EWG
- Blouch 20G/TD05H/8cm (Swain Tech Coated hot side)
DRIVETRAIN
SUSPENSION/BRACES/BRAKES
- KW v1 Coilovers w/ Group-N front mounts
- Whiteline Roll Center/Bump Steer correction kit
- Whiteline steering rack bushings
- MSI ALK
- COBB sway bars powder coated pink
- COBB Adjustable sway bar mounts
- COBB Rear strut tower brace
- StopTech Street Performance pads (F/R)
- OSWALD PERFORMANCE "Triangle Brace"
- ebay pink H-brace
INTERIOR
- Pioneer AppRadio
- ATI Triple Gauge Pod
- PLX Devices WBO2 w/ DM-100
- ProSport Boost and Voltage gauges
MISC
- McGard GOLD spline lug nuts
- Debadged
- OSWALD PERFORMANCE front bumper beam
- eBay V-limited lip
Parts sitting on the work bench:
- T1 top feed conversion w/ ID1000 injectors
- Invidia Equal Length Headers - Swain Tech coated.
- KillerB Pickup Tube
- TiC Klunk Killer - Comfort
- TiC 04-05 STi Bodacious Bushing Bundle
- TiC Tranny Crossmember Bushings
MY REVIEWS/NOTES:
It almost goes without saying, but these a quality pieces. The build quality is up to my standards, which for those that know me, I'm pretty anal. For the most part, these are a straight swap for the stock suspension. Before starting the task of installing them, I ordered new tophats, conical washers and all the misc replacment nuts and bolts I felt like replacing while I had it all apart.
One thing to note, the stock coilovers do not require the rubber (that is attached) to the rear tophats. I ordered Group-N tophats and the rears turned out to be a waste of money as you have to take off the rubber anyway (reading directions > me). The rears use a progressive spring, so without the rubber isolation, they're too stiff initiall (it's all relative). For the fronts, I installed the conical washer and Group-N mount and went to town. As said above, it's just a swap once that's all done.
Coming from the COBB springs that I purchased already on the car, these things are GREAT. They're firm, of course, but when hitting larger bumps (again, relative), the car does not get jar'd like the dash wants to punch me in the face. So far, with the limited time I've had with them, they keep the tires right were they need to be. For a street setup that wants to drop the car a bit and still retain strut travel, these are great coilovers. I don't drive the car in the winter, so I won't see any corrosion, but I would imagine that these would hold up very well judging by the build quality.
I went with the Group-N mounts because when being honest with myself... I take this to the track a few times a year, but it's a street car that gets driven on nice days. I didn't need the extra cost and harshness, so I put that money elsewhere. This is also the idea behind me getting the v1's as opposed to the v3's.
I can't really comment on these. The fitment was perfect and they haven't torn apart or slipped out. The car doesn't feel any different, but I've yet to push them to that point yet. Will review further.
After pulling out the stock bushings, I can't say I'd do this mod again. Apparently these are a vast improvement on 2004 STi's, but there is VERY LITTLE rubber on the stock driver's side mount for the 2005+. I can't really asy there is any improvement aside from the underside of my car looking more flashy.
The install was pretty easy as it came with a tool to pull the old bushings out. I made a mark on the steering shaft to put it all back together the way it was. These bolts made me stop using my torque wrenches again. I couldn't get them torqued to "spec" and I was worried about stripping them. I HIGHLY RECOMMEND TIGHTENING THESE BY HAND.
MSI ALK
They're noisy. I should have taken them apart and lubed them up before install. I'll do that eventually.
COBB sway bars
I bought the car with these already installed, so I cannot compare to a stock setup. What I can add is that before adding the adjustable brackets, I was able to flip the rear sway bar over with the car jacked in the rear. Now that I am able to adjust the mounting points, the bar fits very well. The quality is very good and they look good PINK!
COBB Adjustable rear sway bar mounts/brackets
As stated with the sway bar notes, this has made the rear COBB bar a perfect fitment. My enlinks now stand verticle and I am unable to flip the rear bar with my hand with the car jacked in the air/suspension unloaded. Since installing these and the Kart Boy endlinks, my bar no longer walks over to the driver's side of the car.
I bought the car with this already installed. The buddy I sold it to says he can feel that the bar stiffened up the rear of the car, but I noticed lots of creaking in the rear and upgraded to an Oswald Performance "Triangle" brace. The build of the COBB bar looked great. The diameter of the bar is MASSIVE, but it is also a hollow aluminum bar.
For a street pad with some good bite (READ: better than stock), these are great options. I was very concerned about picking the right pad. I love 'bite'. I love getting on the brakes and being amazed by the negative g-forces.
AFTER bedding these pads in on a stock rotor that had been turned, they have all the bite I could ever ask for on the street. They do take a little heat, but that is maintained after a stop or two. These have not made ANY noise and have shown much less dust than the stockers. In fact, my rear brakes still have the stock pads and me rear wheels are always the dirty ones, not the front. I'd definitely recommend giving these a go if you're looking for great stopping power on the street, quiet operation and less brake dust (all relative to stock).
As noted in the strut tower notes, I had LOTS of creaking in the rear of the car when took a spin without the back seats. Not only could I not stand the sounds, but the throught of the car flexing so much made me uneasy.
The install was very easy aside from some tight spaces. Everything is 'bolt-on', so no modification is required. Pretty much no trunk space is compromised, so there's really no reason to get a rear strut bar over this... The price difference is ABSOLUTELY worth it.
This brace cleared up ALL of my rear creaks immediately. The car feels 'more together' back in the rear allowing the suspension do what it was designed to do. I haven't been able to really push the car yet with this brace, so I'll follow up later about real performance.
These things look good and I haven't been able to scratch them yet. I prefer the style over the stock chrome lug nuts and I wanted to get rid of the factory keyed lock. They have a separate shank that allows the lugnut to spin without rubbing on the wheels itself.
As a note, the spline socket provided requires a 22mm socket to use. If you're worried about getting a flat, make sure you carry some extra tools. Also, do not use an impact with their spline socket.
The weight difference between this and the stock bumper is roughly 22lbs. I was looking for a way to lighten the car without loosing any functionality and appear 'stock'. Fitment was spot on. My bumper almost centered itself and all the stock parts snapped right on/over this bumper. I haven't pushed the car hard enough to notice any real difference, but I'm sure removing that much weight so far forwad in the car isn't going to make it worse.
Just like anything from Oswald Performance, the quality is top notch. I plan to purchase the rear bumper beam from them as well.
