2011 wrx sti hatchback weakspots ? - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > 2011 wrx sti hatchback weakspots ?
Old 06-04-19, 01:18 PM   #1
Jordivdm
Jordivdm is an unknown quantity at this point
Default 2011 wrx sti hatchback weakspots ?
Do any of you guys have any advise or tips off what to look for when buying a 2011 wrx sti hatchback (europian model)? Or any known weakspots that i have to look out for (excuse the english not my native language).
Thanks
Jordivdm
Jordivdm is offline
Old 06-04-19, 03:16 PM   #2
crick0234
Car: DGM '12 WRX STI 5DR
Fav Mod: shortThrow Shifter
crick0234 is on a distinguished road
Default Re: 2011 wrx sti hatchback weakspots ?
does europe have pre-inspections? where a mechanic looks over the car for leaks, checks fluids, checks rust, checks a huge list of things including engine codes?
i'd invest in a mechanic to inspect it for u. I've seen people just glance over an engine and go "IT'S GOOD."
gotta get that car up on a lift and look under it. hence why having a mechanic do it is well invested munnies.
crick0234 is offline
Old 06-04-19, 03:25 PM   #3
UrdnotWrexSTi
Car: Aspen White GR STi
Fav Mod: Coilovers
UrdnotWrexSTi will become famous soon enough
Check for previous modifications.
Is the Downpipe OEM or aftermarket? If it's aftermarket then it's most likely been tuned, and with that being said, the Accessport has most likely been unmarried and sold. (BAD)
If the downpipe is OEM, then is the turbo heat shield missing?
Is the turbo inlet OEM or aftermarket? If it's OEM, then check to see if it's leaking at the turbo clamp.
Are the injectors blue or black? If they're black then they are most likely aftermarket.
Is there an aftermarket intake?
There's a lot more stuff to check but these things are the obvious ones.
Also, check the oil level.
UrdnotWrexSTi is offline
Old 06-04-19, 07:28 PM   #4
Jedi03
Car: Blue 2009 STi Hatch
Jedi03 is on a distinguished road
Fix firewall issue regardless...otherwise just like any used cars do a prepurchase Inspection!
Jedi03 is offline
Old 06-12-19, 11:44 AM   #5
Jordivdm
Witch firewall issues if i may ask ? Like i said totally new car for my so i don't know anything about it at all. (I have a basic understanding on how engines work an such but thats about it). What i did notoce is that the eninebay is completly cramped so working on it is gone be a pain in the ass.
Thanks
Jordi
Jordivdm is offline
Old 06-12-19, 01:20 PM   #6
Jedi03
Its deceptive...take off intercooler and it's easy, the hatch has the clutch bracket is spot welded to the firewall, if you take the cowl cover off you can see if they are ripping off. When I noticed mine I drilled mine out and riveted them all
Jedi03 is offline
Old 06-12-19, 02:38 PM   #7
Jordivdm
Oh so its just some bad welds from the factory then ? Wel thats not to bad. But i will consider this ones i finally own one. Hunting 1 down right now bit there queit scares ober here (at least with all seats still left in them). So hopfully updating this saterday/sunday. Thanks for the help and tips everybody.
Thanks a lot
Jordi
Jordivdm is offline
Old 06-12-19, 06:58 PM   #8
UrdnotWrexSTi
Fav Mod: Coilovers
Subaru fixed the spot weld issues starting in MY10 or 11, I can't remember. They literally just made that sheet metal area slightly thicker than the previous years.
Old 07-01-19, 12:38 PM   #9
Ciedric
Ciedric is an unknown quantity at this point
I had a 09 STI hatch for almost 4 years. Stock turbo, 200cells Invidia downpipe and a Q300 muffler. Got a ecu flash from Ecutek. This car is a beast, 365 hp and 530Nm measered at 10 Celcius.
I was the first and probably the only one that got two broken spot welts in the NL.
Another weak spot is the steering pump. I replaced my but still got noises, probably the steeringrack itself.
Ciedric is offline
Old 07-09-19, 02:55 PM   #10
Jordivdm
Nice
Well steering pump was replaced 2 months ago so yeah thats good. I get a bit of noise when i back up nothing to be conserend about i guess. Thanks for the help everybody will post some pictures as soon as i get it washed.
Jordivdm is offline
