Looking for a working USDM EJ257 engine for sale near Toronto for my 2009 STI - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Looking for a working USDM EJ257 engine for sale near Toronto for my 2009 STI
Old 09-16-19, 04:05 PM   #1
Dec
Dec is an unknown quantity at this point
Default Looking for a working USDM EJ257 engine for sale near Toronto for my 2009 STI
Hello!
Im a new STI user just bought my car 2 months ago.
I need some help about my 09 STI. I had a problem with the engine. It seems a engine rebuild is requied (the engine run about 210k kms). I think the engine swap is cheaper than rebuild it. I found a complete engine with 40k kms, but the engine is imported from japan, so im not sure it will 100% fit to my car. May somebody can help me about it?
Do i need anything else or i can swap the engine without difficulty.
Thanks for any informations
Dec is offline
Old 09-17-19, 03:52 AM   #2
mheyman
Gold Member
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber
mheyman is a glorious beacon of lightmheyman is a glorious beacon of lightmheyman is a glorious beacon of lightmheyman is a glorious beacon of lightmheyman is a glorious beacon of lightmheyman is a glorious beacon of light
Default Re: Need help! Engine swap to JDM EJ257 Fits to my 2009 STI?
Sure the engine will fit. That certainly doe not mean all the external parts will. A swap is not that easy unless you have done a bunch because the correct information is difficult to come by. But still it will likley be the least expensive path - especially if you are doing the work.
Again USDM -> JDM can be time consuming just trying to figure out what parts will work. We have an 03 WRX swap and I am driving another biught this way at the moment.
But, Kms? Your not in the US ans not swapping a USDM engine? Perhaps your will be more similar to JDM?
If someone's description of a mod sounds to good to be true, it probably is !!!
If you think you should have lower r's at cruise you're in the wrong car
I become a more loyal IAG customer every time I drive my STI
mheyman is offline
Old 09-17-19, 04:24 AM   #3
Dec
Thanks for the information. Im in Canada thats why kms. USDM engine will good to me, just find JDM engines for good price with low kms. But than i think its not a good idea to swap JDM.
Dec is offline
Old 09-17-19, 06:55 AM   #4
enoxard
Advanced Mastery Level III
Fav Mod: kung f00 skillz!
enoxard has a spectacular aura aboutenoxard has a spectacular aura about
this is way off topic, but we used to drop JDM motors in USDM hondas all the time.. never had an issue. but i digress.
enoxard is online now
Old 09-17-19, 08:03 AM   #5
STINick19
STINick19 is on a distinguished road
I'm also an old school Honda fan. Electronics and emissions things were common issues. For example, the "OBD2" JDM Honda engines didn't come with the CFK sensor (Crank Fluctuation Sensor) and there wasn't even a provision for it on the oil pump. You either had to perform a CFK bypass to trick the ECU or swap the oil pump, add the sensor and use a USDM harness. The JDM intake manifolds also didn't have a provision for the evap purge solenoid.
I'm sure the same applies to Subarus for things like the TGVs. At least for Hondas, it was easier to use the JDM long block and swap over all of the USDM accessories to avoid any OBD2 issues.
OP: You may be better off searching for threads on EJ207 swaps to see what that typically entails. It may give you a better idea of what you may run into with the JDM EJ257.
STINick19 is offline
Old 09-17-19, 06:25 PM   #6
Dec
Default Re: Looking for a working USDM EJ257 engine for sale near Toronto for my 2009 STI
Im just looking for a complete working USDM EJ257 engine for my 2009 STI. If anyone have it to sale near Toronto, it will helpful. Thanks
Dec is offline
