White Fox - 2016 STI Limited - Page 14 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > White Fox - 2016 STI Limited
Old 12-13-16, 10:14 PM   #131
Aguamala
Car: 2016 STI Limited-CWP
Fav Mod: Mine
Aguamala is on a distinguished road
Default Re: White Fox - 2016 STI Limited
I finally got around to installing the APR brake duct cooling system. What a pain in the ass the whole process was, but it's finally in. God damn, that carbon fiber looks so good though.
First I was given two passenger side backing plates, which took about a month to replace. I didn't realize I was given two of the same side until I had the whole car apart. Once I finally got them, I found out that because I have thicker rotors, I had to grind and cut the carbon fiber backing plates to fit from preventing from rubbing. Once that was finally done I found out that the silicone hose is sitting directly on my header flange. I wrapped that side of the header in a heat wrap and it's been smoking for the past couple days. I'm so concerned about the amount of smoke, I went out an bought an Auto/Marine Fire Extinguisher and keep it within an arms reach. Once the smoke eases off a little bit I want to see if the silicone hose is showing any signs of melting or other heat related issue(s).
I'll be stopping into Cobb (to their surprise) in a couple weeks to discuss engine upgrades for the next phase of upgrades.
White Fox - 2016 STI Limited-15540760_10206048618774959_3007713958915397988_o-jpg   White Fox - 2016 STI Limited-15493375_10206048622135043_3039600913522932829_o-jpg   White Fox - 2016 STI Limited-15393010_10206048620254996_6402605862499740324_o-jpg
Aguamala is offline
Likes 4 Dislikes 0
Old 01-19-18, 10:41 AM   #132
cphibs
Car: CPW 17 STi
Fav Mod: ETS Extreme Catback
cphibs is an unknown quantity at this point
Originally Posted by Aguamala View Post
A few things have happened since my last major post.
Sixth, with the help of the local Subaru community members and some coaxing with money, I finally got around to getting them to install the Morimoto Demon Eye, Morimoto Angel Eye, and the Morimoto C-Light Switchbacks hooked up and working perfectly. While the headlight was open, I installed blacked out orange side markers to get rid of the last bit of orange on the car
Can you enlighten me on how you went about installing these angel eyes? Any trouble from the police? Price? Thanks
cphibs is offline
Old 01-19-18, 11:46 AM   #133
muller_777
pwn n00bs
Feedback Score: 15 reviews
Car: '18 CBS STI
muller_777 will become famous soon enough
gosh i love carbon fiber and varis.
muller_777 is offline
Old 12-10-18, 12:26 AM   #134
Aguamala
Fav Mod: Mine
Well, my engine finally shit itself with very loud audible rod knock. I'm in the process of buying a new block with forged internals along with a few other goodies.
Case: IAG Extreme Stage 4
Pistons: Manley Extreme Duty with Upgraded Wrist Pins
Rods: Manley Turbo-Tuff Tri-Beam Rods with ARP 625+ Rod Bolts
Bearings: ACL Main and Rod Bearings
Crank: Manley Extreme 79MM Crankshaft
Head Studs: ARP 14MM Headstuds
Headgasket: Fire-Seal Gasket
Valves: Supertech +5MM Valves
Camshafts: Kelford R-220C
Springs and Retainers: Kelford Race Series Springs and Retainer Set
Oil Pan/Baffle/Intake: Killer B Package
Intake Manifold: AMS Manifold
Turbo: Precision 3870 with ETS Rotated Turbo Kit
FMIC: ETS Front Mount Intercooler
Once I get this installed and I'm up and running (and I've got few more dollars in the bank) I'm going to focus on fuel upgrades to dial in the true power this thing will be capable of. I'm hoping for 450-500hp at first, and think 800-1000 is obtainable once I get fueling upgrades in place.
Aguamala is offline
Old 12-10-18, 07:31 AM   #135
Leemanfor
Fav Mod: EFR 7163 Turbo
Leemanfor has a spectacular aura aboutLeemanfor has a spectacular aura about
damn that sucks. how long she last on stock engine with the 1.5?
Leemanfor is offline
Old 12-10-18, 11:16 AM   #136
Aguamala
Fav Mod: Mine
I got 36,000 miles out of the car, and about 29,500 after the I put in all the major upgrades which is when I got the Dom 1.5 thrown in. The turbo is still is good condition, (from what I can tell right now), but going to bigger turbo (4" inlet) should allow me to put it up for sale somewhere, or keep it tucked away incase I want to throw it back on.
Aguamala is offline
Old 06-24-19, 11:49 AM   #137
Aguamala
Fav Mod: Mine
‚ÄčI blew the motor just before Thanksgiving in 2018. I decided to go ahead with my plan and make this bulletproof. I've installed the following:
Case: IAG Extreme Stage 4 closed block short block
Intake manifold: Process West
Turbo: Precision Gen 2 6870 with ETS rotated kit
Pitch mount: Perrin with firewall brace
Engine mounts: IAG Street series
Air oil separator: IAG Competition AOS
Throttle body: Boomba Racing 75mm DBW
Injectors: Injector Dynamics 2000CC
Fuel pressure regulator: Aeromotive 1000
Fuel Rails: IAG
Intercooler: ETS 15+ FMIC with titanium piping
Axles: drive shaft shop 1000hp capable
Drive shaft: APR carbon fiber
Header: Killer B Motorsport Holy Header
Clutch: Competition Clutch STI 240mm MPC Twin Ceramic Clutch
Flywheel: lightweight
Fuel pump: Dual Walbro 450
Surge Tank: Radium (with distribution block and wiring kit)
Oil pan: Killer B with windage tray and pickup
Coilpacks: Okada Projects Plasma Direct Coil Packs
Air pump delete: Andrewtech
Wastegate: 43mm Tial dumped atmospherically
Blowoff Valve: Tial - Atmospherically Dumped
Downpipe: custom made without Cats
Exhaust: Invidia Q300
Miscellaneous: braided lines, port, polish and deck cylinder heads, ceramic coated turbo (hot side), headers & downpipe.
Brakes: Brembo GT Big brakes (front and rear)
Rotors: Brembo slotted
Brake cooling ducts: APR carbon fiber intakes and dust shields with fire proof tubing
Axles: driveshaft 1000hp Capable axles
Wheels: Wedsport SA-20r 18x9.5
Tires: Bridgestone RE-71R's
I'm sure I'm forgetting a couple things, but this covers the bulk of it.
Aguamala is offline
Old 06-24-19, 11:52 AM   #138
Aguamala
Fav Mod: Mine
The tune happened last week, but the Clutch seized up. I guess the clutch was manufactured too big which rubbed against the pressure plate and the resulting rub caused the ceramic disc to gum up the whole thing. JR couldn't get the car in/out of gear, which ended the day on the dyno. We got 457hp and 397ft lbs before she seized. I've replaced the clutch with an ACT 6-puck for the time being until I can get Competition Clutch to get me a new twin ceramic disc clutch under warranty. Next time JR is in town we will schedule the rest of the pump gas tune and then roll into the e85 tune for the big power. I can't wait.
Aguamala is offline
Old 06-24-19, 12:23 PM   #139
Aguamala
Fav Mod: Mine
Aguamala is offline
GR Sedan: Smitty's 2011 DGM STI Sedan - The Perpetual Build smitty5788 GR-Members' Journals 1817 02-15-17 12:25 PM
Ship it | Build it | Return it | Engine Build SALE!!! @ TopSpeed [email protected] GR-Engine, ECU, Power, Drivetrain 9 07-27-11 04:34 AM
keeping stock beep with viper alarm? a143gsxr GR-ICE/Security 28 02-08-09 01:28 PM
AMS Top Shop Engine build..the quest for 1000hp on 100octane! AMS Vendor Announcements & Project Buildups 8 11-05-08 04:58 PM
