High AF Learning 1 - Subaru Impreza WRX STI Forums: IWSTI.com
High AF Learning 1
High AF Learning 1
Go Back   STI Forums > > > High AF Learning 1
Old 05-18-19, 07:17 PM   #1
zero316189
zero316189 is an unknown quantity at this point
Default High AF Learning 1
Hello,
What would cause for AF Learning 1 to reach -13 when letting go of the gas pedal after accelerating while still being in gear. In every other situation the car performs as intended. Any help would be greatly appreciated.
Thanks
zero316189 is offline
Old 05-18-19, 07:56 PM   #2
JSR84
JSR84 is an unknown quantity at this point
One of your learning ranges has learned a -13 percent correction. Probably the B range.. Set your monitors to AF Learning A, B, C and D to see what one it is.
JSR84 is offline
Old 05-18-19, 08:18 PM   #3
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
yamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant futureyamahaSHO has a brilliant future
Default Re: High AF Learning 1
AF Learning 1 gives you the current trim, keep monitoring that. I focus on steady state throttle/load when referencing trims. If you want to post a log, I can take a look.
Looking at turbo upgrades? Click here.
www.jaztuning.com
yamahaSHO is offline
Old 05-19-19, 04:00 PM   #4
Noximus
Advanced Mastery Level II
Feedback Score: 3 reviews
Fav Mod: 2015 STI Steering Rack!
Noximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really nice
Dirty MAF is the most common issue. Get yourself a can of MAF sensor cleaner. Remove your MAF, DO NOT TOUCH THE WIRES INSIDE, keep your hands on the head, spray all the wires inside a few times, then re-install.
Noximus is offline
Old 05-20-19, 08:49 AM   #5
[email protected]
Car: 2011 STI Sedan
Fav Mod: Arcflash LLC Ohlins Coilovers
joshua@arcflashllc is on a distinguished road
What mods do you have and what map are you running?
Originally Posted by zero316189 View Post
Hello,
Thanks
COBB Pro-Tuner/Dealer <-10% OFF SALE NOW THROUGH 11/26!!!!!!
Custom valved and sprung Ohlins Coilovers
Antigravity Battery <-- SAVE 22 LBS!!
SPL Suspension Components
joshua@arcflashllc is offline
Engine High A/F Learning 1 at Idle on E85 OHappyDay 2015+ STI Discussion 7 06-13-17 02:03 PM
Going to wire road lights. Need a 'high beam is on' signal on my 2012 STi. evilspoons GR-Exterior 10 04-22-13 10:05 PM
Crawford Performance High Flow Water Pump CrawfordPerformance.com Vendor Announcements & Project Buildups 13 03-22-13 02:51 PM
Crawford Performance High Flow Water Pump CrawfordPerformance.com Vendor Announcements & Project Buildups 0 03-21-11 07:48 AM
OBD-II Codes (CEL Light Codes) 201Motorsports 2.5 Liter/Litre Factory Motor 8 06-03-09 03:19 PM
