Factory STi Manifolds, heat damage at flange (Solved: Casting Flaw) - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > > Factory STi Manifolds, heat damage at flange (Solved: Casting Flaw)
Old 08-30-19, 03:55 PM   #1
Bumblebeelotus
Contributor
Car: 2011 STi Plasma Blue
Fav Mod: My Lotus :D
Bumblebeelotus is an unknown quantity at this point
Default Factory STi Manifolds, heat damage at flange (Solved: Casting Flaw)
Decided to pull my headers off and noticed the flange at Cyl 1/3 was showing some strange wear. Anyone have any insight?
Bumblebeelotus is offline
Old 08-30-19, 04:14 PM   #2
killerbmotorsport
Feedback Score: 12 reviews
Car: Blue 05 WRX STi
Fav Mod: It's all good
killerbmotorsport is just really nicekillerbmotorsport is just really nicekillerbmotorsport is just really nicekillerbmotorsport is just really nicekillerbmotorsport is just really nice
Default Re: Factory STi Manifolds, heat damage at flange
I don't understand, what wear? I see carbon, a good seal on the fire rings and no signs of leaks.
HOLY HEADER - Highly Advanced and Full of Awesomeness - Patent Pending
OEM Oil Pickup Failures vs. The Ultimate Oil Pickup
World's Best Performing Air Oil Separator
Brushed Delrin Shift knobs - Grab Our Knobs - It's Good Shift! CLICK HERE!
killerbmotorsport is offline
Old 08-30-19, 04:18 PM   #3
Bumblebeelotus
Contributor
If it looks normal, great! I was worried about the rusty/pitted portions on the right of each port.
Old 08-30-19, 09:33 PM   #4
UrdnotWrexSTi
Car: Aspen White GR STi
Fav Mod: Coilovers
UrdnotWrexSTi will become famous soon enough
Cast manifolds last pretty much forever, you're fine. Sometimes they will crack from quick changes in temperatures, say from a hot manifold getting cold water on it but other than that they almost never break, especially at the flange where it's thickest. Those "porous" spots look like carbon build, like killerb said.
UrdnotWrexSTi is online now
Old 08-30-19, 10:08 PM   #5
Bumblebeelotus
Contributor
Interestingly they're actually holes, maybe .5mm deep... I'll clean it up tomorrow and get a better pic, but here's a closeup;
Cleaned it up a bit with sandpaper, could it be a casting defect? It's actually porous, and even seems to have warped the edge in places.
Old 08-31-19, 03:26 AM   #6
killerbmotorsport
Now those pics are a bit more revealing. At first I thought it was just the 'normal' texture of carbon build-up, but now it seems like casting voids. Those were there when the car was assembled at the factory.
Anything that looks like it may be hanging or could break-off, I would hit it with a file or grinder to smooth it down a bit. This way no pieces will come off. Unless you're seeing something bad enough that looks like it could effect the integrity of the part, I would just touch it up and put it back together and be on my way. Going to a dealership and talking them into replacing this part (which they may argue is 'normal') is just not worth the effort IMO.
Old 09-02-19, 09:36 AM   #7
Bumblebeelotus
Contributor
Appreciate it! Used some carbide bits to smooth it down, ended up rounding the edges on all of the ports.
Old 09-03-19, 06:43 AM   #8
Jedi03
Car: Blue 2009 STi Hatch
Jedi03 is on a distinguished road
Default Re: Factory STi Manifolds, heat damage at flange (Solved: Casting Flaw)
in the rust belts i have seen cast manifolds rust away or high heat crack them in half...super fun having a 3 piece manifold come off one side [email protected] could be comnbination of high moisture environment and exhaust gas making acidic moisture...is normal but shouldn't cause issues anytime soon!
Jedi03 is offline
