Hi guys, I'm 21 years old and this is my 2012 Subaru WRX STi. I bought the car July 2011. This is my first car ever. I had a ringland failure happen at 8 thousand miles on the car. So i sent it over to IAG PERFORMANCE. Here is the list of mods that has been done. Everything in this build is out of my pocket. Im not sponsored by mom and dad.
MOTOR
GTX35R Rotated
GT Spec stainless Steel Header with V-Band Connection ( Equal Length )
Invidia Racing Catback Exahust
COBB EBCS
COBB AP V2
IAG Custom V-Band Uppipe
Tial Stainless Steel Turbine Housing
IAG Custom 3" Stainless Steel V-Band Rotated Downpipe
Stainless Steel Braided Oil Feed Line
Aeroquip AQP Oil Drain Line with Billet Flange
Billet Banjo Water Line
Stainless Steel Power Steering Line
IAG Catch Can Kit
Tial Sport Q Series BOV
Tial Sport 44mm V-Band Wastegate
IAG Custom Dump tube
IAG Custom Rotated 4" Draw Pipe
K&N 4" Hi-Flow Air Filter
Manifold Gasket
Downpipe Gasket
Stage V Heads - Ported - Bigs Valves, Springs and Retainers
Kelford 272cams
ID1300cc
Manley Platinum series pistons 99.75mm
Manley Steel Rods ( I Beams )
ACL Race Main Bearing Kit
ACL Race Rod Bearing Kit
FHI Engine Gasket
Killer B oil pick up
Manley Valve Springs + Retainers
Manley Extreme Duty Valves Set
Manley Race Flo Valve Set
Aeromotive Fuel pump 340lph
IAG's Flipped Intake Manifold + FMIC
Koyo radiator
Mishimoto Radiator Hose Kit
IAG Intake Air Temp. Speed Density Kit
Competition Stage 4 Clutch
AEM 3.5 Bar Map Sensor
IAG Map Sensor Adapter
APR Head Stud Custom Aged Kit
IAG Air Pump Block Off Plates
IAG CNC Top Feed TGV Deletes
IAG Fuel Rail Line + Fittings Race Kit
Aeromotive Fuel Pressure Regulator
Suspension
Tien Flex Coilovers
Cusco Rear Lateral Links
Front Camber Bolts
Drivetrain
Cobb Short Throw Shifter
Exterior
Body work and paint done by Ulterior Automotive Front Royal, VA
Varis Kit D APR Carbon Fiber Front Lip
Custom Rear GT inspired diffuser
Grimmspeed License Plate Relocator
Black STi Side Badges
35% Tint
Interior
AEM Boost, Oil Pressure, Oil Temp, Fuel Press, AFR Gauges
Harness Bar
Sparco 4 Point Harness Belt
all stickers were taken off like a week ago. these are the only pictures i had on my computer. Im not home or else i would have taken better pics. Thanks btw
Yeah man, I've been there off and on since '07. I'm moving to Va at the end of the month and debating on using them as my shop again or using a Subaru specific like IAG or Andrewtech.
Your car looks great by the way. Did you get aligned at PTuning as well?
I got the cobb bov because when i went stage 2 my tuner said my stock bov will start to leak. As far as warranty goes. Nothing will void your warranty until that aftermarket part effects something else. FOR EXAMPLE: if you get a bigger turbo and your motor blows... subaru wont cover it because your aftermarket part did the damage. But yah the bov is nice. I cant really hear it because of the Cobb sf intake is loud lol
Nice ride btw. I do hate to burst your bubble just flashing it with an AP just at stg1 for example voided the Warranty. I knowingly did it but I don't care. If the dealership you take it to is strict for warranty repairs your warranty is done.
Im really excited to announce that the varis kit B will be at my door step around August.
Im keeping the hood stock.
I may or may not get the front canards
Your car is shaping up to be quite a beast however I will admit I thought it looks pretty damn perfect with the Works. Look forward to seeing the progression of this build.
Build quality is nice on it. I went with a single exit exhaust so if you have a quad it'll look a little better. I did hydro dip it in carbon fiber so thats why it has that glossy look. When you buy it from HT Autos, it will come in this flat black look. I love it and never had fear of breaking it. The only problem i had was it collects little rocks inside of the diffuser.
Related Threads
IW STi Forum
4.1M posts
121.3K members
Since 2001
