Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 **** - Page 97 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > > Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 ****
Old 08-22-18, 06:28 AM   #961
Noximus
Advanced Mastery Level II
Feedback Score: 3 reviews
Fav Mod: 2015 STI Steering Rack!
Noximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of light
Default Re: Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 ****
One of you who has this issue is going to need to take the lead and figure it out. There has to be something causing it. I can play on all traction modes without any issues as many others. There’s a huge majority with no issues at all.
I still strongly believe as I’ve mentioned many times before that it’s a bad sensor. SAS, ABS, etc. Something has to be bad some where.
I’ve had a bad MAF that was reading all values within spec when evaluating it individually, but as a whole, it screwed my AF Learning significantly to cause a lot of issues. If I had tempted faith and replaced it 2 years sooner, I would have saved a lot of troubleshooting time and tuning expenses. I’ve had an O2 sensor read correctly when tested, but it still ended up being bad. Anyways, there are more examples I can explain with this car, but you get the picture.
Noximus is offline
Likes 1 Dislikes 0
Old 08-22-18, 06:53 AM   #962
Joebie
Feedback Score: 1 reviews
Fav Mod: The car...
Joebie is a jewel in the roughJoebie is a jewel in the roughJoebie is a jewel in the roughJoebie is a jewel in the rough
I literally never have the traction control on
Joebie is offline
Old 08-23-18, 06:21 PM   #963
inpuressa
Advanced Contributor Level 5
Fav Mod: Cobb AP
inpuressa is an unknown quantity at this point
Thanks guys, going to make the big leap in getting that leaking rack replaced along with the poly bushings.
That passenger side bushing, I read that it's a direct fit although it doesn't seem so at first. Any update to this?
I also should replace the PS pump, but I heard that Subaru did some silent revisions for improvement. Is 34430FG040 the latest one?
Thanks
inpuressa is offline
Old 08-23-18, 06:33 PM   #964
Noximus
Thanks
The passenger bushing is a direct fit. It was my misunderstanding. The stock bushing is very soft and flexible, it didn't seem it would fit at first glance when comparing the stock rubber to the poly version, but it fit perfectly.
2019 Subaru STI TYPE RA 2.5L TURBO 6MT Pump-power steering. Oil - 34430FG040 | Subaru Parts Warehouse, Branford CT
34430FG040 is the one used on the 2019 Type RA
Noximus is offline
Old 08-28-18, 05:20 PM   #965
bigBADbenny
Becoming A Contributor
Car: OBP Liberty GT-B 6MT
bigBADbenny is on a distinguished road
There is a fix involving an arduino with canbus io’s and programming to increase the steering angle sense back to stock...
https://forums.nasioc.com/forums/showpost.php?p=44302713&postcount=512
https://www.google.com.au/search?q=subaru+arduino+can+steering+wheel+angle&i e=UTF-8&oe=UTF-8&hl=en-gb&client=safari
bigBADbenny is offline
Old 08-29-18, 12:03 PM   #966
Dinnyin
Car: 12 OBP STI Hatch
Dinnyin is an unknown quantity at this point
makes you wonder why everyone isn't having issues then...
Dinnyin is offline
Old 08-29-18, 12:19 PM   #967
eaglehunter
Advanced Contributor Level 1
Fav Mod: Cobb AP, downpipe and protune (best bang for bucks thus far)
eaglehunter is on a distinguished road
I am also wondering how many are driving with the traction control off all the time...
eaglehunter is offline
Likes 1 Dislikes 0
Old 08-30-18, 07:39 AM   #968
Dinnyin
good point
Dinnyin is offline
Old 09-20-18, 01:21 PM   #969
inpuressa
Fav Mod: Cobb AP
I was finally able to work on my car this week.
Few things I found out:
1. Those fittings for the hard line connection was a pain. Get yourself a set of crowfoot tool and some creativity
2. I bought the superpro bushings, but the passenger side was a bit too big as indicated on the pic you see on this thread. I was told that this was ok, and the part fits, but the steering rack had play when I torqued down the bolts. I measured the rack body and found that the new one was about 0.75mm smaller in diameter than the old one. This could be the reason for the play. I just used the OEM one(the new and old OE bushing is the same part#), and the play went away. This will have to do for now. Is this the reason why whiteline has two different bushings in their kit?
3. Moving the passenger side bolt that holds the control arm to the cross member will make things easier to get the rack out/in. I also swapped my control arms to the 2011 one, so it was part of the process anyway.
Took the car out for a test drive, and I need to center the steering wheel one notch. But the car felt really responsive, almost like a new car The steering felt heavier, due to the increased ratio, but I like the feeling.
PS. I hate those hard line connectors
Likes 1 Dislikes 0
Old 12-30-18, 01:48 PM   #970
kwiksti
Active Participant
Car: 2014 WRB STI Hatch
kwiksti is an unknown quantity at this point
Does this solve the potential from future leaking? Meaning is the next gen rack batter built/engineered?
kwiksti is offline
Similar Threads
FS (USA,IL): Sea Sucker Mini Bomber Bicycle Rack (All models / Makes) Robstunner Exterior Parts For Sale 0 07-21-13 06:20 PM
FS (USA,CA): Yakima roof rack (LANDING PADS STYLE) + 2 bike racks esker Exterior Parts For Sale 2 01-17-13 08:15 AM
FS (USA,VT): 2000 Subaru Impreza 2.5RS Full STI Swap RSTI vt4cam Used STIs For Sale 4 04-24-12 12:46 PM
Suspension/Stiffening 05+ STi Spec C rack ends CPC GD-General 0 08-14-10 02:27 AM
