Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 **** - Page 93 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > > Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 ****
Old 02-06-17, 08:28 PM   #921
salvi
Becoming A Contributor
salvi is an unknown quantity at this point
Default Re: Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 ****
Got the rack from my local dealer instead since they had it in stock. Got it for 670 including taxes.
How do you center the rack? I want to make sure that it's centered before installing it.
salvi is offline
Old 02-07-17, 08:18 AM   #922
Noximus
Advanced Mastery Level II
Feedback Score: 3 reviews
Fav Mod: 2015 STI Steering Rack!
Noximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of light
It only goes in one way as steering knuckles only have one horiontal location you can install them in. The only difference is that you can measure your current rack wdith from tie rod end to tie rod end to get the alignment as close as you can to what you have now. This is a moot point though as you should get an alignment afterwards anyway.
Noximus is offline
Old 02-07-17, 09:56 PM   #923
salvi
Got the old rack out today after work. What a pita was to disconnect the damm lines. Got the one installed and should have everything done by tomorrow. Does anyone have the torque settings for all the hardware that is removed?
I also have to replace two front wheel studs since my brother using an impact gun snapped them off while removing the wheel nuts :/
salvi is offline
Old 02-08-17, 07:06 PM   #924
RocketRobin
Car: British Racing Green
Fav Mod: Snow Tires
RocketRobin is on a distinguished road
I've had the 15 rack in my 09 since before Xmas.
Had to replace the pump, etc. cause the old rack sucked (literally).
Works perfectly. Doesn't suck in air + dirt in cold weather to blow the seals (suck in more dirt and blow the entire system).
Replaced the rack bushings with Whiteline. Reduced torque steer, which, apparently, doesn't exist for the teenage street racers, yadadada.
Cheers!
Rocket
RocketRobin is offline
Old 02-08-17, 07:28 PM   #925
salvi
Finally finished the rack today. The steering wheel is a little off, but I'm taking it for an alignment tomorrow. I took it for a short drive and the steering does feel tighter/heavier and more direct.
One thing to note, on the first regular turn that i took, the traction control went crazy and scared the crP out of me. I disabled it until after I get it aligned. Why do Subarus need traction control? My bugeye doesnt have it.
salvi is offline
Old 02-09-17, 09:24 AM   #926
kingsalami
Becoming An Advanced Contributor
Feedback Score: 6 reviews
Car: 2009 WRX 5-door
Fav Mod: Stage 2 Pro Tune
kingsalami is an unknown quantity at this point
You need to line up the steering rack-to-U joint splines PERFECTLY so the ESC stops seeing the steering wheel turned when the wheels are straight. Even one spline off will trigger ESC.
kingsalami is offline
Likes 1 Dislikes 0
Old 02-09-17, 11:21 AM   #927
salvi
I connected the ujoint when the wheels were straight and the steering wheel was centered, but when I took it for a drive the steering wheel ended up a little off. The alignment shop should be able to fix it by adjusting the tie rods no?
salvi is offline
Old 02-17-17, 02:52 PM   #928
2bfi
Advanced Contributor Level 3
Feedback Score: 2 reviews
Car: 2011 WRX STI
Fav Mod: Lightweight flywheel
2bfi is on a distinguished road
I hope you didn't turn the steering wheel while the rack was disconnected. That can damage the roll connector as stated in the service manual.
Besides that, if your steering wheel is in between splines, the alignment shop should be able to straighten it by the tie rods.
If it is off by a spline or more, remove the steering wheel and center it as best as you can. Then alignment can take care of the rest.
Mine was off by 3/4 spline so I moved it over by a spline which reduced it to 1/4 spline in the other direction. Then I used SmartStrings to align the car. The car runs straight and true.
2bfi is offline
Old 06-14-17, 11:26 AM   #929
lidrew
Advanced Mastery Level III
Feedback Score: 1 reviews
Car: 2011 DGM Sedan
Fav Mod: Brake Dust
lidrew will become famous soon enoughlidrew will become famous soon enough
Turns out my Factory steering rack is shot on my 11 and leaking badly so I now have an excuse to get the 15 steering rack! Dealer quoted me $775 for the rack and a few hours labor. I see the general motor parts online site has it for $592. Think I will order online and have dealer install.
2011 DGM Sedan on E85
lidrew is offline
Likes 1 Dislikes 0
Old 06-24-17, 05:10 AM   #930
lidrew
Car: 2011 DGM Sedan
Fav Mod: Brake Dust
Got the 15 Rack installed and it's excellent! Very tight and precise with zero play. Completely different driving experience. My OEM 11 steering felt loose in comparison.
lidrew is offline
Likes 2 Dislikes 0
Similar Threads
FS (USA,IL): Sea Sucker Mini Bomber Bicycle Rack (All models / Makes) Robstunner Exterior Parts For Sale 0 07-21-13 05:20 PM
FS (USA,CA): Yakima roof rack (LANDING PADS STYLE) + 2 bike racks esker Exterior Parts For Sale 2 01-17-13 07:15 AM
FS (USA,VT): 2000 Subaru Impreza 2.5RS Full STI Swap RSTI vt4cam Used STIs For Sale 4 04-24-12 11:46 AM
Suspension/Stiffening 05+ STi Spec C rack ends CPC GD-General 0 08-14-10 01:27 AM
