Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 **** - Page 100 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > > Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 ****
Old 09-13-19, 07:39 AM   #991
Western_STi
Advanced Contributor Level 1
Fav Mod: StopTech Stainless Steel Brake Lines
Western_STi is on a distinguished road
Default Re: Swap a 2015+ Rack into an earlier STI?**** Parts Update Post 1 ****
Has anyone tried a 18-19 Steering Rack? PN 34110VA131. Wondering if it’s different enough to cause problems.
Western_STi is offline
Old 09-16-19, 09:08 PM   #992
Noximus
Advanced Mastery Level II
Feedback Score: 3 reviews
Fav Mod: 2015 STI Steering Rack!
Noximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of light
The wheel base is the same. I don't believe anything else change on that end. It should fit in theory.
You'll have to buy it and try it just like I did with the 2015 one. Be the first.
Noximus is offline
Old 09-17-19, 10:00 AM   #993
eaglehunter
Fav Mod: Cobb AP, downpipe and protune (best bang for bucks thus far)
eaglehunter is on a distinguished road
Is the ratio different on the newer one? If not, why bother, just go with what has been proven already.
eaglehunter is offline
Old 09-27-19, 04:13 AM   #994
gregnauman
Becoming A Contributor
gregnauman is an unknown quantity at this point
Originally Posted by jharris48 View Post
I just did the 2015+ rack swap into my 2011 STi wagon and just thought I’d share the experience as another data point.
I followed all the gouge on strapping the steering wheel in place to be centered and counted the exposed threads on the tie rods to attempt to get it set up as close to my old rack as possible. It was very straight forward, however I screwed up not getting the rack centered when I connected it. The steering wheel was centered, but the rack was not. I had the wheels off the car and it looked close to center judging from the rotors. When I got the wheels back on and took the car off the jacks it was slightly more apparent. I don’t have any kind of alignment equipment and the miss alignment was subtle enough that I wasn’t sure if the rack was off or if it was just an optical illusion. I took the car out of the driveway and went about 30 feet and the VDC lost its mind and eventually deactivated itself. I immediately pulled the car back into the garage and called it a day.
The next morning I was able to disconnect the steering linkage without taking anything off the car other than the undertray. I loosened the top bolt and slid the u joint up the steering wheel shaft and was able to clear the connection into the rack. To make sure the rack was centered I clamped to pieces of trimming I had laying around to make a long straight edge that I could hold flush to the rear tires and the front tires at the same time. I lined up the tires with the front end jacked up. It was clear there was a bit of toe out, but both front tires had the same amount of toe out and they were otherwise straight and the rack centered. I reattached the steering linkage and took it for another drive. No more VDC/traction control issues. I was able to drive the car to the shop to fine tune the alignment from there. I haven’t driven the car at autocross or the track yet, but pushing it around town a little hasn’t resulted in any traction control issues. It’s only been a couple days but so far I love it. I did have some shudder in the steering a few times at low speed sharp turning (parking), but I’m not sure if that is just all the fluid getting settled in the new system or just the fact it’s a brand new steering rack and I’m not used to so much feed back. I bleed the system carefully and thoroughly, but I guess I could I screwed it up. It seems to have gone away though. I’ll share if anything comes of it.
This was long but hopefully it helps to have another data point of experience.
I had this exact issue and all is well. Installed the rack last couple days taking my time.
Def the steering is way heavier than the GR rack which was WAY TOO LOOSE. Its actually heavy believe it or not like my 2005 Outback XT was and also my daughters 2007 Outback Sedan H6 car.
It is a great mod, quicker steering and no more feeling out of control in the corners cause the other rack was so loose. It would almost bump steer if cornering and hitting a imperfection in the pavement.
Originally Posted by Joebie View Post
Nope, none that I found unfortunately. (there is a weird pin, but I think that's unrelated to centering).
As far as I can tell there is 1.5 turns to each side from the center. So it was pretty easy to find center once it was on. (Initially from center I had 1-3/4 turn to the right and 1-1/4 to the left) I imagine if I counted the teeth and divided it up I could determine how many teeth it's actually off, but I figured the fine adjustment can be done at the tie rods.
I messed around with the toe plates yesterday, pretty easy to use although I was a little rushed because it was supposed to storm. I think it have it driveable now. I'll revisit them today (as long as it's not raining ). I also need to get the subframe girdle back on before I take it out.
I'll probably also set up some strings as well to determine individual wheel toe as a sanity check. Been watching some videos on it this morning and it seems fairly straight forward if you take the time to set it up the right way.
Ive installed racks before and this was exactly what I was looking for when I started. The rack comes turned one direction. I couldnt find a center detent or anything. I actually just rotated it and counted the turns to get it as close as I could but after install I was off about 1/4 turn.
Anyway great mod and great thread, and yes I did read it all. Notice I didn't have any questions
gregnauman is offline
Likes 3 Dislikes 0
Old 10-20-19, 09:49 AM   #995
gregnauman
I just last week upgraded my 2013 STI to the new 2015 rack.....
Before we installed we tried to find the center of the rack and it was difficult because there is no "detent" like other racks I have done. It comes shipped in the box all the way one direction.
So we centered it as best we could, installed the rack and when I first turned it on I of course got the dash lights.
When driving straight it was maybe 1/4 turn off.
So I took it to my buddies shop put it on an alignment rack straightened the wheels up and then disconnected the steering coupler and straightened the steering wheel.
He then completed the alignment.
After the alignment or at the end of the alignment their alignment machine has you plug into the OBDII port and zero the sensor which it did just fine and the lights went out.
After driving it a few days I too hit a couple 90 degree turns at about 35-40 with throttle lifted and the outside wheel would brake.
Still no check lights.
I did the headlight switch trip reset sequence to get the codes and I have a C0071 in ABS/VDC memory.
I am going to take it to the dealer and see if they can clear it and then do what you reported by having them recalibrate with the Subaru Select Monitor.
Maybe just zeroing it at the alignment shop doesn't quite reset it or calibrate it fully.
I will report back.
Also the Factory Service Manual tells you to remove the steering wheel and adjust roll center after installing the rack......
15) Lower the vehicle.
16) Remove the steering wheel. <Ref. to PS-13, REMOVAL, Steering Wheel.>
17) Align the center position of the roll connector. <Ref. to AB-28, ADJUSTMENT, Roll Connector.> 18) Install the steering wheel. <Ref. to PS-13, IN- STALLATION, Steering Wheel.>
19) Connect the battery ground terminal.
20) Pour fluid into the oil tank, and bleed air. <Ref. to PS-51, Power Steering Fluid.>
21) Check for fluid leaks.
22) Check the fluid level in oil tank.
CAUTION:
• Do not rotate the roll connector to more than the specified number of turns. Otherwise, the roll connector internal wire may be broken.
• When determining the end stop, rotate the connector slowly without applying excessive force. Applying excessive force at the end stop may break the internal wire.
1) Check that front wheels are positioned in straight ahead direction.
2) Turn the roll connector pin (A) clockwise until it stops.
3) Turn the roll connector pins (A) approx. 3.25 turns in the counterclockwise direction until “^ ” marks are aligned.
Likes 1 Dislikes 0
Old 10-20-19, 09:51 AM   #996
gregnauman
Also this from another thread from a Subaru Mechanic I think.....
"I got a car in yesterday with the described error lights. Scanner pulled a c0071. Data link showed 0° in all positions so I replaced the SAS. Lights went away and sensor was reading correctly. However, when turned all the way right, lights came back. Rechecked installation, reinitialized the zero angle and yaw. Same errors when turned all the way right. Data link showed a 110° deference between lock right and lock left. Installed another sensor and found same readings. Just before i pulled ALL my hair out I raised the vehicle and found the rack and pinion to have been centered incorrectly.
So... My advice and an easy way to check this is center your steering wheel. Verify the wheels are straight at the 0° mark, then turn the wheel all the way left counting the rotations. Center again and go right. Are they the same number of rotations from center to lock both ways? If not check your rack for proper centering (count the visible threads on both ends)
Hopefully this will help at least a few of you"
Likes 2 Dislikes 0
Old Today, 10:04 AM   #997
gregnauman
Well after zeroing out the SAS sensor with the subaru select monitor and not a single code I sill have the issue once in a while.
Im not sure if its the way I am testing it or not.
If I go through a sharp left corner about 35-40 mph with throttle mostly lifted my right front ABS (outside wheel) will kick on. Haven't been able to duplicate it at all with the left front when going into a right turn.
I haven't really felt it on throttle I don't believe....
Other than that it seems to drive fine.
Noximus do you have any input on how you tested yours? I think you spoke about it a bit.
I ordered a VXDiag Subaru Select Monitor which seems to work well from what I have heard. I am going to do so more testing when I get it up and running.
Similar Threads
FS (USA,IL): Sea Sucker Mini Bomber Bicycle Rack (All models / Makes) Robstunner Exterior Parts For Sale 0 07-21-13 06:20 PM
FS (USA,CA): Yakima roof rack (LANDING PADS STYLE) + 2 bike racks esker Exterior Parts For Sale 2 01-17-13 08:15 AM
FS (USA,VT): 2000 Subaru Impreza 2.5RS Full STI Swap RSTI vt4cam Used STIs For Sale 4 04-24-12 12:46 PM
Suspension/Stiffening 05+ STi Spec C rack ends CPC GD-General 0 08-14-10 02:27 AM
