GR Hatch: IAG Built| HTA86| >500whp| Daily driven for 155,000 miles - Page 270 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > GR Hatch: IAG Built| HTA86| >500whp| Daily driven for 155,000 miles
Old 07-29-17, 06:35 PM   #2691
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber
Default Re: IAG Built| HTA86| >500whp| Daily driven for 135,000 miles
Sorry I wasn't clear, Thanks.
mheyman is offline
Old 07-31-17, 08:52 AM   #2692
Delphi
Advanced Contributor Level 1
Fav Mod: 6 Speed
Delphi will become famous soon enough
Originally Posted by user1029 View Post
I would consider swaintech but I'm still adamantly against wrapping. I firmly believe I wouldn't have gotten 8 years out of these headers with wrapping since it just traps moisture and dirt. I've seen wrapped KillerB headers fail so the lower quality steel on these Tomeis would last even a shorter period of time. Changing out headers on this vband kit was a pain in the ass because the new vband had to be welded on in the exact configuration and orientation for it connect perfectly to the uppipe.
Don't forget that the Tomei's run a different design than KB though. Having that slip joint in both the GT spec and Tomei's allow for expansion and movement. This helps prevent cracking a lot.
Also the Tomei's in my opinion are 1 notch above the GT Spec in quality because the Merges and Collector are cast parts not tube to tube.
Delphi is offline
Likes 3 Dislikes 0
Old 08-14-17, 08:33 AM   #2693
mheyman
I would have thought that clamping the them enough so they do not leak makes them immovable and exactly like one piece in terms of expansion - except with added stress points.
It's possible "adjusting them to fit reduces stress, but I have suspect the KB would come out on top due to being built more accurately everywhere to start with.
mheyman is offline
Likes 1 Dislikes 0
Old 08-15-17, 08:49 AM   #2694
Delphi
Fav Mod: 6 Speed
KB headers merge collector is highly stressed under extreme conditions. The 4-1 merge collector while being the best design experiences some extreme forces. They all seem to crack in the same area with both Cast collector and the fabricated collect, albeit the fabricated is more likely to crack.
KB has the best design on the market, but with it comes some strength draw backs, which is made up with 321 stainless. The merge is not braced between the pipes, couple this with thermal expansion of the block and the headers and everything else it is likely the headers are experiencing a force pulling them apart between flanges. Add in engine vibrations and 1600°F heat it really goes through the ringer.
Having the slip joints allows for movement, even though they are "clamped in place" it will still shift. That friction fit with the tiny little machine screws holding it will move before the steel gives more than likely. Obviously they will still eventually fail as seen above but it is pretty obvious it was fatigue.
Delphi is offline
Old 09-02-17, 07:28 AM   #2695
user1029
Advanced Mastery Level V
Feedback Score: 5 reviews
Fav Mod: HTA86.
user1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud of
Nothing to update, had uppipe welded due to a crack but car still running great
user1029 is offline
Likes 6 Dislikes 0
Old 11-19-17, 01:48 PM   #2696
ShinjiML
Advanced Mastery Level I
Car: 2011 STI DGM
Fav Mod: Spoolinator; Back-up Camera; ShinjiTuned
ShinjiML has a spectacular aura aboutShinjiML has a spectacular aura aboutShinjiML has a spectacular aura about
Default Re: IAG Built| HTA86| >500whp| Daily driven for 140,000 miles
User, what kind of inline filter do you run?
ShinjiML is offline
Old 11-19-17, 02:29 PM   #2697
user1029
Fav Mod: HTA86.
Fragola Performance Systems Inline Fuel Filters 960002-BL - Free Shipping on Orders Over $99 at Summit Racing
user1029 is offline
Likes 1 Dislikes 0
Old 11-19-17, 07:07 PM   #2698
mheyman
KB headers merge collector is highly stressed under extreme conditions. . . . The merge is not braced between the pipes, couple this with thermal expansion of the block and the headers and everything else it is likely the headers are experiencing a force pulling them apart between flanges. Add in engine vibrations and 1600°F heat it really goes through the ringer.
All that and I mostly agree
I not convinced bracing the merge in any practical way would help much.
or that that slip joints slip. If they did they would wear, slip more, leak and fail prematurely - wait some do that!!! So, the ones that don't were are either either a better design and/or tighter tolerances, or they were installed and tightened properly or some combination.
mheyman is offline
Old 11-25-17, 05:52 AM   #2699
user1029
Fav Mod: HTA86.
user1029 is offline
Likes 7 Dislikes 0
Old 11-25-17, 11:18 AM   #2700
TBAG
Advanced Mastery Level II
Car: WRB Bugeye STI
TBAG has much to be proud ofTBAG has much to be proud ofTBAG has much to be proud ofTBAG has much to be proud ofTBAG has much to be proud ofTBAG has much to be proud ofTBAG has much to be proud ofTBAG has much to be proud ofTBAG has much to be proud ofTBAG has much to be proud of
Not bad... not bad at all.
TBAG is offline
Likes 1 Dislikes 0
Similar Threads
2016 Hyperblue IAG Built | Daily Driven | 530whp/508wtq ///V3Dude 2015+ Member Journals 53 08-30-18 12:54 AM
FS (USA,MD): FS/FT: (MD) $25,250 - 2011 Limited STi w/ 65k+ miles (Daily Driven) - Basic Stage 2 G(SP)T Used STIs For Sale 18 08-22-15 02:57 AM
[2008 STi] 550whp daily driven, HTA86, IAG Built user1029 Power Bragging 14 04-20-15 09:54 AM
(OT) 2009 Iron Butt Rally Underway Bownse Off Topic 40 10-07-09 09:03 AM
