GR Hatch: IAG Built| HTA86| >500whp| Daily driven for 155,000 miles - Page 11 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > GR Hatch: IAG Built| HTA86| >500whp| Daily driven for 155,000 miles
Old 03-22-10, 10:58 AM   #101
user1029
Advanced Mastery Level V
Feedback Score: 5 reviews
Fav Mod: HTA86.
user1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud of
Default Re: 2008 WRB STi IAG 35R... RCE Sway bars!
Just got a chance to pick up a set of 22mm front and rear RCE sway bars today Very beautifully constructed and the thick end collars is a big reason why I picked RCE over Whiteline.
RCE collars vs. Whiteline collars
user1029 is offline
Old 03-22-10, 08:07 PM   #102
user1029
Fav Mod: HTA86.
Default Re: 2008 World Rally Blue STi...IAG V-band 35R 416whp/366wtq @3700 rpm tuned by Jorge
Originally Posted by LittleBlueGT View Post
Sweet.
Could you do the following?
Log:
-rpm
-MRP
-MAF g/s
-total timing
That is all, then do a WOT log from:
-2000-7000rpm in 2nd
-2000-7000rpm in 3rd gear
-4th from 2000-4000 rpm or as high as you feel is safe.
If you do the above I will give you all sorts of nice charts and stuff.
I am so excited about you doing the above.
2nd gear and 3rd gear from 2000rpms
EDIT: This was in Sport mode that was only running the 18psi map; not Sport# mode which is 23psi map.
EDIT: This was datalogged in Sport mode that was only running the 18psi map; not Sport# mode which is 23psi map.
user1029 is offline
Old 03-22-10, 09:02 PM   #103
LittleBlueGT
Feedback Score: 1 reviews
Car: 13 STI
Fav Mod: Numerous alignments
LittleBlueGT will become famous soon enough
Good, actually looks nice.
Do a 3rd gear (and 4th gear if possible and safe) from 2000 -7000 rpm, your above 3rd gear log starts at 3400 rpm, not 2000.
Then see if you can attach the logs so we can actually open them up ourselves in excell.
Or e-mail to me. Once I have those logs in my hands I will make pretty graphs.
All non TS-turbos should be banned.
LittleBlueGT is offline
Old 03-22-10, 09:24 PM   #104
user1029
Fav Mod: HTA86.
3rd gear pull starts at row 18
user1029 is offline
Old 03-23-10, 07:45 AM   #105
LittleBlueGT
Car: 13 STI
I see now.
Old 03-23-10, 03:27 PM   #106
LittleBlueGT
Car: 13 STI
Default Re: 2008 WRB STi IAG 35R... RCE Sway Bars!
This is assuming a lot of things:
-tire size is 245/40/18 (best to actually measure with a tape measure)
-car weighs about normal, you have 200 lbs of stuff in it including yourself
-full of gas (curb weight assumes full)
Send me the above info and I can make better graphs.
Also, log less stuff:
-don't log load (we can figure that out)
-don't log DAM (just check before and after a run)
-don't log learned ignition timing (unless you know the table, it doesn't really help)
-don't log AFR (front O2 is useless on WOT runs anyways)
-don't log MAF volts, just g/s
-don't log fuel trims, or vehicle speed
-do log fine learning (called something like that in AP)
less stuff logged = greater resolution
3rd gear WHP:
3rd gear plot:
Kinda looks like there is a small amount of fine learning.
2nd gear plot:
I will try and get a 2nd gear whp plot, but I don't know off hand the gear ratio of 2nd.
Don't take the whp chart as accurate, just the best I could do with the info at hand. In fact maybe the wind was in your face, maybe you were going downhill. IDK. Listen to my above suggestions and I will get you better charts next time.
Stand-by for my thoughts.
Old 03-23-10, 03:56 PM   #107
LittleBlueGT
Car: 13 STI
2nd gear whp:
I don't know what to say, other then there is a ton whp on the table. I think spool looks pretty damn good.
I look forward to the next logs, and better info for me to make my spreadsheet more accurate.
Old 03-23-10, 04:13 PM   #108
user1029
Fav Mod: HTA86.
thanks for the graphs
I have 265/35/18 tires, full weight, half a tank of gas
user1029 is offline
Old 03-23-10, 04:18 PM   #109
LittleBlueGT
Car: 13 STI
So then you will have to take a few WHP away, as those tires are a bit smaller then the size I uses, and I used full weight.
Best is to weigh your car and measure tires.
Old 08-14-10, 06:24 PM   #110
user1029
Fav Mod: HTA86.
haven't updated forever Car just hit 10,000 miles with the 35r and still going strong! New pic for prosperity's sake
user1029 is offline
Similar Threads
2016 Hyperblue IAG Built | Daily Driven | 530whp/508wtq ///V3Dude 2015+ Member Journals 53 08-30-18 12:54 AM
FS (USA,MD): FS/FT: (MD) $25,250 - 2011 Limited STi w/ 65k+ miles (Daily Driven) - Basic Stage 2 G(SP)T Used STIs For Sale 18 08-22-15 02:57 AM
[2008 STi] 550whp daily driven, HTA86, IAG Built user1029 Power Bragging 14 04-20-15 09:54 AM
(OT) 2009 Iron Butt Rally Underway Bownse Off Topic 40 10-07-09 09:03 AM
