Anyone find the rear view mirror sits too low? - Page 4 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > > Anyone find the rear view mirror sits too low?
Old 06-12-09, 08:40 PM   #31
farmboy
Advanced Mastery Level I
Feedback Score: 1 reviews
Car: SSM 08 STi
Fav Mod: JDM Ash Tray
farmboy is an unknown quantity at this point
Default Re: Anyone find the rear view mirror sits too low?
I have actually considered buying a new windshield so I can have the installer glue the mount higher up. That's how much it bothers me.
farmboy is offline
Old 09-15-09, 10:30 PM   #32
czecho
Advanced Mastery Level II
Feedback Score: 6 reviews
Car: Dark Gray 2009 sti
czecho is an unknown quantity at this point
I have the homelink rear view mirror and was wondering where the 2 joint things are to raise it, unless those are on the regular rear view.
czecho is offline
Old 03-13-11, 09:14 PM   #33
milkplus71
Becoming A Contributor
milkplus71 is an unknown quantity at this point
Anyone move their homelink mirror? Just bought a 2011 and the mirror is way too low. Can I just heat it and re-stick? Also wondering if I can attach it toward the top of the windshield since there is like a sunshield as you get toward the top. Any help would be great thanks
milkplus71 is offline
Old 03-16-11, 03:59 PM   #34
geddesk2
Car: 2006 STI WRB
Fav Mod: None yet!
geddesk2 is an unknown quantity at this point
My home link mirror was set to the lowest point when installed.
The mirror tilts...and the arm of the mirror also tilts/pivots from where it is attached to the windshield mount.
You just need to pivot that arm up and then adjust the tilt of the mirror down.
Not sure if the same goes for the standard mirror.
geddesk2 is offline
Old 03-16-11, 04:20 PM   #35
farmboy
Car: SSM 08 STi
I have the homelink and even doing what you suggested the mirror sits too low on the windshield. I am 6'2" and going around sharp fast corners I have to duck my head to see ahead of me because of how low the mirror sits.
farmboy is offline
Old 03-16-11, 06:19 PM   #36
austinpike
Feedback Score: 11 reviews
Car: 2o11 dgm wrx
austinpike is an unknown quantity at this point
My homelink mirror was loose and rattling... In the process of tightening it I realized you can easily rotate the whole thing 180 so it sits upside down - the way the joint is offset it ends up raising it an extra inch or so. Looks stupid and it confuses the compass, but it helps visibility.
austinpike is offline
Old 03-16-11, 06:48 PM   #37
czecho
there has to be a way to machine a new bracket that is longer, hmmmm
czecho is offline
Old 03-16-11, 11:27 PM   #38
damianblalack
Advanced Contributor Level 1
Feedback Score: 4 reviews
Car: 09 LR STi
Fav Mod: Recaro Young Sport
damianblalack is on a distinguished road
This has bothered me for a couple years too, so I decided to take it apart and see if I could figure something out. I have the homelink and what I ended up doing wastaking the mounting tab for the mirror and mounted it using the top hole on the base and the bottom hole on the tab. I then drilled a new hole in the base to screw into the top hole of the tab. It ended up moving the tab up 1/2 an inch or so. There is now no gap between the top of the mirror and the dot matrix sunshade. It was easy to do and worth the few minutes it, but I do wish it was even higher. I'm only 5'9 and still feel like I have to look under the mirror making right handers. I wish there was a way to extend the arm. Unfortunately there is a black spot on the windsheild where base is glued to so I don't think removing and regluing it is a worthwild solution, it would probably work but you see the back side of the mounting braket through the glass and have that black spot too.
damianblalack is offline
Old 11-07-18, 02:51 AM   #39
Judyw
Joined the Conversation
Judyw is an unknown quantity at this point
Originally Posted by FLoP View Post
Is the mount type the same with the regular mirror as it is on the homelink/autodimming one?
you may need a backup camera to reduce blind spot.
Judyw is offline
Old 12-01-18, 02:15 PM   #40
woweriux
woweriux is an unknown quantity at this point
Any aftermarket mirrors that sit higher?
woweriux is offline
