custom oil cooler bracket installed - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > custom oil cooler bracket installed
Old 07-06-19, 10:00 AM   #11
Got2Boostit2
Moderator Elite
Feedback Score: 18 reviews
Fav Mod: Hands down - Q Rack FTMFW Boy eee
Got2Boostit2 is a name known to allGot2Boostit2 is a name known to allGot2Boostit2 is a name known to allGot2Boostit2 is a name known to allGot2Boostit2 is a name known to allGot2Boostit2 is a name known to all
Default Re: custom oil cooler bracket installed
Originally Posted by dlheman View Post
At least now we know there is no difference between reading at oil pan or at oil sandwich filter.
Afterall Subaru Japan did offer oil tempt sensor kit and that too is installed on the provided oil sandwich plate.
In my mind I’ve believed this from the beginning. Ok if I share your post on the Book of Faces?
If it's not Boosted, what's the point?
Serving you as a moderator since Jan 2011
"Lucille" is Sponsored by: Butler's Garage
Protune video
https://youtu.be/Xyx6G1yXqKc
If you have issues with moderation or other members, report the post or use the Private Support Forum to discuss. Located => https://www.iwsti.com/forums/private-support-forum/
Got2Boostit2 is offline
Old 07-06-19, 03:21 PM   #12
dlheman
Advanced Contributor Level 5
Feedback Score: 1 reviews
Car: 2011 WRX STI UK-Type
Fav Mod: Those STI flexible parts and IHI VF56
dlheman will become famous soon enough
Sure, no problem.
dlheman is offline
Old 07-06-19, 05:58 PM   #13
dlheman
And so I just took the car for a good exercise in the name of science.
Ambient tempt 29 Deg C:
1. Steady state fast cruise can result in oil tempt dipping to 190 Deg f
2. Race the car with acceleration, deceleration, braking and gear shifting the oil tempt stays steady between 200 to 205 deg F.
3. Single pull to 140mph+, oil tempt steady between 200 to 205 Deg F.
4. Normal drive around town, oil tempt betwee 200 to 205 Deg F.
So that is a significant reduction of oil tempt vs not using oil cooler, but not much to be below 200 Deg F. I don’t think I need to cut open the upper grill duct to try to get more air into the pil cooler.
And as previously mentioned the coolant tempt is as good as ever. I didn’t get to see what the coolant tempt was when racing the engine, but during the single pull to 140mph it was at 83 Deg C (note: I also have Dom’s 4th cylinder coolant mod and still on oem radiator).
So after the test I went to get coffee for the morning and I let the car idle with air con on, to see what the oil tempt is like. It gradually decreasing from 205 Deg f all the way to 179 Deg F before settling at around 182 Deg F.
And that concludes this oil cooler project.
Time to go back to race circuit!
dlheman is offline
Likes 1 Dislikes 0
Old 07-07-19, 06:58 PM   #14
dlheman
After going through traffic and arriving at shopping mall.
Without oil cooler that fluid temperature (oil tempt) would read 220 deg F.
dlheman is offline
Likes 2 Dislikes 0
Old 07-09-19, 07:39 PM   #15
itsm3ming
Developing Advanced Mastery
Feedback Score: 4 reviews
Car: Launch | STI
itsm3ming will become famous soon enough
Sweet gauges and diag.
I was always curious about the temp difference between a cooler or not and averaging low 200s vs 220-240 i bet thatll help during track daze.
itsm3ming is offline
Likes 1 Dislikes 0
Old 07-09-19, 09:32 PM   #16
dlheman
Absolutely. The oil cooler helps because prior to converting to R205 Spec C twinscroll turbo I went for a couple of track day with oil cooler installed. The Subaru service guys didn’t believe me that I did track day because others who went without oil cooler always struggled with overheating while I don’t. The engine didn’t even lose oil or coolant and it went for many2 laps until my AD08R and brakes are gone. If I remembered correctly at that time the oil tempt stayed steady at 220 Deg F During track day.
dlheman is offline
Old 07-12-19, 03:00 AM   #17
dlheman
So a friend bought Mishimoto oil cooler kit; and it don't fit UK model STI due to couple of reasons; the front bumper beam is much deeper towards the air conditioner radiator and there is a thick front lower plastic guard.
But is a good thing as low mounting location is a bad idea in my opinion.
Since the Mishimoto oil cooler is thicker the upper grill duct piece is preventing it from center mount position.
And it is mounted at a slight angle due to clearance (can only be seen if viewed from the top). Which is ok.
That protection sleeve uses sticker to wrap it together, but since I don't trust it a zip tie is recommended.
But there are more problems when installing the sandwich adapter. Due to the shape of the sandwich plate, the OEM water cooled oil cooler adapter pipe will hit the sandwich plate. Thankfully the kit includes another spacer plate adapter which provides the much needed clearance (supposedly to be used when installing on WRX...).
Start the engine, and moments later a leak was detected coming out from spacer plate sensor port. Bastards...
Well by the end of the day the kit is successfully installed - but knowing this the owner would have just piece together a better kit (Setrab core, Mocal plate etc). I also think the rubber gasket on the mishimoto sandwich plate may not be reliable.
dlheman is offline
Old 07-20-19, 09:43 AM   #18
dlheman
Just a little update.
driving on hwy, nothing crazy just easy cruise 62mph - 80mph and the oil tempt went below 176 Deg F and the coolant went down below 80 Deg C. Not sure how far it went down to as I only saw both my gauges flashes its warning light (indicating it went below the set target). The ambient tempt was 27 Deg C.
Looks like the oil cooler is more effective that I thought.
dlheman is offline
Likes 1 Dislikes 0
Similar Threads
Engine What Oil will you use? APEXIT53 2015+ STI Discussion 893 10-20-18 06:35 AM
Installs, Service, Maintanance, Repairs, Custom work, Tuning, Dyno Database! Infamous Performance Services 939 08-30-17 05:48 PM
Engine Oil Change 04 STi ytsohptwhere DIY Mods & Installations 74 02-25-12 02:16 PM
The Japtrix Performance Service & Parts Special Thread! Serving the South East Region Japtrix Services 5 09-20-09 01:42 PM
The Japtrix Performance Service & Parts Special for 2008+ Subarus Japtrix Vendor Announcements & Project Buildups 4 03-24-09 09:16 AM
