GR - Transmission Issue 4th Gear - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > GR - Transmission Issue 4th Gear
Old 07-11-18, 08:29 AM   #11
Leo843
Becoming A Contributor
Car: Black 13 WRX STI
Leo843 is an unknown quantity at this point
Default Re: GR - Transmission Issue 4th Gear
Originally Posted by hanzda View Post
At that mileage it wouldn't hurt to do a clutch job.
Sent from my LG-LS993 using Tapatalk
Got you! I didn't know what's the average clutch life. Granted it all depends on how you drive it, right?
Leo843 is offline
Old 07-11-18, 08:39 AM   #12
hanzda
Advanced Contributor Level 2
Car: ISM 2012 sti hb
Fav Mod: SI TO STI UPGRADE
hanzda is on a distinguished road
2012 71K stock no issues but I barely launch the car,Im about to try CC stage 2 before E85 tune soon.I did a clutch for a friend 13 at 45K and that won't even go p ast 2500 rpm.
hanzda is offline
Old 07-11-18, 10:14 AM   #13
Leo843
Thank you hanzda! I think I'm going to change the clutch myself first and go from there. If the issue still there, then I'll look into a tranny rebuild.
Quick question for you, do I need to replace the clutch slave cylinder as well?
Leo843 is offline
Old 07-11-18, 10:21 AM   #14
hanzda
Optional depending on funds,always replace flywheel unless your on a budget.
hanzda is offline
Old 07-11-18, 10:53 AM   #15
Leo843
Got you! I saw an Exedy Clutch OE + flywheel for $434 on ebay. That's the cheapest I could find with out going XTD, XTR, or any other ebay knock off brands for less than $200.
Leo843 is offline
Old 07-11-18, 11:02 AM   #16
Leemanfor
Developing Advanced Mastery
Fav Mod: EFR 7163 Turbo
Leemanfor has a spectacular aura aboutLeemanfor has a spectacular aura aboutLeemanfor has a spectacular aura about
I had bad grinding going from 3rd to 4th when trying to shift fast. I put motul gear oil in and its been fixed since. I had tried Amsoil gear oil but I believe I had the wrong stuff. the normal Amsoil gear is GL4 where as severe gear is GL5.
i was quoted between 1500-2500 for rebuild depending on what you want done
Leemanfor is offline
Old 07-11-18, 06:04 PM   #17
bayswagger
Contributor
Car: 17 STi / 05 STi
bayswagger is an unknown quantity at this point
Thank you! I saw a post on NASIOC where a guy use a 50/50 mixed of 75w-90 and Redline lightweight shockproof. Does 50/50 mix sound about right for you?
I haven't read the thread and I am not sure the reasoning for mixing it. I've only run 100% shockproof, but I have no doubt that other oils or blends recommended would help.
So.... what if it is the clutch going bad? Is there anyway I could troubleshoot that? I'm just asking because on my way home from work yesterday and on my way in from home today it didn't happen at all.
I mean, could the reason be that my clutch is wearing out and the clutch engagement point I was used to is now different?
If the grinding was in fact the issue, shouldn't it happen every time I change from 3rd to 4th?
Please forgive my ignorance and the many questions.
If the clutch is going bad it will slip. No need to replace the clutch unless it is slipping or you're adding more torque than what your current clutch can handle. You wont necessarily get the scraping noise every time unless it's really bad.
bayswagger is offline
Old 07-12-18, 12:23 PM   #18
CTSparky
Becoming A Master Contributor
Feedback Score: 2 reviews
Fav Mod: SS lines and master cyl brace
CTSparky is on a distinguished road
I'm having this problem now and aside from the synchro it could be the shift fork guides going as well.
Sent from my SM-G955U using Tapatalk
CTSparky is offline
Old 07-12-18, 08:16 PM   #19
Leo843
Wow! I'll check the oil I used again to make sure but I don't recall seeing GL4 or GL5 lettering in there.
Leo843 is offline
Old 07-12-18, 08:25 PM   #20
Leo843
I heard about redline shockproof, expensive stuff. Is there a special weight you get or is there just one type?
There is no slipping. I tried to recreate the grinding noise and found out that it only happen at high RPM. Under normal driving conditions, there is no grinding. Does that sound about right?
Leo843 is offline
Similar Threads
GR Hatch: BJJMark95's 2013 DGM STi - The "Sleeper" - Car Sold and Gone BJJMark95 GR-Members' Journals 459 05-23-17 05:18 AM
2012 STI Transmission / Clutch Weird Issue AudioGuy2013 Drivetrain Components 12 08-15-13 01:23 PM
Subaru Impreza - Won't go into gear!!!! Gear box issue! subaru1991 Warranty / Service Issues 2 06-12-13 06:12 PM
Clutch Problem/NOW STUCK IN 4th GEAR tyboe Drivetrain Components 9 04-04-10 06:43 PM
Mystery transmission issue Pkskull77 GR-General 11 05-16-09 01:35 PM
