Rank Them: Top 5 WORST installs - Page 4 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Rank Them: Top 5 WORST installs
Old 10-01-16, 07:45 AM   #31
STIGR-Wagon-Dad
Master Contributor Level 1
Feedback Score: 1 reviews
Car: DGM 08 WRX STI Zenki
Fav Mod: RalliTek sway bars+ Kartboy endlinks, Synapse Engineering Diverter valve
STIGR-Wagon-Dad has a spectacular aura aboutSTIGR-Wagon-Dad has a spectacular aura about
Default Re: Rank Them: Top 5 WORST installs
For me it was the Grimmspeed MCB and the stock fuel injector guards. Both were never installed/reinstalled. I gave up due to it taking longer than I was willing to work on it. The fuel injectors were the easy part, the guards, not so much.
STIGR-Wagon-Dad is offline
Old 10-06-16, 12:33 PM   #32
KManZ
Advanced Mastery Level I
Feedback Score: 4 reviews
KManZ will become famous soon enoughKManZ will become famous soon enough
I forgot I had started this thread, and now I have to update it with the spark plugs... driver side rear, shit's no joke. Toss-up etween this and the MCB.
I retired from DIY, and modding. Thank god.
KManZ is offline
Old 01-05-17, 10:56 AM   #33
mxer
Car: 08 REAL WHITE
Fav Mod: Rock chips and hood dent
mxer is on a distinguished road
Shifter bushings were annoying but even more annoying was taking them back out since I couldn't stand the added noise!
mxer is offline
Old 10-16-18, 07:29 AM   #34
DocBlackAdder
Fav Mod: NOT E.T.Tuning in Union,MO
DocBlackAdder is on a distinguished road
Soundproofing.
Any job that requires removing the interior trim from the driver's seat rearward. Why in the HELL do they have about 6 different sizes of clips to hold the interior trim panels on, yet all are designed to shatter if you have to take something loose!?
The report notes the driver was "alert and conscious" after the wreck. Too bad he wasn't before the impact.
DocBlackAdder is offline
Old 10-16-18, 07:49 AM   #35
Leemanfor
Master Contributor Level 2
Fav Mod: EFR 7163 Turbo
Leemanfor has a spectacular aura aboutLeemanfor has a spectacular aura about
1. IAG AOS with TMIC.
2. Group N engine mounts
Leemanfor is offline
Old 10-16-18, 04:01 PM   #36
hanzda
Advanced Contributor Level 2
Car: ISM 2012 sti hb
Fav Mod: SI TO STI UPGRADE
hanzda is on a distinguished road
1.Removing the stock fuel rails for upgrading the injectors is definitely a lot of work. while the intake manifold was out upgraded to a tomei silicone turbo inlet so i cant vouch for the degree of difficulty,even though that all stock fuel lines and other parts are out the GS mcb is still difficult so I can imagine if everything is still there that it would be a PITA.
hanzda is offline
Old 10-20-18, 10:17 AM   #37
NastyLuv
Car: OBP 2010 GR STI SE
Fav Mod: OEM Rubber Floormats
NastyLuv is an unknown quantity at this point
+1 for the brake caliper bolts. I've had enough of that mess. I just ordered a timesert kit and will be fixing my front calipers soon.
You guys are scaring me though, as I have a lot of these PITA mods sitting in my living room and plan to hit them hard all at once. Shifter bushings, All Group N mounts, Crossmember bushings, subframe busings, rear diff inserts, the entire power steering system including the rack, and to top it off an IAG AOS.
I found the spark plugs easy the second time. The first time sucked. I learned to remove everything I can within reason first, and to rotate the coilpack clockwise or it will drive you crazy. Also use a short piece of fuel hose to slip new plug in and get the threads started.
NastyLuv is offline
Old 10-21-18, 05:08 PM   #38
mheyman
Fav Mod: Camber Camber Camber
I'm dammed happy with 2015 post. It's holding up well.
Writing now to say that rear wheel bearings kind of suck too. Not #1, but not so fun either.
mheyman is offline
Old 11-02-18, 06:25 AM   #39
murfnamedsmurf
Car: 2012 DGM STI 5 door
Fav Mod: No car payment
murfnamedsmurf has a spectacular aura aboutmurfnamedsmurf has a spectacular aura aboutmurfnamedsmurf has a spectacular aura about
I'll just say any AOS, but for me it's the Crawford. I only had one mounting bolt since my TGV deletes don't have mount holes for the injector protector bastard rails, but just that one bolt was enough to piss me off. The hoses weren't much better.
I'll second what another user mentioned and say some of these jobs make me debate giving up DIY except for simple jobs When it comes to the big jobs in particular, when the job spans 12+ hours then eventually I could've come out even if I'd just done an extra shift at my actual job and let a professional handle my car. The difference is I don't get to hang out with my dog or be outdoors at work, plus I like learning other things while I'm in there working on something.
I thought the TGVs were going to be the worst part of this set of jobs, but I'm going to vote for the AOS.
I want to do mounts soon but I had a hard time getting the stock mounts lined back up when I did my killer B oil pickup, so I'm not really looking forward to raising the engine again.
murfnamedsmurf is offline
Old 11-02-18, 08:19 AM   #40
uschearak
Car: Silver 15' STI base
Fav Mod: IWSTI Knowledge
uschearak has a spectacular aura aboutuschearak has a spectacular aura aboutuschearak has a spectacular aura about
forged pistons duh
The Best Motors Are Raced and Built HERE
uschearak is offline
Similar Threads
New Designed Mishimoto Top Mount Intercoolers for the 04-07 WRX/STI!! RallySportDirect GD-Vendor Classified Ads 4 07-22-14 07:04 AM
Top Gear Season 19 EvoX_to_STi Video Collection 19 03-11-13 04:26 PM
Top 5 and Worst 5 thing about GR STI ariolz GR-General 68 12-04-09 04:26 AM
Suspension/Stiffening For those of you with Group N Top Hats T1mmmy GD-General 27 02-22-06 01:05 PM
