GR: Engine and Drivetrain: Tomioka, COBB, Mishimoto, Subaru OEM, Invidia & MORE!! ♣♠♣
99% of the orders placed before Noon Eastern Time, Mon-Fri are shipped the same day!!
You can trust our experienced, friendly staff and large warehouse to help you reach all of your performance goals!!
Engine Parts By Brand
TOMIOKA
Subaru OEM
Invidia
Walbro
Company23
Injector Dynamics
NGK Iridium Spark Plugs
DENSO Iridium Spark Plugs
Koyo
COBB Tuning
Killer B
GrimmSpeed
GrimmSpeed Gaskets!!
STi
Blouch
Perrin
Mishimoto
TOMIOKA
- Tomioka Racing TD05-16G Turbo, '04-'14 STi
- Tomioka Racing TD05-18G Turbo, '04-'14 STi
- Tomioka Racing TD05-20G Turbo, '04-'14 STi
- Tomioka Racing TD06-20G Turbo (3" Inlet), '04-'14 STi
- Tomioka Racing Unequal Length Exhaust Manifold (Single Scroll), STi
- Tomioka Racing Equal Length Exhaust Manifold (Single Scroll), STi
- Tomioka Racing Single Tip Cat-Back, 08+ STi
- Tomioka Racing Billet Aluminum Timing Belt Guide, EJ25
- Tomioka Racing Air & Oil Separator Kit, '04-'14 STi
- Tomioka Racing Air Pump Delete Kit, 2006+ STi
- Tomioka Racing Engine & Transmission Mount Kit, WRX & STi (All)
- Tomioka Racing Oil Cooler Kit, 2008+ STi
- Tomioka Racing Fuel Rail Kit, '07-'14 STi
- Tomioka Racing Downpipe (w/ High-Flow Cat), 2008+ STi
- Tomioka Racing Downpipe (No Cat), 2008+ STi
- Tomioka Racing TD06-20G Turbo Kit (Twin Scroll), '08-'14 STI (Hatchback)
- Tomioka Racing Turbo Inlet Hose (Blue), '08-'14 STi
- Tomioka Racing Turbo Inlet Hose (Black), '08-'14 STi
- Tomioka Racing Turbo Inlet Hose (Red), '08-'14 STi
- Tomioka Racing Lightweight Aluminum Crank Pulley, '04-'14 STi
Subaru OEM
- Subaru (OEM) Oil Filter, '02-'14 WRX & '04-'14 STi
- Subaru (OEM) Oil Pan Crush Washer (5 pack), WRX & STI
- Subaru (OEM) Oil Cooler O-Ring
- Subaru (OEM) Thermostat
- Subaru (OEM) Thermostat Gasket, Impreza (All)
- SPT Turbo Heat Shield, '08-'10 WRX & STI, '05-'09 Legacy GT
- STi "Group N" Heavy Duty Engine Mounts (Pair), WRX & STi
- STi "Group N" Heavy Duty Transmission Mount, WRX & STi
- STi "Group N" Pitching Stopper, WRX & STi
- STi High Pressure Radiator Cap
- Subaru (OEM) Oil Pump (11mm), '08-'14 STi
- Subaru (OEM) Water Pump, Turbo
- Subaru (OEM) Oil Baffle Plate, '04+ STi
- Subaru (OEM) Oil Pan, '06-'13 STi
- Subaru (OEM) Timing Belt Guide (Crank Pulley)
- Subaru (OEM) Crank Sensor, '04-'14 STi
- Subaru (OEM) Crankshaft EJ257 (Induction Hardened)
- Subaru (OEM) O2 Sensor (Front), '08-'10 STi
- Subaru (OEM) Coil Pack, '04-'12 STi & '08-'11 WRX
- Subaru (OEM) IHI VF48 Turbocharger, '08-'14 STi
- Subaru (OEM) Engine Block Case Bolt (6 Required, Sold Individually), EJ Series Engines
- Subaru (OEM) Engine Block Case Bolt (8 Required, Sold Individually), EJ Series Engines
- Subaru (OEM) Engine Block Case Bolt (2 Required, Sold Individually), EJ Series Engines
- Subaru (OEM) Premixed Long Life "Super Coolant", Subaru Engines
- Subaru (OEM) Engine Block Case Bolt (1 Required, Sold Individually), EJ Series Engines
- Subaru (OEM) Cylinder Head Casting (LH, Bare), '08-'10 STi
- Subaru (OEM) Cylinder Head Casting (RH, Bare), '08-'10 STi
- Subaru (OEM) Threaded Plug for 6-Speed Trans Clutch Rod Hole, Subaru 6MT
- Subaru (OEM) Downpipe To Turbo Exhaust Bolt, Subaru Turbo Models
- Subaru (OEM) Turbo Heatshield Bracket (Upper), '02-'13 WRX & STi w/ Stock Turbo
- Subaru (OEM) Banjo Bolt (Union Screw) Oil Line to Turbo, '02+ WRX & STi
- Subaru (OEM) Timing Belt Front Cover Bolt (Long), '02-'13 WRX & STi
Invidia
- Invidia Cat-Less Divorced Wastegate Down Pipe, '08+ STi
- Invidia Catted Down Pipe w/ Divorced Wastegate, '08+ STi
- Invidia Racing Cat Back Exhaust w/ Ti Tip, 2011+ STi Sedan
- Invidia N1 Cat Back Exhaust w/ Ti Tip, 2011+ STi Sedan
- Invidia Q300 Quad Tip Cat Back Exhaust, '08+ STi (Hatch)
- Invidia Q300 Quad Tip Cat Back Exhaust w/ Ti Tips, '08+ STi (Hatch)
- Invidia Q300 Quad Tip Cat Back Exhaust, '11+ STi (Sedan)
- Invidia Equal Length Race Header, '06+ STi
- Invidia Equal Length Header w/ Integrated Uppipe, '06+ STi
Walbro
- Walbro GSS342 High Flow Fuel Pump (255 L/Hr)
- Walbro 400LPH Drop In Fuel Pump, WRX & STi
- Walbro 400LPH E85 Compatible Fuel Pump, WRX & STi
Company23
- Company23 AVCS Intake Cam Sprocket Tool, '04+ STi
- Company23 Dual AVCS Exhaust Cam Sprocket Tool, '08+ STi
- Company23 Crank Pulley Tool, '93+ Imprezas (All, WRX, STi, Etc)
- Company23 Camlock Tool, '02+ WRX & STi
- Company23 Cam Sprocket Tool, '93-'12 SOHC EJ Engines
- Company23 Top Mount Intercooler Stud Kit, '02+ WRX & STi
- Company23 AVCS Pulley 5-Sided Tool, '04+ STi
- Company23 Valve Spring Compressor Tool, '02+ EJ2x Engines
- Company23 Crankshaft Socket, Subaru EJ Engines
- Company23 Piston Ring Compressor (96.52mm-100.33mm), '04+ STi
- Company23 Fuel Line Disconnect Tool, '05+ Impreza & '13-'14 BRZ
Injector Dynamics
- Injector Dynamics 1000cc Top Feed Injectors, STi
- Injector Dynamics 725cc Top Feed Injectors, STi
- Injector Dynamics 2000cc Top Feed Injectors, STi
- Injector Dynamics "ID850 " 850cc Fuel Injectors PNP, '02-'14 WRX & '07-'14 STi
Koyo
COBB Tuning
- COBB AccessPORT V3, '08-'14 WRX/STi, '07-'13 LGT/FXT, '09-'10 2.5 GT, '07-'09 OXT
- COBB Lightweight Crank Pulley, WRX & STi
- COBB SF Short Ram Intake WRX, STi, FXT
- COBB 3 SS Downpipe w/ Cat, 2008 WRX & STi (MT Only)
- COBB Tuning SS Heat Shield, '02-'07 WRX, '04-'08 FXT & '08+ STi
- COBB "SF" Short Ram Intake (Blue), 2008+ WRX & STi
- COBB "SF" Short Ram Intake (Black), 2008+ WRX & STi
- COBB "SF" Intake & Air Box Combo (Black), '08+ WRX & STi
- COBB "SF" Intake & Air Box Combo (Blue), '08+ WRX & STi
- COBB 3-Port Boost Control Solenoid, '08+ WRX & STi
- COBB Post MAF Hose, '08-'14 WRX & STi
- COBB Cat-Back Exhaust System, Quad Tip, '11-'14 WRX & '11-'14 STi (Sedan)
- COBB Turboback Exhaust System, Quad Tip, '11-'14 WRX & '11-'14 STi (Sedan)
- COBB Top Feed 1000cc Fuel Injectors, '02-'14 WRX & '07-'14 STi
- COBB Replacement Filter Element (For COBB Subaru "SF" Intake), Subaru Intake
- COBB Throttle Body Coupler, '02-'07 WRX & '04-'14 STi
Killer B
- Killer B Ultimate Oil Pickup, WRX & STi
- Killer B Oil Pickup & Baffle Combo, WRX & STi
- Killer B Oil Pan, WRX & STi
- Killer B Oil Pan & Pickup Combo, '02+ Impreza
- Killer B Oil Pan & Baffle Combo, '02+ Impreza
- Killer B Oil Pan, Pickup & Baffle Combo, '02+ Impreza
- Killer B Baffle Windage Tray, WRX & STi
- Killer B Radiator Shroud (Black), '08+ WRX & STi
- Killer B Alternator Shroud (Black), '08+ WRX & STi
- Killer B Shroud Combo (Black), '08+ WRX & STi
- Killer B Holy 4-1 Equal Length 321 S.S. Header, WRX & STi
- Killer B OEM to 1/8" PT Adapter
- Killer B Relocated Oil Fill Tube, '08-'14 WRX & STi - Free Shipping!
- Killer B 1/2"NPT to 1/8" BSPT Adapter
- Killer B Performance Turbo Stud Set (5), '02-'14 WRX & '04-'14 STi
- Killer B 1/2" NPT to 1/8" NPT Adapter
- Killer B 1/8" NPT to 1/8" PT Adapter
- Killer B 1/8" PT to 1/8" NPT Adapter
- Killer B Oil Pan Hardware Kit (For Killer B Aluminum Oil Pan), '02-'14 WRX & '04-'14 STi
- Killer B KBM Pan OEM Plug Copper Seal, '02-'14 WRX & '04-'14 STi
- Killer B 2" V-Band Flange Stainless
GrimmSpeed
- GrimmSpeed Phenolic Intake Manifold Spacer (3mm), WRX & STi
- GrimmSpeed Phenolic Intake Manifold Spacer (8mm), WRX & STi
- GrimmSpeed Subaru MAF Block Off Plate
- GrimmSpeed EWG Up Pipe w/ Dump Tube (38mm 2-Bolt or V-Band, Cer. Coated), WRX & STi
- GrimmSpeed EWG Up Pipe w/ Dump Tube (38mm V-Band), WRX & STi
- GrimmSpeed Exh. Manifold Crosspipe (Ceramic Coated), '02-'05 WRX, '08+ WRX & '04+ STi
- GrimmSpeed Exh. Manifold Crosspipe, '02-'05 WRX, '08+ WRX & '04+ STi
- GrimmSpeed EWG Up pipe w/ Dump Tube (44mm V-Band, Ceramic Coated ), WRX & STi
- GrimmSpeed Up Pipe w/ Flex (Ceramic Coated), WRX & STi
- GrimmSpeed Up Pipe w/ Flex, WRX & STi
- GrimmSpeed EWG Up Pipe w/ Dump Tube (44mm V-Band), WRX & STi
- GrimmSpeed Air/Oil Separator, '02-'07 WRX & '04+ STi
- GrimmSpeed Manual Boost Controller
- GrimmSpeed Lightweight Crank Pulley, STi
- Grimmspeed Turbo Heat Shield, '04-'14 STi
- Grimmspeed Turbo Heat Shield w/ Blue Ceramic Coating, '02-'14 WRX & STi
- Grimmspeed Turbo Heat Shield w/ Black Ceramic Coating, '02-'14 WRX & STi
- GrimmSpeed 3" Downpipe to OEM Midpipe Adapter Kit, Subaru
- Grimmspeed OEM Downpipe to 3" Cat-Back Adapter, '02-'13 WRX & STi
- Grimmspeed Adjustable Wastegate (IWG) Bracket, Most Subaru Stock Location Turbos
- Grimmspeed Crank Pulley Removal/ Install Tool, '93-11 Impreza
- Grimmspeed Top Mount Intercooler (TMIC) Kit, '02-'07 WRX, '04-'13 STi
- Grimmspeed Top Mount Intercooler (TMIC) Kit (Black), '02-'07 WRX, '04-'13 STi
- Grimmspeed Top Mount Intercooler (TMIC) Y-Pipe Kit (Black), '02-'07 WRX, '04-'13 STi
- Grimmspeed Top Mount Intercooler (TMIC) Y-Pipe Kit (Red), '02-'07 WRX, '04-'13 STi
- Grimmspeed Top Mount Intercooler (TMIC) Y-Pipe Kit (Blue), '02-'07 WRX, '04-'13 STi
- GrimmSpeed 3-Bolt Gasket (APS Downpipe)
- GrimmSpeed Exhaust Manifold Gaskets (pair), WRX & STi
- GrimmSpeed Exhaust Manifold to Up Pipe Extra Thick Gasket, WRX & STi
- GrimmSpeed Exhaust Manifold to Up Pipe Gasket, WRX & STi
- GrimmSpeed Manifold to Crossover Pipe Gaskets (pair), WRX & STi
- GrimmSpeed Turbo to Downpipe Gasket, WRX & STi
- GrimmSpeed Up Pipe to Turbo Gasket, WRX & STi
- GrimmSpeed 3" 2-Bolt Gasket, Extra Thick
- GrimmSpeed Intake Manifold to TGV Gasket (Pair), '02+ WRX/STi/FXT/LGT
- GrimmSpeed TGV to Head Gasket (Pair), '02+ WRX/STi/FXT/LGT
- Grimmspeed Throttle Body Gasket, '06-'13 WRX & '04-'14 STi
- Grimmspeed 3-Bolt Manifold to Up Pipe Gasket
- Grimmspeed Top Mount Intercooler Blow-Off Valve Gasket, '02-'07 WRX & 04+ STi
- Grimmspeed Top Mount Intercooler Y-Pipe Gasket(pair), '02-'07 WRX & 04+ STi
STi
Blouch
- Blouch Turbo TD05H-16-XT, WRX & STi
- Blouch Turbo 20G-XT-R , WRX & STi
- Blouch Turbo 20G-XT, WRX & STi
- Blouch Turbo DOMINATOR 2.5XT-R, WRX & STi
- Blouch Turbo DOMINATOR 1.0XT, WRX & STi
- Blouch Turbo DOMINATOR 2.0XT, WRX & STi
- Blouch Turbo DOMINATOR 3.0XT-R, WRX & STi
- Blouch Turbo DOMINATOR 5.0XT-R, WRX & STi
- Blouch Turbo TD05H-18G-XT, WRX & STi
- Blouch Turbo DOMINATOR 1.5XT-R, WRX & STi
- Blouch Turbo DOMINATOR 4.0XT-R, WRX & STi
- Blouch Oil Feed Line (Ball Bearing), '04-'06 STi & '08-'14 STi
- Blouch Oil Feed Line (Journal Bearing), '04-'06 STi, '08-'14 STi
Perrin
- Perrin Up Pipe, '02-'10 WRX & STi
- Perrin Header, WRX & STi 2.5L Turbo (SAVE $90.00!!)
- Perrin "Big Tube" Equal Length Headers, '04+ STi & '02+ WRX
- Perrin Turbo Inlet Hose (Newest Design!), '02-'07 WRX & '04-'10 STi (SAVE $20!!)
- Perrin "Big" Turbo Inlet Hose, '02-'07 WRX & '04-'09 STi
- Perrin "Big Tube" 2" Up Pipe, '02+ WRX & '04+ STi
- Perrin Turbo Heat Shield, '02-'13 WRX & STi
- Perrin Turbo Thermal Blanket, '02-'13 WRX & STi
- Perrin Up Pipe Thermal Blanket, '02-'13 WRX & STi
- Perrin Panel Air Filter, '08-'13 WRX & STi
- Perrin Lightened Crank Pulley, '02-'09+ WRX & STi (Save $20.00!!)
- Perrin Recirc. Blow Off Valve (Black), '02-'07 WRX & '04-'10 STi
- Perrin Lightened Crank Pulley (Red), '02-'13 WRX & STi
- Perrin Pulley Cover (Black), '02-'13 WRX & STi
- Perrin Pulley Cover (Red), '02-'13 WRX & STi
- Perrin Engine Mount Kit, '02-'14 WRX & '04-'14 STi
- Perrin "Big Tube" Equal Length Headers, '04-'14 STi & '02+ WRX
- Perrin Cat Back Exhaust System (Brushed Finish), '11-'13 STi Sedan & '08-'13 WRX Sedan
- Perrin Axle Back Exhaust System (Brushed Finish), '11-'13 STi Sedan & '08-'13 WRX Sedan
- Perrin Catback Exhaust System (Quad Tip, Brushed Finish), '08-'13 STi Hatch & '11-'13 WRX Hatch
- Perrin Axle Back Exhaust System (Quad Tip, Brushed Finish), '08-'13 STi Hatch & '11-'13 WRX Hatch
- Perrin Cat-Back Exhaust System (Quad Tip, Brushed Finish), '11-'13 STi Sedan & '11-'13 WRX Sedan
- Perrin Axle-Back Exhaust System (Quad Tip, Brushed Finish), '11-'13 STi Sedan & '11-'13 WRX Sedan
- Perrin Y-Pipe Mid Pipe Section, '11-'13 STi Sedan & '08-'13 WRX Sedan
- Perrin Radiator Hose Kit (Black), '08-'14 WRX & STi
- Perrin Radiator Hose Kit (Red), '08-'14 WRX & STi
- Perrin Pre-Filter Cover, Fits Perrin Cone Filters
- Perrin "Afta-MAF" MAF Hose (Black), '08-'14 WRX & STi
- Perrin "Afta-MAF" MAF Hose (Red), '08-'14 WRX & STi
- Perrin "Afta-MAF" MAF Hose (Blue), '08-'14 WRX & STi
- Perrin Radiator Shroud (Black), '08-'14 WRX & STi
- Perrin Radiator Shroud (Red), '08-'14 WRX & STi
- Perrin Front Mount Intercooler Core (Black), '08-'14 WRX & STi
- Perrin Front Mount Intercooler Core (Silver), '08-'14 WRX & STi
- Perrin Front Mount Intercooler Tubes & Couplers (Black / Black), '08-'14 STi
- Perrin Front Mount Intercooler Tubes & Couplers (Black / Red), '08-'14 STi
- Perrin Front Mount Intercooler Tubes & Couplers (Red / Black), '08-'14 STi
- Perrin Front Mount Intercooler Tubes & Couplers (Red / Red), '08-'14 STi
- Perrin Air / Oil Separator Kit (TMIC, Black), '08-'14 WRX & '08-'14 STi
- Perrin Air / Oil Separator Kit (TMIC, Red), '08-'14 WRX & '08-'14 STi
- Perrin Air / Oil Separator Kit (FMIC, Black), '02-'14 WRX & '04-'14 STi
- Perrin Air / Oil Separator Kit (FMIC, Red), '02-'14 WRX & '04-'14 STi
Mishimoto
- Mishimoto Performance Radiator, '08-'09 Subaru WRX & STi
- Mishimoto Aluminum Fan Shroud Kit, '08-'13 WRX & STi
- Mishimoto Magnetic Drain Plug (M20x1.5) Subaru
- Mishimoto 19 Row Oil Cooler (Universal)
- Mishimoto 10 Row Oil Cooler (Universal)
- Mishimoto Oil Cooler Kit
- Mishimoto 19 Row Oil Cooler Kit (Universal)
- Mishimoto Oil Catch Can (Aluminum, Small)
- Mishimoto Oil Catch Can (Aluminum, Large)
- Mishimoto Oil Catch Can (Black)
- Mishimoto Oil Sandwich Plate (M20, Silver)
- Mishimoto Sandwich Plate Fitting (M20 x -10AN, Black)
- Mishimoto Stainless Steel Sandwich Plate Adapter (M20)
- Mishimoto Upper Aluminum Hose Kit, '08-'13 WRX & STi - $80.00
- Mishimoto Silicone Radiator Hose Kit (Red), '08-'13 WRX & STi
- Mishimoto Silicone Radiator Hose Kit (Black), '08-'13 WRX & STi
- Mishimoto Silicone Radiator Hose Kit (Blue), '08-'13 WRX & STi
- Mishimoto Oil Filler Cap (Red Insert), Subaru "EJ" Engines
- Mishimoto Oil Filler Cap (Black Insert), Subaru "EJ" Engines
