Got2Boostit2's 2004.7 STi "Lucille"-2.0 Coming in 2020 - Page 19 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Got2Boostit2's 2004.7 STi "Lucille"-2.0 Coming in 2020
Old 09-09-10, 11:09 AM   #181
got2boostit2
Administrator
Feedback Score: 18 reviews
Fav Mod: Hands down - Q Rack FTMFW Boy eee
got2boostit2 is a name known to allgot2boostit2 is a name known to allgot2boostit2 is a name known to allgot2boostit2 is a name known to allgot2boostit2 is a name known to allgot2boostit2 is a name known to all
Default Re: Got2Boostit2's 2004.7 STi "Lucille" I Needed Me Some STi Post 171
So back to the lateral links. Got impatient and did a quickie polish on one of the links so I could install the TIC bushings. Here are comparision picks:
Pretty easy to swap bushings. Most likely will finish the other links and install on car sometime next week.
Image of link currently on car from last year, (trying a different polishing method this year):
If it's not Boosted, what's the point?
Serving you as a moderator since Jan 2011
"Lucille" is Sponsored by: Butler's Garage
Protune video
https://youtu.be/Xyx6G1yXqKc
If you have issues with moderation or other members, report the post or use the Private Support Forum to discuss. Located => https://www.iwsti.com/forums/private-support-forum/
got2boostit2 is offline
Old 09-09-10, 01:16 PM   #182
muller_777
pwn n00bs
Feedback Score: 15 reviews
Car: '18 CBS STI
muller_777 will become famous soon enough
Default Re: Got2Boostit2's 2004.7 STi "Lucille" Polished Lat Link TIC Bushings Post ???
damn those came out shiny as hell.
muller_777 is offline
Old 09-09-10, 02:07 PM   #183
Spider96
Advanced Mastery Level I
Feedback Score: 19 reviews
Fav Mod: Low mileage, High resale value. lol...
Spider96 is on a distinguished road
Yeah they did...any tips you could share on how to make them look this good?
Spider96 is offline
Old 09-09-10, 03:03 PM   #184
got2boostit2
Administrator
Whatcha lookin' for..... one of those Joey Lisano write-ups with pictures?
Give me a minute.
Items used:
WD40 (dissolves the underspray)
Shop towels (blue) Sam's Club multi-roll
3M Ultra fine wet/dry sandpaper (to be followed with W/D 1500/2000 grade paper)
Air drill with headlamp polishing pad
Special secret compound (some street rod stuff)
Write-up with images to follow either here or in the How to section.
Updated post 181 with images of the stock hand polished links currently on car. Will be swapping these for the polished links with TIC lateral link bushings installed.
Protune video
Old 09-10-10, 07:14 AM   #185
got2boostit2
Administrator
Default Re: Got2Boostit2's 2004.7 STi "Lucille" Polished Lat Link TIC Bushings Post 181
How I cleaned and polished my aluminum lateral links.
1. Use WD40 to clean the undercoating off of the links. Apply a liberal amount to desolve the undercoating.
2. Using wet/dry sandpaper Ultra fine or 1000 grit or finer, wet sand the complete surface of the links.
3. Using a metal polish of your choice like Simichrome, apply an amount to a polishing pad. I used a old headlamp polishing pad installed in a air drill.
4. Polish to the appropriate luster. I cleaned it then polished with Eagle One "Never Dull" polishing pads which I also use to periodically clean the links on the car.
Sure, I could have cleaned the WD40 bottle, but I broke the nozzle right before the image was captured and said $% it.
Protune video
Old 09-10-10, 07:41 AM   #186
IGoFast1589
Advanced Mastery Level II
Feedback Score: 1 reviews
Car: 07 Subaru STi
Fav Mod: Bride Zeta 3
IGoFast1589 is on a distinguished road
Links look awesome!
IGoFast1589 is offline
Old 09-16-10, 07:25 AM   #187
got2boostit2
Administrator
So what would you do? Should I consider a engine build this winter? I said I was going to run this combination next year to fine tune the suspension and then look to build the engine afterwards. Should continue with my original plan or complicate things by doing a build and possibly spending all season next year fine tuning an engine build as well as the suspension?
If I were to improve the engine it would be:
20G XT Blouch TD-06 clipped
1000 cc injectors
TGV deletes
External wastegate routed back into exhaust
Forged pistons (brand to be determined)
Improved bearings both crank/rods
Ported heads
Change valves/springs
Kelford cams
Couple of other items
ARP headstuds
Balanced internals
Cobb AP V2 Protuned (seek out Doug from Topspeed)
Upgrade oil pump
Decisions:
Upgrade crank and rods while apart
Go 3071 rotated P&L kit versus 20gxt
Change turbo back from current
Buy packaged shortblock versus using current block and having local machine work done and self assemble
Protune video
Old 09-16-10, 12:55 PM   #188
luvracn
Advanced Contributor Level 3
Feedback Score: 22 reviews
Car: 04 PSM STi RIP
Fav Mod: 35R+C16= :)
luvracn is an unknown quantity at this point
Default Re: Got2Boostit2's 2004.7 STi "Lucille" Engine Build Question Post 187
Darryl, i'll take you for a ride and then your decision will be a no brainer! We will talk off thread. Upgrade FTMFW!!
luvracn is offline
Old 09-17-10, 07:16 AM   #189
coolblue05
Master Contributor Level 2
Feedback Score: 13 reviews
Car: 05 sti widebody
coolblue05 is an unknown quantity at this point
Darryl, those lat links look beautiful!!!
coolblue05 is offline
Old 09-17-10, 07:45 AM   #190
got2boostit2
Administrator
Thanks, they are even more impressive after getting some products from Wizard.
Protune video
