GD: Project Silverstreak: New diff and coilovers! - Page 15 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > GD: Project Silverstreak: New diff and coilovers!
Old 03-12-19, 04:39 PM   #141
brapp
Becoming A Master Contributor
Car: 2005 STi
Fav Mod: going from GR -> GD
brapp will become famous soon enoughbrapp will become famous soon enough
Default Re: Project Silverstreak: New diff and coilovers incoming...
Originally Posted by SubySal View Post
Yesterday I was working on cleanup and it occurred to me that sharing my methods might be useful to others.
This is a 3M bristlebrush. Different grits come in different colors. White is a pretty fine grit. They take a little getting used to. They work better at lower speeds which isn't always easy on a die grinder. The techs at Hueberger use these quite a bit. They are outstanding at quickly removing old Fujibond even on aluminum. Of course care should be taken as aluminum is a soft material.
Image Link
Here's how it worked on my block when I installed a Killer B pan.
Image Link
Yesterday I used it to clean up the bearing caps and diff housing.
It worked great at removing the rust on the housing.
Image Link
It also did a great job at removing the corrosion from the bearing caps. Note: I did polish the caps after cleaning them up with my bench buffer.
Image Link
Image Link
While I was at it I thought I'd do some test fitting. I found that the studs that go into the new diff cover stick out about 2mm too far. I'm going to cut the threads down a bit more with a bottom tap.
Image Link
As always... simply gorgeous.
Looking forward to trying to keep up with you this year after all that!
brapp is offline
Likes 1 Dislikes 0
Old 03-13-19, 12:46 PM   #142
SubySal
Advanced Mastery Level I
Feedback Score: 1 reviews
Fav Mod: everything done so far
SubySal has a spectacular aura aboutSubySal has a spectacular aura about
Default Re: Project Silverstreak: New diff and coilovers!
Thanks Dan. Well you haven't had any problems keeping up to this point lol. I'm just hoping after all this these parts make for a pretty noticeable difference around the course.
SubySal is offline
Old 03-28-19, 10:01 PM   #143
SubySal
I made some progress on the diff install. It went OK. I like the Cusco cover, but I have a few minor gripes. Besides the crappy plugs they include and the fact there is no temp sensor adapter (in the case you want to use an external cooler) they don't thread the holes for the studs down far enough. I needed another few millimeters. It wasn't a difficult fix, but with a part this expensive you'd think they get it right.
My backlash was out too. I think maybe it was set on the high side from the factory and wear did the rest. There's not a lot of info out there on setting used gears. One school of thought is to reset backlash on used gears the same no matter what. The FSM says that upon inspection if the spec is out correct it. I went that route. The gears may make some noise, but if they do they should quiet down eventually. Anyway we'll see.
I'm told these are acceptable patterns on a used gear set.
I finally got to use this dial indicator. I bought it around 1993 to set the gears on the '87 Bronco XLT I had at the time. However one of my Dad's friends set the gears instead.
I had a friend of mine make this pretty cool vise adapter. It made torquing the ring gear bolts much easier.
Here it is all assembled. The vise adapter like the above tool also made life much easier.
...and here it is installed.
SubySal is offline
Likes 2 Dislikes 0
Old 03-28-19, 10:28 PM   #144
Z33KLF
Becoming A Contributor
Z33KLF is an unknown quantity at this point
one of the best build period
Z33KLF is offline
Likes 1 Dislikes 0
Old 03-28-19, 11:28 PM   #145
SubySal
Thanks! I appreciate it!
SubySal is offline
Old 03-30-19, 05:57 PM   #146
Got2Boostit2
Moderator Elite
Feedback Score: 18 reviews
Fav Mod: Hands down - Q Rack FTMFW Boy eee
Got2Boostit2 is a name known to allGot2Boostit2 is a name known to allGot2Boostit2 is a name known to allGot2Boostit2 is a name known to allGot2Boostit2 is a name known to allGot2Boostit2 is a name known to all
Damn son! I need a towel from all this parts porn.
If it's not Boosted, what's the point?
Serving you as a moderator since Jan 2011
"Lucille" is Sponsored by: Butler's Garage
Protune video
https://youtu.be/Xyx6G1yXqKc
If you have issues with moderation or other members, report the post or use the Private Support Forum to discuss. Located => https://www.iwsti.com/forums/private-support-forum/
Got2Boostit2 is offline
Likes 1 Dislikes 0
Old 04-01-19, 06:58 AM   #147
SubySal
SubySal is offline
Old 04-21-19, 05:06 PM   #148
SubySal
I decided to up my detailing game and jumped on the foam cannon bandwagon. I have to say they are pretty fun.
The new hardware...
I like that the trigger can be detached and fitted with a standard 1/4" quick-disconnect nozzle. It is so much easier and faster then using a long wand.
SubySal is offline
Likes 1 Dislikes 0
Old 07-15-19, 12:02 PM   #149
SubySal
Default Growlfest 2019
Well I haven't been able to race much this year so not much to update. I did a Time Attack event on the 23rd and it didn't go well. It was cold and Nexen's like heat so they wouldn't stick. With all the changes I felt out of sorts too. I also noticed a cloud of white smoke come from the exhaust after my 3rd run.
My block catch can had oil in it, but the catch can for the heads was empty. It was suggested to me it could be the PCV valve. I realized I had never changed it so it was 13 years old. I think it may have been a combination of that and overfilling the oil a bit. The car seemed to work well at the Growlfest so that was a relief.
Here's a run from yesterday's Double Down race.
https://www.youtube.com/v//WPt5kiLV_2E
The car ran much better. I had set the rear rebound incorrectly at the time attack event which made the car understeer and turn in very sluggishly. This time around after correcting that it ran much better. I was actually dragging the mudflaps around the entire carousal turn. The car has never done that before so the grip has increased even with old tires. The rear diff did a great job at keeping the car in line. The brake pads take some getting used to. They're grabby when cold so they just lock up the front tires. Once warm though they feel great. You still have to be gentle though.
SubySal is offline
Likes 2 Dislikes 0
Similar Threads
New build project Ares 2.5 Liter/Litre Factory Motor 12 12-28-13 04:32 AM
How to build a 'perfect' DAILY-DRIVE 350-400bhp? U9Ly_KwaN 2.5 Liter/Litre Factory Motor 23 08-11-11 11:44 PM
AMS Top Shop Engine build..the quest for 1000hp on 100octane! AMS Vendor Announcements & Project Buildups 8 11-05-08 04:58 PM
ICS '08 STI Project Stage "X" Build Up Dyno Flash 2.5 Liter/Litre Factory Motor 18 06-22-08 08:51 AM
FS: S2000 powered IRS "Locost" Seven Project BrianGT Used STIs For Sale 7 10-06-07 06:51 PM
