STi Table of Contents:
New front end - post #27
New wheels - 57Motorsport installed - post #35
#4 cylinder low compression - post #75
aspec shift knob - post #96
engine pulled - post #97
engine failure - post #106
build list - post #144
long block pics - post #177
motor is in - post #221
wiring carnage - post #271
new motor on the dyno - post #377
pickup at EFI! - post #387
interior tear down - post #437
defi relocation - post #440
trip to EFI logics/overheating issue - post #590
first oil change/drain plug - post #625
PROVA steering wheel - post #639
very clean pictures - post #665
EFI Logics first tune pictures - post #734
new duramax/DD - post #782
dyno run 510/473 - post #863
full blown dual walbro pics - post #868
rally armor mud flaps - post #925
crawford gymkhana exhaust pics + video - post #981
invidia n1 race w/ti tip - post #1027
clean pics - post #1045
enkei pf01's powdercoated red mounted - post #1123
MORE enkei pictures - post #1141
few exterior changes - post #1252
syms sides and dress up bolts - post #1422
few pics - post #1505
EFI Logics Mega Meat 10/1/11 - post #1608
10/13/11 - T3h_Clap's Wheel33list Blog Feature
bent kw3's - post #1799
repainted intercooler core (eastwood rad paint) - post #1930
AST 4100's with Swift springs (8k/7k) - post #2060
wheel fell off/damage pictures - post #2114
engine bay dress up - neon yellow!! - post #2202
EFI Logics Mega Meet 5/19/12 - post #2237
Black PF01s installed w/Prova Yellow Mirrors - post #2774
2005 Subaru WRX STi
93 Octane + Meth Injection + Speed Density
Engine:
Exterior:
Interior:
Drivetrain:
Suspension & Stiffening:
2005 Subaru WRX STi
Engine:
- COBB Accessport V3
- AEM Meth Injection
- Spec C Tank w/Meth
- STi GR Nitride Crank
- Manley H Beam Plus Rods
- Supertech 100mm Pistons
- Supertech +1mm Intake and +1mm Exhaust Valves
- Supertech Titanium Retainers
- Supertech Valve Springs
- Cosworth S2 Grind Camshafts 278/274
- ACL Race Rod/Main Bearings
- ARP Head Studs
- Invidia N1 Race w/Ti Tip Catback
- Ultimate Racing GTX3582R 1.06 A/R Turbo
- Ultimate Racing Downpipe
- Ultimate Racing 3 Bolt Uppipe
- Ultimate Racing Reverse Flow Ver1 FMIC
- Tomei Equal Length Header
- Perrin Performance A/O Separator
- KS Tech 83mm MAF Housing
- Full Blown Dual Walbro 255 Pump Setup w/Custom Lines
- Blitz SBC ID3 Boost Controller
- TIAL MV-R External Wastegate
- TIAL BOV
- Aeromotive Fuel Rails
- Aeromotive Fuel Pressure Regulator with Liquid-Filled CHM Gauge
- Radium Engineering Pulse Damper
- Injector Dynamics 1300cc Injectors
- KOYO Race Aluminum Radiator
- KillerB Motorsport Oil Pan + Pickup Tube
- KillerB Oil Fill Tube
- Zerolift Composite TGV Deletes
- NGK One Step Colder Plugs
- Fluidamper Crank Pulley
- 11mm GR Oil Pump
- Prova Radiator Cap
- Prova Oil Cap
- XS Power S680 Battery
- Samco Sport Radiator Hoses
- Coolant Reservoir Deleted
- Gates Racing Timing Belt
- Carbign Craft Carbon Fiber Alternator Cover
- Carbign Craft Carbon Fiber Radiator Shroud
- Dress Up Bolts Polished Engine Bay Bolts
- Project MU Brake & Clutch Caps (not made anymore, extremely rare!)
- NRG Carbon Fiber Hood Dampers
- AEM 3.5 MAP Sensor
Exterior:
- Genuine Cusco Front Lip
- Chargespeed Genuine Carbon Fiber Bottomline Side Skirts
- Chargespeed Genuine Carbon Fiber Vortex Generator
- Voltex Carbon Fiber Rear Diffuser
- Voltex Wing Delete
- Prova Yellow Wide Angle Mirrors
- S2000 Retrofit Headlights w/Angel Eyes/Blacked Out
- 10% Window Tint
- Debadged
- Blue Bat's Tinted Tails + 3rd Brake Light
- Pillarless Grille Mod Painted OBP
- Black STi Billet Aluminum Front Bumper Trim
- Varis Carbon Fiber Exhaust Shield
- Varis Carbon Fiber B-Pillars
- Hella's
Interior:
- Recaro Leather Speed Seats (Custom Ordered)
- WRX Black Carpet/Door Cards/Rear Seat w/Pass Through
- PROVA D-Shaped Steering Wheel
- Aspec Shift Knob
- S204 Style Flat Black Dash Trim
- AEM AFR Gauge
- Autometer Carbon Fiber Gauge Pods
- DEFI BF Amber Boost
- DEFI BF Amber Oil Pressure
- DEFI BF Amber EGT
- DEFI Control Unit II
- DEFI Triple Meter Hood
- Fully Converted Interior Lights to Red
- Subtle Solutions Ashtray Bezel
- Auto-Dimming Mirror/Compass
- Polished STi Shifter Surround
- JDM Carbon Shift Pattern Decal
- Autospeed Dead Pedal
- Passport 8500 X50
- Forester DIN Pocket
- Alpine iDA-X305 Digital Media Receiver
- Alpine Type-R Speakers
Drivetrain:
- Enkei PF01 Black 18x9 +45
- Conti Extreme Contact 255/35/18
- Project KICS R40 Neochrome Lug Nuts
- Kartboy Short Shifter W/All Bushings
- Kartboy Crossmember and Transmission Bushings
- ACPT Carbon Fiber Driveshaft
- South Bend Stage 3 Daily Clutch
- Competition Clutch Lightweight Flywheel
- Goodridge SS Clutch Line
- Torque Solution Motor/Tranny Mounts
- JLM Motorsports Pitch Stop Mount
- AST 4100 Coilovers w/Swift Springs & Helpers (8k/7k)
- RCE Lowering Front Adjustable Camber Plates (not made anymore, extremely rare!)
- Vorshlag Rear Adjustable Camber Plates
- The Car Labs X-Brace
- Whiteline 24mm Adjustable Front/Rear Sway Bars
- Kartboy Rear Endlinks
- Kartboy Front Endlinks
- Whiteline Subframe Locking Bolts
- Whiteline Sport ALK Kit
- Whiteline Adjustable Lateral Links
- Cusco Adjustable Trailing Arms
- Offensive Power Front Fender Braces
- JDM Titanium Front Strut Bar
- GT Spec 3-Piece Subframe
- Gloss Black Powdercoated Brembo's
- DBA 5000 Front Drilled/Slotted Roters
- DBA 4000 Rear Slotted Rotors
- Hawk HPS + Front/Rear Pads
- Cusco Master Cylinder Brace
- Goodridge SS Lines
- Motul RBF600 Fluid
