Ben's STi replacement - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Ben's STi replacement
Old 06-23-09, 11:08 AM   #1
bsholt21
Advanced Contributor Level 1
Fav Mod: Tein Flex
bsholt21 is on a distinguished road
Default Ben's STi replacement
I'm Ben Holt in Nashville, TN. Formerly had an '04 WRB STi, and I've been a member for quite awhile. As you can see from the description, this is a WRX hybrid and I intend to finish the STi changeover...minus the AVCS. This car's great, but it'll be even better when I can drive it.
--Thanks to Innovative Tuning for the replacement map!
bsholt21 is offline
Old 06-23-09, 11:09 AM   #2
bsholt21
Fav Mod: Tein Flex
Default Re: Ben's STi replacement
Moved from:
https://www.iwsti.com/forums/other-ve...cment-now.html
---Yeah, Ima retard. GD Series is GD Series regardless.
bsholt21 is offline
Old 06-23-09, 11:11 AM   #3
bsholt21
Fav Mod: Tein Flex
Review of car details:
Engine
**Built by Innovative Tuning - NY**
***Tuned by Forged Performace (Currently 260whp)***
EJ257 SB
Cobb Tuning 2.0L Stg 2 Heads
Stage 2 Package Includes:
- New Subaru Castings
- CNC Porting
- Intake Flow increased +20%
- Exhaust Flow increased +42%
- Hand Blended
- Deburred
- Multi-Angle Valve Job
- Vacuum Tested Valve Seats
- SS In. Valves(+1mm Oversized)
- Inconel Ex. Valves ( +1mm Oversized)
- Performance Dual Valve Springs
- Titanium Retainers
- Hardened Spring Seats
- Matched Combustion Chambers
- Kelford 264/272 cams matched by Kelford NZ for Rally/ autoX
- TGVs Deleted, Ported and Polished to match the heads
- Phlenetic Intake Spacers
Walbro 255 FP
DW 740cc Injectors
Power Enterprises Kevlar Timing Belt
VF22 P&Pd by Deadbolt Internal Wastegate Welded Shut
UR EWG UP (only 2 of a kind, according to original seller)
UR Waste Dump Tube
Tial 38mm Wastegate
Grimspeed EBCS
STi P&Pd Exhaust Manifolds plus center pipe
Ebay Autodynasty TMIC ported for Meth Injection (No Meth)
Perrin Y pipe
Perrin Throttle Body Coupler
Perrin Turbo Inlet
Custom Oil CC
Exhaust
PDE HF Catted DP
Borla Hush Cat Back
Kartboy Exhaust Hangers Limited Pink
Suspenssion/ Handling
Tein Flex + EDFC
STi Rear Sway Bar
Cobb Front 3 Way Adj Sway Bar
E-Bay F&R Strut Bars
Chassis
Paranoid Fabrications LW Subframe
Paranoid Fabrications Fender Cowls
Ebay H-Brace
Kartboy Rear Subframe Outrigger Bushings (Race)
TIC Clunk Killer (Race)
TIC Unabombers Sexy rear end kit
Protection
RallyArmor Limited Mud Flaps
ARC Alternator Shroud
Perrin Radiator Shroud
Engine Management/ Tuning
Tactrix OpenPort 2.0 - Forged Performance Tune
Stopping
Rotora BBK
Goodrich SS Braided Coated Brake Lines
Perrin Master Cylinder Support Brace
Drivetrain
ACT Streetlight Flywheel
ACT 6 PUC Clutch Disk
ACT Race Pressure Plate
Kartboy Short Throw Shifter
TIC Shift Linkage
TIC Shifter Bushing
Goodrich SS Clutch Line
Custom Driveshaft Cover
Kartboy Front Shifter Stay Bushings
Kartboy Lever Combo Plus
Kartboy Rear Shifter Stay Bushing
TIC Lever Pivot Bushings Wide
TIC Rear Diff Mount Bushings (Race)
TIC Transmission Crossmembert Bushings Limited Pink
Comfort
JVC Arsenal KD-ADV49 ...with perhaps lockout bypass
Driver Input
PDE Fully Adjustable Racing Aluminum Pedals
Defi 60mm 3 Gauge Pod (replace oem clock pod)
Omori 60mm Boost, EGT and Oil Pressure Gauges with Peak Hold and Warning Indicators
Exterior
JBP Painted Headlights
JDM Sti Wagon F&R Lip Kits
Sti JPB Painted Side Skirts
Wagon Tailight Mod
Prodrive Shift Lever
Prodrive Floor Mats
Sti Hood Scoop
Safety
4 Hella FF500 55W Fog Lamps
2 Hella FF1000 100W Fog Lamps
Passenger and Driver RJS 6 point Racing Harness
Ebay Harness Bar
Wheels
Exel TZ-10 17X7.5 Painted Black
Ben's STi replacement-car-front-jpg   Ben's STi replacement-car-side-jpg   Ben's STi replacement-engine-bay-jpg
bsholt21 is offline
Old 06-23-09, 11:22 AM   #4
bsholt21
Fav Mod: Tein Flex
I'll try to post pics soon, but I'm up to my arse in the wiring and other gremlins.
bsholt21 is offline
Old 06-23-09, 12:38 PM   #5
torquemada
Fav Mod: ghetto intake
torquemada is on a distinguished road
posting to disrupt your monologue
saying hi, waiting for pics
R.I.P. Peter Steele * 4. January 1962 14. April 2010
torquemada is offline
Old 06-25-09, 05:26 AM   #6
bsholt21
Fav Mod: Tein Flex
Sorry, still haven't had time to go out to my parents' house. It's hiding in my dad's shop at the moment till I get all the problems worked out. There are several pics on the original sales listing, BTW. It still looks the same.
As stated before, I'm hoping my Omori electronic boost gauge isn't f'd. Every time it gets power, it immediately tacks out to 25lbs...this is even before the car is started. The gauges were wired wrong, and I'm keeping my fingers crossed that this is the problem. If anyone has any ideas, feel free to let me know.
bsholt21 is offline
Old 12-17-09, 08:54 AM   #7
bsholt21
Fav Mod: Tein Flex
Still haven't gotten pics up...I know.
Update -
* Working with Benchmark Tuning (formerly 555 Tuning) on an Internet tune. It's stupid fast now.
* Have new front hub setups from TIC to be installed...bearings on passenger side are poop.
* Still needing new suspension. Looking for new (or good used) coilovers. The ones on it are absolutely SHOT.
bsholt21 is offline
Old 12-17-09, 08:59 AM   #8
BAD STI
IWSTI Guru
Feedback Score: 2 reviews
Fav Mod: 20G-XT
BAD STI is an unknown quantity at this point
Nice build man. Do you have a dyno?
BAD STI is offline
Old 12-21-09, 07:23 PM   #9
bsholt21
Fav Mod: Tein Flex
Thanks! That'd be awesome if I did...or if there was even one anywhere close to Nashville. I'm doing an Internet tune through Benchmark/555 Tuning with my Tactrix setup. It's working out pretty well. There's a buttload of logging involved, but it's worth it.
Got my new-ish coilovers on their way. Found a Tein Flex EDFC setup for cheap. Werd
bsholt21 is offline
Old 12-24-09, 03:04 PM   #10
bsholt21
Fav Mod: Tein Flex
My coilovers came in, and I'll be installing them asap. Downside is, I have to take the front knuckles totally off to get my new bearings and hubs put in.
bsholt21 is offline
Similar Threads
Bigest Brake & Suspension Thread on Iwsti.com: All Subaru Makes Included JBK Performance.com GD-Vendor Classified Ads 18 01-15-09 04:54 PM
Alcantara STI Pillow GROUP BUY! *** ORDERS SHIPPED!!! * Car Comfort Design Inc. Vendor Group Buys 101 10-11-08 06:20 AM
1/7/2008 Dealer Inventory! (153 in stock) chippyhawkeye GR-General 32 01-24-08 10:40 AM
Interested in thoughts on a potential STi replacement. donmei Off Topic 21 01-26-06 05:31 AM
