piknockout's STU Auto-x Build Sponsored by Agile Auto: 8/23 Update - WDCR #7 - Page 17 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > piknockout's STU Auto-x Build Sponsored by Agile Auto: 8/23 Update - WDCR #7
Old 10-05-10, 08:00 AM   #161
T3h_Clap
I Solve Problems
Feedback Score: 14 reviews
Fav Mod: TiC SST's and Vorshlag Plates
T3h_Clap will become famous soon enoughT3h_Clap will become famous soon enough
Default Re: piknockout's STU Auto-x Build - 2006 STi sponsored by Agile Auto: 10/4 - 18x9.5's
Yeah, the spacer would be required with that high an offset. Not like it matters they fit great at the +35mm effective offest up front.
Are you going to jump to the AD08 in a 245/40/18? The 9.5s should stretch the 40 series just enough to not lose much sidewall stiffness.
T3h_Clap is offline
Old 10-05-10, 08:13 AM   #162
Thorium06
Advanced Contributor Level 2
Feedback Score: 2 reviews
Car: 05 AW STi
Thorium06 is an unknown quantity at this point
This is my SMF car, its finally where I wanted it, but its still a lot of work away from being competitive at a national level. The trouble is that nobobdy really makes parts for this thing, so Im making it up as I go lol
Thorium06 is offline
Old 10-05-10, 09:30 AM   #163
piknockout
Advanced Contributor Level 1
Car: 2006 WRX STi
piknockout is an unknown quantity at this point
The plan is to get another set of Dunlops, I've been very happy with them so far. The biggest problem I've seen from guys driving on the AD08's is that they don't heat up fast enough for autocross. I've seen the 245/40/17 AD08's on a 9.5" wide wheel, and the sidewall was nearly straight up and down...those tires are really wide. Oh yeah, and then there's that whole price thing on the AD08's...ouch.
Looks like a clean car! Of course the biggest issue with a newer car like that is weight. To be Nationally competitive, I would say you need at least a 275 r-comp up front, drop some weight, and a fancy diff (if you don't already have one). Anything other than a lightweight Civic seems to be pretty tough to really be fast. Good luck with the build! A friend of mine is working on his SR20DET B15 Sentra, and needless to say it's been a lot of work to get it close...and it's still got a ways to go. SMF is definitely a tough class to build for.
piknockout is offline
Old 10-05-10, 09:38 AM   #164
T3h_Clap
I Solve Problems
The AD08s would probably do better in the south. My Z1 Star Specs get greasy very fast when temps are over 85 or 90 at autox.
T3h_Clap is offline
Old 10-05-10, 10:08 AM   #165
piknockout
Car: 2006 WRX STi
Do you spray them with water when they get hot? I have a co-driver and we've had no issues doing 8 runs, usually spraying them down after the 2nd or 3rd run and between every run afterwards. But agreed, if you're having overheating issues then the AD08's could work well. I'm half tempted to try them since there's contingency, just can't get myself to fork over that kind of money for a "test".
Old 10-05-10, 11:08 AM   #166
T3h_Clap
I Solve Problems
Yeah, spray after each run. If I wait till the 2nd run I'm screwed because they don't cool down unless I spray the crap out of them and wait 10 minutes. No Co-driver.
Part of it could be a combination of smaller run groups and retarded track temps. Homestead go kart track can get upwards of 110 in the summer. Fail.
Since I'm not planning on sticking to STU anymore, I'll probably try a wider "cooler" tire like the RS3 or AD08.
I'm not doing any national events this year so I haven't followed the contingency payouts, are they over $250 yet? I remember the hoosier contingency a few years ago didn't even cover the cost difference between hoosier and kumho.
T3h_Clap is offline
Old 10-05-10, 04:08 PM   #167
Thorium06
Car: 05 AW STi
Talking Re: piknockout's STU Auto-x Build - 2006 STi sponsored by Agile Auto: 10/4 - 18x9.5's
Thanks! Yeah weight sucks, its at 2700lbs which is light for a tc, but almost 1000lbs too heavy for the class. In that pic Im running 245 R6's, but at divisionals this year we ran 275's all around and they still fit in the fenders no problem lol. Originally I was planning on getting the OS Giken diff, but for the money, I decided I would rather have an STi built for STU/Rallycross duty than a FWD race car, so Im going to start parting it out this winter and hopefully find an 06 STi.
If everything goes well I might see you at nationals next year!
Old 10-06-10, 06:55 AM   #168
piknockout
Car: 2006 WRX STi
Smaller run groups and 110 temps could do it! Contingency payouts at NT's are usually $300/$200/$100 for Toyo/Yoko/Bridgestone, with Hoosier giving I think 3 Tires/2 Tires/1 Tire for NT's. It's a lot more at Nationals. Based on that and how well I think we could do, the Yoko's or Stones might not be a terrible idea regionally (FL Tour, DC/Toledo Pro, NE Divisionals). Hmm.
Sounds like an interesting build, sorry you have to tear it down. But then again, an STU STi is quite a bit of fun!
Old 10-06-10, 07:01 AM   #169
T3h_Clap
I Solve Problems
stop thinking, thinking is expensive!
speaking of thinking, i should pick up a cheap pyrometer. Having some hard data on tire temps would be beneficial. My next event is in November so hopefully it's not 100 degrees. My luck it'll be 30
T3h_Clap is offline
Old 10-06-10, 09:27 AM   #170
piknockout
Car: 2006 WRX STi
I've only used a pyrometer to check temps across the tire, not so much for finding optimal tire temp. Last I checked they were pretty even across the board, just a few degrees off in the middle, so I think my camber is in a happy place.
Similar Threads
ChrisM623's WRB 2006 STI (Summer Parts Installed 3/30) ChrisM623 GD-Members' Journals 4 09-18-09 01:02 PM
FS: Cobb AccessPort V1 2006 STI w/ Agile stage 2 Protune Map psidy ECU/Performance Electronics For Sale 6 06-16-09 12:56 PM
Calling All SoCal Subies - Dec 14th, 2008 Minninips USA - SoCal 8 12-14-08 07:10 PM
Agile Auto Tuned STi WOR440 2.5 Liter/Litre Factory Motor 21 03-12-07 01:59 PM
Help King of Imports build a better Project STi! KingofImports.com Vendor Announcements & Project Buildups 36 07-04-05 07:38 PM
