Suspension/Stiffening Street Susp. Sway Set Up - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Suspension/Stiffening Street Susp. Sway Set Up
Old 02-01-08, 08:27 AM   #1
martyq
Contributor
Feedback Score: 2 reviews
martyq is on a distinguished road
Default Street Susp. Sway Set Up
Ive been searching the boards for the proper set up for my street car. I currenty have stock struts with Prodrive springs. Im torn between Whiteline 22mm adjustable front and rear or 24 mm front and rear. I want to maintain comfort and achieve better handling. It seems people are running bigger on street. I dont track or autocross , some hard cornering and twisty driving. Will 22mm be enough with prodrive springs for this type of driving.
martyq is offline
Old 02-01-08, 09:18 AM   #2
stretch
Advanced Mastery Level II
Feedback Score: 4 reviews
Fav Mod: Seat Time
stretch is on a distinguished road
Default Re: Street Susp. Sway Set Up
Probably you should go with equal sized front and rear bars. For purely street, you might consider Cusco 22mm bars for the sole reason that they use maintenance-free rubber bushings. Otherwise, I think 24mm bars are a good street size.
I personally like a larger rear sway than front when on stock springs (Prodrives are close enough), but such a setup can be a handful if you don't like a car that rotates.
stretch is offline
Old 02-01-08, 09:46 AM   #3
antecylintz
Becoming An Advanced Contributor
Car: '05 AWP Stg.3 LGT
Fav Mod: SS lines
antecylintz is on a distinguished road
honestly, i don't think you'll feel much difference btwn the stock 21mm and any brand 22mm sways. i went through this process a couple months ago when trying to come up with a decision. 24s im guessing you'll be happy with and 22s you'll be wondering why in the hell your wallet is lighter
personally i'll be getting the hotchkis street setup
25mm (hollow - i.e. lighter) front and rear with endlinks
antecylintz is offline
Old 02-01-08, 10:06 AM   #4
DrPhyzx
Car: GR STI
Fav Mod: alignment
DrPhyzx will become famous soon enough
I have not done the calculation, but it is often said that the hollow hotchkis/cobb 25 bars are equal in stiffness to a solid 22.
DrPhyzx is offline
Old 02-01-08, 10:24 AM   #5
RaceComp Engineering
Feedback Score: 15 reviews
Car: 15' WRX, 07 Cayman S
Fav Mod: GOOD shocks
RaceComp Engineering will become famous soon enough
I did do the calculation....it's about 23.5mm solid in the front, and the rear is around 22.x, 23.x, and 24.x in the rear. I forget exactly and I have the exact numbers at home.
- andrew
www.racecompengineering.com - www.GTWORX.com
Check us out on Facebook here!
Racecomp Engineering
410-846-5407 Phone
443-370-9000 Mobile
RaceComp Engineering is offline
Old 02-01-08, 10:24 AM   #6
And IIRC, the Cusco rear bar adjusts up to 24mm, so it's a decent choice for your uses, especially with the rubber bushings that they use.
- andrew
410-846-5407 Phone
443-370-9000 Mobile
Old 02-01-08, 10:42 AM   #7
martyq
Contributor
Thanks guys. Im gonna go with Whiteline 24mm adjustable which adjust from 22 - 26 for the rear. So what about the front ?
The Whiteline Front 22mm adj goes 22-24
THe Whiteline Front 24 mm adj goes 24 -26
Which one would be best ?
martyq is offline
Old 02-01-08, 03:38 PM   #8
antecylintz
Fav Mod: SS lines
- andrew
thanks andrew - i had asked around calc too when i heard the same as DrPhyzx to make sure i wouldn't be paying 26mm solid bar prices for 22mm solid bar feel. I also remember it being closer to 24mm in the front and 23-25 in the rear. 'preciate the confirmation!
Old 02-01-08, 09:20 PM   #9
Blu_Scoobie
Becoming A Contributor
Car: White 04 STi
Blu_Scoobie is an unknown quantity at this point
You'll love the Whiteline 24mm rear. I installed mine last weekend, have it set on the middle setting and it made my 04 feel like a different car.
Blu_Scoobie is offline
Old 02-02-08, 06:09 AM   #10
Turninconcepts.com
Account Inactive
Feedback Score: 67 reviews
Turninconcepts.com is an unknown quantity at this point
- andrew
When we did our calculations on them we found them to be just over 22mm solid equivalent. That was a long time ago though.
You can't go wrong with the 22mm or 24mm bars. They would both be good for what you are looking for, but the 24's will make the car easier to rotate so be ready for it.
Tony
Turninconcepts.com is offline
