Is the accessport worth the money? - Page 3 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Is the accessport worth the money?
Old 03-14-18, 08:26 AM   #21
enoxard
Advanced Mastery Level III
Feedback Score: 2 reviews
Fav Mod: kung f00 skillz!
enoxard has a spectacular aura aboutenoxard has a spectacular aura about
Default Re: Is the accessport worth the money?
please do share how those of you claiming 'lean values on the OEM tune' measured this. AFAIK, the AP does not have the ability to log the OEM map.
enoxard is offline
Old 03-14-18, 08:39 AM   #22
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber
i believe you were asking CAKEATER. But, there have been numerous dynos posted over the years. Isn't the stock 2800 rpm stumble associated with a lean spot?
mheyman is offline
Old 03-14-18, 08:52 AM   #23
enoxard
i dont think dyno plots tell you AFR. but im still StockAF, so what do i know. =/
enoxard is offline
Old 03-14-18, 11:24 AM   #24
Noximus
Feedback Score: 3 reviews
Fav Mod: 2015 STI Steering Rack!
Noximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of lightNoximus is a glorious beacon of light
Default Is the accessport worth the money?
Yes, it does. The accessport copies the existing map or if stock they call it the “Installed stock” map when you install the AP. This is what I refered to as Stage 0. I ran each stage to see and log the differences from Stage 0, Stage 1, then Stage 1.5, and finally Stage 2.5 (where 0.5 is the aftermarket intake added to that respective stage.)
Plots can be customized to show any data you want that is part of the log. If you have a wideband log, you can add the AFR log to the plot or you can use the AF sensor 1 from the ECU logs to show the calculated ECU AFR.
Noximus is offline
Old 03-14-18, 11:25 AM   #25
enoxard
I was under the impression that the 'stock' MAP on the accessPort is not actually the OEM map, but Cobbs attempt to recreate the stock map for these purposes.
enoxard is offline
Old 03-14-18, 11:29 AM   #26
Noximus
It’s a straight copy of the installed map, but it resets the ECU so learning has to happen again, otherwise it’s the exact same stock map unless you install their Stage 1 map.
Noximus is offline
Old 03-14-18, 11:32 AM   #27
enoxard
checked the cobb site, it is simulated. this is not the same as the OEM map.
Originally Posted by https://www.cobbtuning.com/maps/2017-subaru-wrx-sti-installed-stock-mode-map
SIMULATED STOCK ... ECU to act like it is still stock.
COBB Tuning - 2017 Subaru WRX STI Installed Stock Mode Map
enoxard is offline
Old 03-14-18, 11:33 AM   #28
enoxard
enoxard is offline
Old 03-14-18, 11:34 AM   #29
enoxard
enoxard is offline
Old 03-14-18, 11:36 AM   #30
enoxard
holy triple post batman.. this was a site bug, not a dupe post. i dont see a way to delete the dupes, so mods please do the needful.
enoxard is offline
Similar Threads
Engine mods & Money, what a waste,,,, qwksti General Subaru Discussion 57 03-16-13 02:23 PM
COBB AccessPORT Now Available for 2012 Subaru STI and WRX COBB Tuning Vendor Announcements & Project Buildups 3 03-14-12 05:10 AM
FS: (Socal) Brand New Never Been Used Cobb Accessport AP-SUB-003 quattro ECU/Performance Electronics For Sale 3 12-29-09 05:32 PM
Interior Anodized floor mats worth the money? tnolan182 GD-General 9 04-03-09 10:09 PM
Perrin turbo inlet tube, worth the money? ride_the_pony69 2.5 Liter/Litre Factory Motor 28 09-27-05 09:09 PM
