Cobb Accesstuner Street Tuner n00b Tuning Primer - Page 5 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Cobb Accesstuner: Street Tuner n00b Tuning Primer
Old 08-23-05, 04:00 AM   #41
WolfPlayer
Feedback Score: 6 reviews
WolfPlayer is on a distinguished road
The LC-1 does come with the DataLog cable. Check out my pics here:
http://www.bescaredracing.com/sti/wideband/innovate/
WolfPlayer is offline
Old 08-23-05, 04:03 AM   #42
WolfPlayer
Originally Posted by drfrink24
Wolf,
Quick question.. I'm looking at some logging from a few weeks ago (low humidity, 55 degrees) and I'm seeing 20/22/24/30 (varys). This is the v1.04 stage2 basemap, of course, 100% throttle.
Are the values you recommend starting points, or, ending? I find it hard to beleive that cobbs shelf maps already are more aggressive than this.
These are starting points for dialing in a static map. Yes, you are right, the stock map is capable of slightly more ... but, that is very optimistic. Most people get less and this OEM timing is usually very erratic. I had my original map tuned in to slightly more aggressive timing than what was mentioned above. I started my mapping over from scratch and will be approaching the timing again. I'll post after that is done ... but, it will be a little while cause I am pretty busy right now.
t
Old 12-14-06, 04:21 PM   #43
STLSTI
Advanced Contributor Level 4
Feedback Score: 4 reviews
Car: 07 335
Fav Mod: NOISE
STLSTI is an unknown quantity at this point
WolfPlayer, I have a question about your tuning guide. But first I have to thanks you for taking the time to write this guide thus opening the tuning door to us NOOBS, again thanks. In your guide with reference to boost you say most tuners set the target boost first and then use 75% WDC high across the board. Do you mean the the last vertical row or max TP or the whole map from 0 TP to 80 TP.
Thanks,
Marcos
Super Noob
07 335i
05 STI
04 STI
STLSTI is offline
Old 12-15-06, 04:30 AM   #44
WolfPlayer
First, for those reading this thread, I'd really like to update the original article because I wrote it 1.5ys ago. That's a long time.
Second, to answer your specific question, I was referring to the last vertical row; namely, the 80% throttle column. IN NO WAY would you want to set the whole table to 75%.
t
Thanks,
Marcos
Super Noob
Old 12-15-06, 04:53 PM   #45
STLSTI
Car: 07 335
Fav Mod: NOISE
Thanks Wolf, that's what I thought.
07 335i
05 STI
04 STI
STLSTI is offline
Old 12-18-06, 02:59 PM   #46
STLSTI
Car: 07 335
Fav Mod: NOISE
Wolf were can I get the custom base map from Cobb that only uses KC A and thus converts the Dynamic Advance to be similar to a WRX.
Thanks
Marcos
07 335i
05 STI
04 STI
STLSTI is offline
Old 12-18-06, 03:38 PM   #47
crystal_Imprezav
Advanced Mastery Level I
Feedback Score: 12 reviews
Car: Slow 05 STi
Fav Mod: Loping Idle
crystal_Imprezav is an unknown quantity at this point
You need to ask Cobb for the map or use jorge's map on his website the stage2 streettuner map located at www.projectwrx.com
2005 Crystal Grey Metallic STi
New Setup:8500rpms; 600+ HP/TQ
crystal_Imprezav is offline
Old 12-21-06, 02:51 PM   #48
STLSTI
Car: 07 335
Fav Mod: NOISE
Is this the map your writing about.
2005 STI stage 2 93 oct.
Description: Cat back exhaust, K&N Typhoon, 93 octane. AVCS optimized for spool up and bottom end torque. Ignition timing optimized under part throttle and cruise positions for fuel economy. WOT AFR at 12:1 through the bottom end and midrange, tapering to 11.7 by redline.
Thanks
Marcos
07 335i
05 STI
04 STI
STLSTI is offline
Old 01-23-07, 10:48 PM   #49
mknack
Advanced Contributor Level 1
Car: 04 WRX STI
Fav Mod: APS 3.5 in tbe
mknack is on a distinguished road
Thanks for the info
mknack is offline
Old 04-30-07, 04:16 PM   #50
TraSTi
Master Contributor Level 2
Feedback Score: 2 reviews
TraSTi is on a distinguished road
Default Re: Street Tuner n00b Tuning Primer
This Info is awesome I'm on my way to tuning my car and this helped a lot but still dont' have anything too specific in my tune Trying to do something great overall but Auto X oriented so i want quick spool
SOLD: 06 STI, Aspen White & Gold
'12 WRX, Dark Gray: DP w/ Cutout, TP Stage III Tune, TMIC, and a few other things...
TraSTi is offline
