Clutch CREAK? - Page 5 - Subaru Impreza WRX STI Forums: IWSTI.com
Clutch CREAK?
Clutch CREAK?
Go Back   STI Forums > > > Clutch CREAK?
Old 03-13-08, 06:38 PM   #41
KruxSTi
Advanced Contributor Level 4
Fav Mod: 20G
KruxSTi is on a distinguished road
Default Re: Clutch CREAK?
Add mine to the list. But it only does it when i've been driving for like an hour.
KruxSTi is offline
Old 03-13-08, 07:22 PM   #42
RAPTR
Advanced Mastery Level I
Feedback Score: 3 reviews
Car: 18' STi Limited ISM
Fav Mod: Tank the Terrier!
RAPTR is on a distinguished road
Use some good grease and preferably use a grase gun with a tube nozzle. Take off our intercooler then located the throw out fork. It has that small spring hooked to it and is practically right next to the clutch master cyclinder. There's a rubber boot that protects the fork; just pop that off and look down the hole and you will see where the fork pivots on the throw out pin. Where the fork pivots is where you must grease her up. Then bammo, sweak be gone... well for me that was where the clutch creak was located. If you can't do that then you must pull the starter to get access to the pivot pin. PM me if you have questions about how to remove the pin. Good luck!
RAPTR is offline
Likes 1 Dislikes 0
Old 03-13-08, 07:26 PM   #43
starxidiam
Feedback Score: 2 reviews
starxidiam is an unknown quantity at this point
im too lazy ahah
starxidiam is offline
Old 07-17-09, 08:45 PM   #44
appletree
Advanced Contributor Level 2
Feedback Score: 4 reviews
Car: '06 WRB STI
appletree is an unknown quantity at this point
mine does it too. ill pull the i/c tomorrow and lube it up.
ill let yall know how it goes.
appletree is offline
Old 06-21-11, 07:12 AM   #45
Duke
Developing Advanced Mastery
Feedback Score: 1 reviews
Car: WRB 04 STi
Fav Mod: S202 Back-box
Duke is an unknown quantity at this point
Does anyone have pictures of what to grease on the fork? I found the slave cylinder but I'm not sure how to grease the fork without dropping **** on the clutch.
Duke is offline
Old 10-25-19, 04:47 PM   #46
Flash
Joined the Conversation
Car: 05 WRX STi
Flash is an unknown quantity at this point
Is this thread still alive? I've greased the pivot point on my 05 STi and the squeak is less but still there. There is a grease nipple located about 2 inches from the rubber boot? It looks like an obvious place to apply some grease but it's not mentioned in any of the threads that discuss the infamous clutch squeak below the intercooler.
Clutch CREAK?-grease-nipple-jpg
Flash is offline
Old 10-26-19, 09:20 AM   #47
mheyman
Fav Mod: Camber Camber Camber! Power! Wide ratio gearing! The rest is just support :)
it's not a grease fitting
Disassemble to grease. Remove starter and , remove pivot pin. Clean and grease it - takes almost none.
Sure some of you aren't firewall years?
IMHO, to justify its' price, the S209 needs to perform at least as well as my moderately powered 05 built beater, and even that might not convince me to buy one cause my next STI isn't likely to be moderately powered.
mheyman is offline
Old 10-30-19, 11:42 AM   #48
Flash
Car: 05 WRX STi
Thanks mheyman. We managed to cure the squeak without removing the starter - just greased what was accessible. What a relief - should have done this years ago. Next project is to try and stop the damned trunk lid squeak!
Flash is offline
