2010 GR Pops out of 6th - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > 2010 GR Pops out of 6th
Old 08-17-19, 06:33 PM   #1
NastyLuv
Donating Member
Car: OBP 2010 GR STI SE
Fav Mod: OEM Rubber Floormats
NastyLuv is an unknown quantity at this point
Default 2010 GR Pops out of 6th
Ok, so this has been happening for a while now and I've just put up with it. But I would like to get it sorted.
So the car shifts smooth and fine through all gears, but will not stay in 6th gear. Sometimes it will stay for a mile or two and sometimes it pops out immediately when loaded. I can hold it in 6th but it's quite a workout. Feels like the transmission is pulling against me to move the shifter forward and pop it out.
2010 GR with 99k on the ODO. Car is mostly stock. It's been like this for at least the past year. I honestly can't remember when it first started. Car has been driven normally and not abused or launched.
Fluids are fine and checked/replaced every 20k or so. Clutch is stock but hasn't slipped or anything weird since I've owned it. I do have new linkage bushings, as well as trans mount and shifter bushings that I haven't installed yet. Anything I can check off the list without dropping the tranny would be appreciated.
NastyLuv is offline
Old 08-18-19, 05:24 AM   #2
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber! Power! Wide ratio gearing! The rest is just support :)
Default Re: 2010 GR Pops out of 6th
If stock shifter and linkage and there isn't something wrong with it then tranny is the answer - unfortunately. Thats not common for ours either . . .
So happens mine is being rebuilt just now - but mine still shifted fine and stayed in gear at 235+K mi.
IMHO, to justify its' price, the S209 needs to perform at least as well as my moderately powered 05 built beater, and even that might not convince me to buy one cause my next STI isn't likely to be moderately powered.
mheyman is offline
Old 08-18-19, 09:07 PM   #3
Jedi03
Advanced Contributor Level 2
Car: Blue 2009 STi Hatch
Jedi03 is on a distinguished road
means synchro is worn...rebuild in order...
Jedi03 is offline
Old 08-22-19, 08:26 PM   #4
RocketRobin
Car: British Racing Green
Fav Mod: Snow Tires
RocketRobin is on a distinguished road
How does synchro wear?
RocketRobin is offline
Old 08-23-19, 07:19 AM   #5
GWOT
Advanced Contributor Level 1
Car: White '13 STi hatch
GWOT is on a distinguished road
I don't think you quite understand how synchros work or what it does... once it is IN gear, the synchro does nothing. How do cars without synchros shift? why does double clutching negate the need for synchro? synchros are simply friction rings that brings the neighbouring gears to the same rpm before going in gear, so you can go in gear.
GWOT is offline
Old 08-23-19, 09:58 AM   #6
Jedi03
so what keeps it in gear then? also these are not straight cut, they are diagonal so the argument is not valid...unless the gear is damaged the only other item is the synchro? Why does my Transmission pops out of gear transmissions
"..Popping out of gear is a common problem when it comes to manual transmissions. The most common reason a manual transmission would jump out of gear is due to low or contaminated fluid, worn synchronizers inside the transmission, or improperly adjusted shift linkage..."
if you have more experience than i or the linked gentleman or the other transmission gurus i go to please enlighten us...also OP please let us know what yours is so we can all learn something new!
GEAR POP-OUT CAUSES AND FIXES-GBox Transmission
WC Engineering : 5th Gear Pop-Out
i guess the other bearings could cause clearance issues, either way the most common ones include them...but again your input on why this is happening will be lovely to hear! instead of just naysaying a post with no additional technical input/backup...
Jedi03 is offline
Old 08-24-19, 10:02 AM   #7
NastyLuv
Donating Member
Hey fellas, thanks for all the input. No need for the arguing. It's not you vs them. It's "us" vs my transmission! I'm just trying to narrow it down and know what to expect to fix it. I've heard it could be the forks as these are prone to damage. I've also read it could be synchros. I'm also thinking maybe my trans mount is just so out of wack that it lets it pull it out of gear. Could be linkage. Could just be a bent shifter... I've no idea which is why I came here to ask if anyone did.
I have a full linkage bushing kit, as well as the usual front and rear shifter bushings, and a group N mount sitting in my closet. I'm not holding my breath but maybe it will sort it self out after all of that goes in. Otherwise, it's bad news bears I'm guessing.
NastyLuv is offline
