2011 STi Trans/Diff Plug Washers - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > 2011 STi Trans/Diff Plug Washers
Old 05-30-19, 02:10 AM   #1
fletcher
Becoming A Contributor
Car: SWP 11 GR Hatch
fletcher is an unknown quantity at this point
Default 2011 STi Trans/Diff Plug Washers
About to flush my trans/diff fluids and trying to find the appropriate OEM washer part numbers to replace them. I'm finding lots of differing info online and the FSM doesn't offer part numbers for washers .
For both rear diff plug washers I have found 803920050 the right fit based off my research
For the Oil pan trans plug washer I found 803926090 and then for the clutch side plug washer I found 803916100. I'm confused about the filler plug washer but assumed 1 of 803918060 or 803926090 should be it.
If anyone can confirm these part numbers that would be incredibly helpful.
Thank you!
fletcher is offline
Old 05-30-19, 04:43 AM   #2
raisingAnarchy
Becoming A Master Contributor
Car: CBS '16 STI
Fav Mod: Driver mod
raisingAnarchy will become famous soon enough
Default Re: 2011 STi Trans/Diff Plug Washers
Thank you!
I found this on the Subaru parts website, which is also the same as my '16's fill plug gasket: Trans Fill Plug - 803918040
I think I have a post on here about torque specs in case you need them. What should i do?
raisingAnarchy is offline
Old 05-30-19, 10:50 AM   #3
fletcher
About to flush my trans/diff fluids and trying to find the appropriate OEM washer part numbers to replace them. I'm finding lots of differing info online and the FSM doesn't offer part numbers for washers <img src="https://www.iwsti.com/forums/images/smilies/frown.gif" border="0" alt="" title="Sad" class="inlineimg" />.
Thank you!
I read your comment from the link. Are those the part numbers you used? And they all fit your 6 speed?
fletcher is offline
Likes 1 Dislikes 0
Old 05-30-19, 12:18 PM   #4
crick0234
Master Contributor Level 2
Feedback Score: 1 reviews
Car: DGM '12 WRX STI 5DR
Fav Mod: shortThrow Shifter
crick0234 is on a distinguished road
i can vouch for raisingAnarchy's part numbers.
Those are the part numbers i used for my 2012 STI.
from his post:
Gaskets:
Clutch housing side drain plug - 803926090
Trans drain plug - 803918060
Rear Diff Drain and Fill plugs - 803920050 (2 gaskets!)
Torque:
Clutch housing Torx T70 - 51.6 ftlb
Trans Oil pan drain/fill side - 36.9 ftlb
Rear diff drain/fill plugs - 44.3 ftlb
yup, the trans fill and trans drain uses two different gaskets, even tho they're the same bolt-plug (same part number).
If you're having difficulty or just want to see where the horse's mouth came from, you can goto parts.subaru.com and they'll have it listed there, easy to find.
i've linked my 2012 for reference:
parts diagram for rear diff **one is a drain bolt, the other is a combo thermostat/plug**:
DIFFERENTIAL (INDIVIDUAL).. For 2012 Subaru STI 2.5L TURBO 6MT 4WD WAGON | Subaru Parts Online
parts diagram to see the trans drain bolt/gasket
MT, TRANSMISSION CASE. CASE & OIL PAN.. For 2012 Subaru STI 2.5L TURBO 6MT 4WD WAGON | Subaru Parts Online
part where u can see the trans fill plug and gasket
MT, TRANSMISSION CASE. SWICH & PUMP COVER.. For 2012 Subaru STI 2.5L TURBO 6MT 4WD WAGON | Subaru Parts Online
part where u can see the clutch plug and gasket
MT, CLUTCH HOUSING.. For 2012 Subaru STI 2.5L TURBO 6MT 4WD WAGON | Subaru Parts Online
also to note for rear diff drain plug... u only need the gasket, no need for tube of gasket filler whatever its called. the FSM documents using a tube of gasket filler thingajigger, but that's only for the WRX. my local subaru shop used both, which made it suck for me cuz i had to clean that gunk out when i serviced my own diff fluids.
crick0234 is offline
Likes 2 Dislikes 0
Old 05-30-19, 12:23 PM   #5
raisingAnarchy
Car: CBS '16 STI
Fav Mod: Driver mod
Yes I ended up ordering a few of each along with other parts from subarupartsdeal.com since they mark down OEM stuff. Still shows up in OEM sealed bags too. Way better than reading off a million numbers to the parts guy at the stealership too
Old 05-30-19, 01:23 PM   #6
fletcher
from his post:
Gaskets:
Torque:
Thank you! I spent at least 2 hours on parts.subaru.com last night and kept finding differing results which just became increasingly frustrating. Good to know that you used the parts and on a relatively similar MY car too.
fletcher is offline
