GR Stumble Mod Fix: GD Style Setup (not hose extension) - Page 8 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > GR Stumble Mod Fix: GD Style Setup (not hose extension)
Old 05-23-15, 05:51 PM   #71
Goner
Becoming A Contributor
Fav Mod: $1,000 pos Expedition
Goner is an unknown quantity at this point
Default Re: GR Stumble Mod Fix: GD Style Setup (not hose extension)
Originally Posted by Gruff Gnome View Post
See my post #57 for a ghetto solution to disconnecting the fuel lines that works amazingly well.
I almost went to Walgrens to grab a Sharpie to try that, but the cotter pins worked out for me...
Goner is offline
Old 05-23-15, 06:52 PM   #72
funks
Advanced Mastery Level I
Feedback Score: 13 reviews
funks will become famous soon enough
Once you've done it more than once, much easier next time. Able to do the whole thing now in less than 20 minutes.
funks is offline
Likes 1 Dislikes 0
Old 05-24-15, 05:51 AM   #73
Goner
That's what she said?
Goner is offline
Old 05-25-15, 12:38 PM   #74
mistah
mistah is an unknown quantity at this point
I'm another sti owner ran into the stumble issue after i installed cobb OTS map. just paypaled funks for his last stumble mod fix. but from what everyone is saying, itll fix the problem with a custom tune. probably going with eric from torqued performance. Might as well get an intake along with my downpipe to make it worthwhile.
I gotten a custome tune from eric before for my wrx. Does anyone know what he baseline power for stage 2 with a downpipe and intake?
mistah is offline
Old 05-25-15, 01:01 PM   #75
funks
Don't even think the intake is worth it - I say you redirect that $$$ to an equal length header instead + up-pipe
Catted Downpipe + Up Pipe + Equal Length Header (stock catback, stock intake), keep the boost conservative (we are in California after all) and you get the following (stock intake). Tuned by Eric - only difference between the two is I went Equal (+ Up Pipe) with the blue line. Injectors per logging are below 90% IDC - so it's not maxed out.
I have the Grimmspeed Limited / Catted Downpipe (a bit pricey), Grimmspeed Up-Pipe, HKS Equal Length Header, get it Cerakoted locally and it's worth the price of admission.
Note: it's Virtual Dyno, not DynoJet but same tuner, same temp, same road, same driver.
funks is offline
Old 05-25-15, 01:49 PM   #76
mistah
Image Link
I'm still torn between going equal length or getting aftermarket unequal length header...
The benefits cylinder 2 and 4 are there and the torque but i dont know if I can give up the rumble... do you know if you get any gains from an aftermarket unequal length header?
mistah is offline
Old 05-25-15, 01:56 PM   #77
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
You won't miss the dudebro sound of inefficiency
jaz|TUNING
yamahaSHO is offline
Old 05-25-15, 03:19 PM   #78
05_white_sti
Active Participant
05_white_sti is an unknown quantity at this point
I own a 05 sti with this problem car leans out around 2500 to 3500. i have done an agency power top feed conversion with fuel rails kit, aeromotive FPR, ID2000's TGV deletes spacers. The stock fuel dampers r still on there as well should i remove them? I have been dealing with this problem for about a year now. Any help would be appreciated thanks
05_white_sti is offline
Old 05-25-15, 04:39 PM   #79
Goner
Grab a piece of fuel hose at the auto parts store, bypass it and see if it helps. You might need the Dorman connectors as per the 1st post.
Goner is offline
Old 05-25-15, 05:04 PM   #80
Kremer930
Advanced Contributor Level 3
Car: WRC Blue 08 WRX Sti
Fav Mod: Invidia Q300 TBE
Kremer930 is on a distinguished road
I would expect that the aeromotive fpr would do the job and so any standard dampeners could be removed. But I will will wait until some experienced users chime in.
Kremer930 is offline
Similar Threads
Fuel Line Extension / Stumble Fix Mod tweeked DIY Mods & Installations 449 07-17-16 07:42 AM
Stumble fix mod markusrose 2.5 Liter/Litre Factory Motor 37 08-16-15 02:19 PM
08 STI Stumble Fix: 06/07 STI FPR install? TMF 2.5 Liter/Litre Factory Motor 30 11-23-13 09:09 AM
04-08 VL Style Lips/ SEIBON Carbon Fiber Parts/ HID KITS & MORE LOW Pricing FREE S/H A1-Motorsports.com GD-Vendor Classified Ads 0 01-20-10 02:12 PM
SEIBON Hoods,Trunks, V-Limited Style Polyurethane Lips, and more Blow Out SALE A1-Motorsports.com GD-Vendor Classified Ads 7 09-08-09 08:14 PM
