GR Stumble Mod Fix: GD Style Setup (not hose extension) - Page 10 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > GR Stumble Mod Fix: GD Style Setup (not hose extension)
Old 06-08-15, 11:37 AM   #91
thundercamel
Advanced Mastery Level I
Fav Mod: Tinted windows
thundercamel is on a distinguished road
Default Re: GR Stumble Mod Fix: GD Style Setup (not hose extension)
Originally Posted by funks View Post
He added fuel dampers or removed them? Because the stock setup has two dampers and it stumbles. Removing em fix the issue with a tune.
scooby24 added two fuel dampers on an SH forester XT. I'm just surprised more people don't temporarily install a gauge to monitor the issue.
thundercamel is offline
Old 07-03-15, 04:30 PM   #92
funks
Feedback Score: 13 reviews
funks will become famous soon enough
Just an update - modified my setup to the following..
You need
1 foot of Vacuum Hose (1/4" Inner Diameter)
1/4 x 1/4 x 1/4 Vacuum T Fitting (Automotive Grade)
1/4 x 3/16 Reducer Fitting (Automotive Grade)
1/8 Vacuum Cap
Zip Ties
You can buy the items from your local AutoZone / Napa / OReilly's - less than 6$. Per Cobb the pressure source feeding the BPV is more consistent than the small nipple.
Fairly straight forward what needs to be done. Don't cut the hose feeding the BPV, hook it up to the T then add new hoses. Picture below is self explanatory..
funks is offline
Old 07-04-15, 08:53 AM   #93
STi and coffee
Advanced Contributor Level 1
Car: 2015 ISM STi Limited
STi and coffee is on a distinguished road
You need
1/8 Vacuum Cap
Zip Ties
Image Link
Will this work on a '15 STi post Stage 2+ or 3 tune? (not sure what model/mods you have)
Do you think it's necessary or will help with a stock tune? Because I'm probably a few months out on getting my parts and tune.
STi and coffee is offline
Old 07-27-15, 06:36 PM   #94
jackhossross
Fav Mod: COBB Downpipe
jackhossross is an unknown quantity at this point
i don't have a miserable stumble in mine - but still drives me nuts. im terrified to do this myself - looks scary.
jackhossross is offline
Old 07-27-15, 07:16 PM   #95
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
You need
1/8 Vacuum Cap
Zip Ties
Image Link
FPR's are one of those things you really want to have on its own dedicated vacuum line without any other tee's off the line.
jaz|TUNING
yamahaSHO is offline
Old 07-28-15, 04:46 PM   #96
Gruff Gnome
Advanced Contributor Level 2
Feedback Score: 1 reviews
Gruff Gnome is on a distinguished road
Would you mind sharing the reasoning? I tried searching but was not able to find much. Your input is much appreciated.
I purchased the cobb version ($20 seemed fair given the R&D)...BUT it really didn't do a dam thing for me, just moved the stumble around in the RPM range. I should say that about 90% of my stumble has been resolved via Funks original kit with tuning. I was hoping that this fix could have resolved the last 10%. It did not.
Gruff Gnome is offline
Old 08-22-15, 05:27 AM   #97
Kremer930
Advanced Contributor Level 3
Car: WRC Blue 08 WRX Sti
Fav Mod: Invidia Q300 TBE
Kremer930 is on a distinguished road
I have an 08 Sti that is about to receive a forged build, ID1000's and gtx3076r so I am going to move away from the extended fuel line mod and install a sard fuel pressure regulator. I have a fuel dampener to use as well if required but not sure of the best way to install it all.
I have read that some people just run a FPR and no dampener whereas others say the dampener is required.
Should the FPR be on the supply top line or the lower return line? I am thinking of a setup like the below picture. Thanks for your help.
My sard FPR.
Kremer930 is offline
Likes 1 Dislikes 0
Old 09-06-15, 04:45 PM   #98
GearGrind
Becoming A Contributor
GearGrind is an unknown quantity at this point
That thing looks purposeful
GearGrind is offline
Old 09-10-15, 04:18 PM   #99
Kremer930
Are the dampeners required in addition to a fuel pressure regulator and if so do you need one or two? I have seen examples of different combinations. My initial plan is to not run any dampener but if I have to then I will only run one.
If Murphy's law comes into play then I will have to buy another and run two....
Old 09-10-15, 06:55 PM   #100
mac_sti
Advanced Contributor Level 4
Fav Mod: Holy Header!
mac_sti will become famous soon enoughmac_sti will become famous soon enough
I've been told by a couple of tuning shops that a fpr will sufficient and no dampers are needed. The only exception that I've seen is if you are using hard lines instead of rubber.
Hope this helps.
mac_sti is offline
Similar Threads
Fuel Line Extension / Stumble Fix Mod tweeked DIY Mods & Installations 449 07-17-16 07:42 AM
Stumble fix mod markusrose 2.5 Liter/Litre Factory Motor 37 08-16-15 02:19 PM
08 STI Stumble Fix: 06/07 STI FPR install? TMF 2.5 Liter/Litre Factory Motor 30 11-23-13 09:09 AM
04-08 VL Style Lips/ SEIBON Carbon Fiber Parts/ HID KITS & MORE LOW Pricing FREE S/H A1-Motorsports.com GD-Vendor Classified Ads 0 01-20-10 02:12 PM
SEIBON Hoods,Trunks, V-Limited Style Polyurethane Lips, and more Blow Out SALE A1-Motorsports.com GD-Vendor Classified Ads 7 09-08-09 08:14 PM
