What clutch for DD with 550 + torque - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > What clutch for DD with 550 + torque
Old 05-08-19, 02:40 PM   #11
nj kiter
Becoming A Master Contributor
Feedback Score: 4 reviews
Car: aw 2005 sti !!!
Fav Mod: tbe
nj kiter is an unknown quantity at this point
Default Re: What clutch for DD with 550 + torque
Originally Posted by Noximus View Post
Do you actually "need" a clutch that can take 660 to 755 of torque?! 6 pucks aren't meant to be daily driven...
Do I "need" a Clutch that can take 660-755 of torque? Depends on how far i'm looking to push this 4 cylinder. Technically I dont "need" a clutch that high, or even "need" to own this car all together. I'm very aware that a 6 puck is not meant to be daily driven on, and I do believe I said my car was not a daily driver either so I am not worried about daily driving a 6 puck clutch.
From my understanding you dont have to have a twin disk that goes as high as you mentioned, sure they do but I do believe that exedy's and other brands offer lower holding torque capacity. I am hoping someone with real world twin disk experience can chime in about pedal pressure between a single disk traditional clutch and a twin disk kit designed to hold the same amount of torque?
nj kiter is offline
Old 05-08-19, 03:07 PM   #12
[email protected]
Car: 2011 STI Sedan
Fav Mod: Arcflash LLC Ohlins Coilovers
joshua@arcflashllc is on a distinguished road
The DS isn't moving if the car isn't moving..
Yes, well some of the issues were misfires at idle while sitting in traffic, etc.
COBB Pro-Tuner/Dealer <-10% OFF SALE NOW THROUGH 11/26!!!!!!
Custom valved and sprung Ohlins Coilovers
Antigravity Battery <-- SAVE 22 LBS!!
SPL Suspension Components
joshua@arcflashllc is offline
Old 05-08-19, 03:21 PM   #13
[email protected]
Car: 2011 STI Sedan
I run a twin plate in my Porsche and while it'll hold plenty of power it's awful in traffic!
Old 05-08-19, 03:30 PM   #14
Noximus
Advanced Mastery Level II
Feedback Score: 3 reviews
Fav Mod: 2015 STI Steering Rack!
Noximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really nice
Probably from the rev up and down while inching forward etc. It’s been a few years since I’ve done that research.
Noximus is offline
Old 05-08-19, 03:33 PM   #15
[email protected]
Car: 2011 STI Sedan
The driveshaft basically isn't doing anything in that situation. I'm not trying to argue with you at all. I was just trying to be funny. The flywheel/clutch revs with the motor. The DS does not. It just moves if the car moves so it's not going to have any effect on that issue. Just like lightweight wheels or brakes wouldn't either.
Likes 1 Dislikes 0
Old 05-08-19, 07:38 PM   #16
mheyman
Fav Mod: Camber Camber Camber
You’re saying a CF DS doesn’t reduce your rotational mass? Really? What clutch for DD with 550 + torque
There have been documented issues when using a CF DS, 12lbs lightweight flywheel, and a lightweight crank pulley. They have fixed it by going with a heavier lightweight flywheel, return to the OEM flywheel, return to the OEM crank pulley or to a Fluidampr crank pulley.
Error on my part, meant crank-shaft. Rotational mass meant of the engine, any sensors and the codes they might trigger.
ADDED: Sure I've read of cases where lightweight rotating assembly, (the parts that should be balanced together) created problems that were cured by swapping those parts - sometimes with heavier parts. Make me wonder how far you have to go, IE very lightweight rotating assembly, strong cam springs and large cams, and tune, or how poor a job you have to do overall to make that happen - cause I believe some people run all that and don't have problems. Anyway . .
the DS will not affect them.
Porshe parts are always so pretty! Need one just to have a reason to buy them!
NJ-Kiter? You doin the install?
mheyman is offline
Old 05-09-19, 03:11 PM   #17
nj kiter
Fav Mod: tbe
Thanks guys, If i were to not do a twin disk i would shoot for a full faced clutch as the 6 puck though is great for what its advertised for does not last as long as other kinds. Yes mheyman i would be doing the install myself.
nj kiter is offline
Old 05-12-19, 05:20 PM   #18
user1029
Advanced Mastery Level V
Feedback Score: 5 reviews
Fav Mod: HTA86.
user1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud of
I've been driving an ACT 6puck + stock flywheel for 40,000 miles now and it is very tolerable for me
user1029 is offline
Similar Threads
OAKOS Automotive - Kartboy, Grimspeed, Perrin & MORE - In Stock Ready to Ship OAKOSAutomotive GD-Vendor Classified Ads 43 05-15-19 12:53 PM
INCREDIBLE Deals: South Bend, Clutch Masters, GrimmSpeed, ID, Kartboy, SuperPro &More CygnusPerformance GD-Vendor Classified Ads 72 11-21-17 02:25 PM
SOLD: BNIB: Clutch Masters FX300 for STi ****PRICE DROP**** 590 SHIPPED!!!! Frank-i-e Engine/Drivetrain/Performance Parts For Sale 16 03-23-14 03:37 PM
Clutch Masters FX100-FX500 Clutch Kits ON SALE! RT Tuning GD-Vendor Classified Ads 4 04-22-13 06:56 AM
Complete Clutch kits-Clutch/Flywheel/Clutch Line/Fluid $675 Shipped Gruppe-S GD-Vendor Classified Ads 13 09-19-08 04:42 PM
