How to correct High fuel pressure on a new build STI? - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > How to correct High fuel pressure on a new build STI?
Old 03-30-19, 03:04 PM   #11
05 CGM Sti
Advanced Contributor Level 5
Feedback Score: 3 reviews
Car: 19 CWP Sti
Fav Mod: Not being pulled over
05 CGM Sti is an unknown quantity at this point
Default Re: How to correct High fuel pressure on a new build STI?
Listen to Noximous. Remove the vacuum line and start from there. Sounds like your tuner doesn't know jack shit and you should be looking for a new one
2019 CWP STi - Only mod is a 3" Cobb Titanium cat back exhaust
Gone but not forgotten
2004 Audi S4
2005 CGM STi
2007 WRB STi
05 CGM Sti is offline
Old 03-30-19, 04:09 PM   #12
Noximus
Advanced Mastery Level II
Fav Mod: 2015 STI Steering Rack!
Noximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really nice
Originally Posted by MY15STI View Post
The idle pressure needs to be at around 42ish psi, but it is at 58+ psi. The Aeromotive FPR can't lower it anymore.
As we’ve been eluding to, but you haven’t answered on it yet, are those numbers with the vacuum line disconnected from the FPR? Base idle pressure needs to be set with the vacuum line disconnected.
Noximus is offline
Old 03-31-19, 10:01 AM   #13
MY15STI
Advanced Contributor Level 2
Feedback Score: 1 reviews
MY15STI is on a distinguished road
Originally Posted by yamahaSHO View Post
If you turn off the pump in the tank, the surge tank will eliminate the factory hanger situation. If you cannot lower the base pressure when you disconnect power to the in-tank pump, your regulator is bad.
Just want to clarify. Do i unplug the harness on the oem fuel pump, turn on the power (not starting up), then adjust the FPR to see if it will get lower the base pressure? Thanks.
MY15STI is offline
Old 03-31-19, 10:06 AM   #14
MY15STI
The line was connected still. Do i need to plug the port on the FPR or the vacuum line if i disconnect it? thanks.
MY15STI is offline
Old 03-31-19, 11:37 AM   #15
Noximus
Default How to correct High fuel pressure on a new build STI?
That’s your problem. You remove it and can clamp it, but not required. It’s a tiny hose. Don’t need to plug the hole on the FPR.
Noximus is offline
Likes 1 Dislikes 0
Old 03-31-19, 12:52 PM   #16
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
You can pull the power on the in-tank pump before or after starting.
Although you set base pressure with no boost or vacuum, if you could not get it lower with vacuum, you're not going to lower it just by pulling the reference hose. Vacuum is supposed to bring pressure down even more.
If you just jump the pump in the surge tank on without starting the car, you can set pressure without removing the power to the in-tank pumps and without removing the reference line. This also eliminates the factory hanger.
yamahaSHO is offline
Old 03-31-19, 12:59 PM   #17
MY15STI
The fuel pressure is the same at 58 psi with the vacuum line disconnected from the FPR.
Should i try to adjust the FPR with the vacuum line disconnected? thanks.
MY15STI is offline
Old 03-31-19, 01:50 PM   #18
yamahaSHO
BROtuner
Car: 2005 WRB
Do what I suggested with jumping the surge tank pump to run with the car off.
If the FPR won't lower fuel pressure with vacuum on it, removing the reference line will not lower it anymore.
Old 04-07-19, 09:41 AM   #19
MY15STI
Problem solved. Got an advice from Radium, it was probably the jet pump in the OEM fuel hangar was too restrictive, creating back pressure.
So I installed a Radium fuel hangar with a WB 450, the pressure came back down, still has room for adjustment with the FPR.
Thanks everyone for your advice.
MY15STI is offline
Old 04-07-19, 02:28 PM   #20
yamahaSHO
BROtuner
Car: 2005 WRB
So... Same thing I was trying to get you to test for.
Likes 1 Dislikes 0
Similar Threads
Engine What Oil will you use? APEXIT53 2015+ STI Discussion 893 10-20-18 06:35 AM
FS (USA,NJ): COBB 2008+ GD STI Fuel Pressure Regulator Fuel Line Kit - SOLD 12obsti Engine/Drivetrain/Performance Parts For Sale 0 09-08-15 11:46 AM
Another dead piston!!! Turninconcepts.com 2.5 Liter/Litre Factory Motor 377 06-15-14 11:12 PM
FS (USA,TX): Walbro 255LPH High Pressure fuel pump $40 shipped BAD STI Engine/Drivetrain/Performance Parts For Sale 0 12-13-10 10:57 AM
OBD-II Codes (CEL Light Codes) 201Motorsports 2.5 Liter/Litre Factory Motor 8 06-03-09 03:19 PM
