Metal in AVCS mechanisms - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Metal in AVCS mechanisms
Old 11-29-18, 06:42 PM   #11
putrio
Becoming A Contributor
Car: Black '11 WRX STi
Fav Mod: AP V3
putrio is an unknown quantity at this point
Default Re: Metal in AVCS mechanisms
Originally Posted by UrdnotWrexSTi View Post
Why are you cleaning them in the first place? Did you spin a bearing or just wanted to be thorough in your build?
Yup, car was...guzzling oil I guess, and long story short, spun bearing, rod knock. I did manage to get the shims out of the exhaust avcs gears, and I cleaned it all as best as I could. The small pin that aligns the lobed part to the housing I've heard can get sheared off if you use the belt method to remove, or if you use a company 23 tool, and mine both look a little bit bent...but intact. That's what I was going to take a picture of. Since I was able to get the springs and clips out and clean everything, I decided I'll just reuse all four gears. If I'm mistaken in this next bit, please correct me, but I don't think an avcs seizing up or being misaligned will cause a catastrophic failure, so I can hold off on replacing those.
One more note....those exhaust springs are really tough to get back on. I used a set of vice grips about 2/3 the way back around the spring to twist it back into place and used my other hand to fight the bent part of the spring into the center hole. The method worked extremely well on the second one....learning curve, I guess.
putrio is offline
Old 11-30-18, 04:00 AM   #12
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber
Although functionality is important, isn't the risk is that a piece of metal gets to a bearing and provides you with the pleasure of redoing the whole experience.
You know how well you cleaned em . . . sounded thorough here I'd still like to know where the brass came from and why it was so embedded. The solenoids are brass?
mheyman is offline
Old 11-30-18, 10:53 AM   #13
UrdnotWrexSTi
Feedback Score: 2 reviews
Car: Aspen White GR STi
Fav Mod: Coilovers
UrdnotWrexSTi will become famous soon enough
Honestly, these gears are very important to the timing of our engines, so anything seizing inside these gears could eventually lead to failure somewhere. I didn't post on the forum, but I actually underwent a second rebuild due to a burnt valve. Which I attributed to my AVCS exhaust gear being damaged. This made the AFRs lean out under boost and I think is what burnt that valve. Anyway, this time I dropped in an IAG closed deck block and got the heads on a mild build. Now it's making 505hp
Okay, so as far buying new gears, if you're worried something is damaged inside, then learn from me and just replace the whole gear. Like I said they do a lot for the timing of the engine.
Looking at that retainer you took a picture of, it actually doesn't look like brass to me, technically there shouldn't be any. To me it looks like it's copper or some other metal that's in bedded itself in the plastic, and since metal should NOT be anywhere near those gears, I'd say you've probably been burning up a bearing for a little while and it contaminated your whole oiling system. Check your heads for the same metal particles as well, and make sure to check the camshaft journals and the surface where the camshafts ride on. Turbo could also be compromised.
UrdnotWrexSTi is offline
Old 12-01-18, 04:05 AM   #14
mheyman
I could not tell from the pic, but copper makes far more sense than brass - far more since you spun a bearing. Seeing this though it Makes me feel feel much better about IAGs insistence on replacing my cam gears. In fact it was about thew only thing they insisted on, and at the time I thought it might have been over-kill. My car did not spin a bearing, but copper was visible on the bearings themselves. Paying them to clean em would not have been cost effective. They did not push anything else on me.
mheyman is offline
Similar Threads
2018 STI - Intake AVCS non functional (both sides) Johnc 2.5 Liter/Litre Factory Motor 0 09-05-18 02:46 PM
AVCS Gear Cleaning Guide! (Read this if you spun a bearing!) UrdnotWrexSTi 2.5 Liter/Litre Factory Motor 20 07-08-18 02:06 PM
The Secret to the best exhaust daddysscp GD-Vendor Classified Ads 105 06-26-08 09:36 AM
MadDad(TM) Metal Catted Bellmouth & Essential Catless daddysscp Vendor Group Buys 0 06-26-07 08:16 AM
Pre-Order Discounts: New MadDad(TM) Metal V2 One-Piece Catted Downpipe daddysscp Vendor Group Buys 20 03-05-06 12:26 AM
