How to clean oil-related components? - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > How to clean oil-related components?
Old 11-06-18, 11:09 AM   #11
UrdnotWrexSTi
Feedback Score: 2 reviews
Car: Aspen White GR STi
Fav Mod: Coilovers
UrdnotWrexSTi will become famous soon enough
Default Re: How to clean oil-related components?
Originally Posted by putrio View Post
I'm curious about this - why is resurfacing necessary?
Also, I got the intake manifold off yesterday (along with the turbo, up-pipe*, starter, secondary air pump and various brackets and shields), and the gasket surfaces have remnants of the gaskets on them. How robust are these surfaces, how hard can I scrub to clean?
*Stock up-pipe has the shell surrounding the ceramic heat shield (or whatever is inside) completely detached from the welds. Is this usable, or do I need a replacement?
Resurfacing ensures the most flat surface possible on the deck on the head, and you want flatness to ensure a perfect head gasket seal. The machinist you use should take off the most minimal amount of material possible to start, then work down by thousandth's of an inch.
UrdnotWrexSTi is offline
Old 11-06-18, 11:13 AM   #12
UrdnotWrexSTi
Fav Mod: Coilovers
Why would I not have the banjo filter, just if I'd done work and removed it previously?
Turbo exhaust side has a crack in the iron housing...but that seems to be somewhat "normal" from what I'm reading online?\
Yes, its common for techs to remove all banjo filters as this is an official SOA service recommendation. If you had your car worked on where any oil related parts were messed with, it's possible the banjo filter were removed.
Yes, wastegate cracks are common for VF turbos. If it's tiny then it's not a problem, but big cracks can turn into an issue.
Similar Threads
Engine What Oil will you use? APEXIT53 2015+ STI Discussion 893 10-20-18 06:35 AM
Motor Oil - All Chapters, Inclusive -Hat Tip to Ferrarichat.com thrlskr 2.5 Liter/Litre Factory Motor 40 08-17-17 03:04 PM
ZDDP... another oil thread SubySal 2.5 Liter/Litre Factory Motor 3 10-02-15 02:35 PM
Engine Well I have 3819 Miles on my 2015 STi..BLOWN MOTOR Arfrce 2015+ STI Discussion 279 02-23-15 04:14 PM
Oil change Instructions for Men & Women! SpeedingTicketsIncluded Off Topic 6 10-29-11 08:16 PM
