Engine, Suspension, Brakes & MORE | Kartboy, Whiteline, Perrin, Grimmspeed... | OAKOS
Fast Shipping, Low Prices, Dependable Service. We deliver performance!
Trust our experienced, friendly staff, large warehouse, and years of service experience
to help you reach all of your performance goals!
Why Buy From OAKOS?
Below is a list of Popular sellers, if you see something that is not listed, please make sure to PM us odds are we have access to it!
Also make sure to PM us regarding Forum Member pricing.
Kartboy
Subaru (OEM)
Company23
Grimmspeed
Why Buy From OAKOS?
Kartboy
- Kartboy Exhaust Hanger (Black, 12mm), 2008-2019 WRX/STi & BRZ/FR-S/86 - $32.00 - Free Shipping!
- Kartboy XL Long Exhaust Hanger (12mm), Black, 2008-2019 WRX/STi & BRZ/FR-S/86 - $36.00 - Free Shipping!
- Kartboy Rear Shifter Stay Bushing, 2002-2014 WRX & 2004-2019 STi & BRZ/FR-S - $35.00 - Free Shipping!
- Kartboy Shifter Bushings (Front, 6-Speed), 2004-2019 STi - $32.00 - Free Shipping!
- Kartboy Short Throw Shifter, 2004-2019 STi - $150.00 - Free Shipping!
- Kartboy Short Throw Shifter w/Front Bushings Combo, 2004-2019 STi - $175.00 - Free Shipping!
- Kartboy Lightweight Crank Pulley (For Single Belt), 2002-2014 WRX & 2004-2019 STi - $125.00 - Free Shipping!
- Kartboy Lightweight Crank Pulley (V2), 2002-2014 WRX & 2004-2019 STi - $100.00 - Free Shipping!
- Kartboy Front Sway Bar End Links, 2002-2007 WRX Sedan & 2004-2017 STi & 2008-2014 WRX (ALL) - $115.00 - Free Shipping!
- Kartboy Sway Bar End Links (Rear, Solid), 2008-2018 WRX/STi & 2013+ BRZ - $125.00 - Free Shipping!
- Kartboy Front Sway Bar End Links, 2015-2018 STi - $125.00 - Free Shipping!
- Kartboy Sway Bar End Links (Front & Rear Combo), 2002-2013 WRX & 2004-2017 STi - $230.00 - Free Shipping!
- Kartboy Pitch Stop Mount (Pitching Stopper), 2002-2014 WRX & 2004-2019 STi - $120.00 - Free Shipping!
- Kartboy Rear Differential WedgeLock Kit, 2015-2019 WRX & STi - $90.00 - Free Shipping!
- Kartboy License Plate Delete (Black), 2002-2017 WRX & 2004-2017 STi - $27.50 - Free Shipping!
- Kartboy License Plate Delete (Silver), 2002-2017 WRX & 2004-2017 STi - $27.50 - Free Shipping!
- Kartboy Shift Knob (Delrin, Black, 6-Speed), 2004-2019 STi & 2015-2019 WRX - $45.00 - Free Shipping!
- Kartboy Shift Knob (Delrin, White, 6-Speed), 2004-2019 STi & 2015-2019 WRX - $45.00 - Free Shipping!
- Kartboy Shift Knob (Aluminum, Black, 6-Speed), 2004-2019 STi & 2015-2019 WRX - $45.00 - Free Shipping!
- Kartboy Shift Knob (Stainless Steel, 6-Speed), 2004-2019 STi & 2015-2019 WRX - $60.00 - Free Shipping!
- Kartboy Shift Knob (Aluminum, Silver, 6-Speed), 2004-2019 STi & 2015-2019 WRX - $45.00 - Free Shipping!
- Kartboy Battery Tie Down, 2002-2019 WRX & 2004-2019 STi & BRZ/FR-S/86 - $35.00 - Free Shipping!
- Kartboy Oil Cap (Black, Delrin), 2002-2014 WRX & 2004-2019 STi - $45.00 - Free Shipping!
- Kartboy Oil Cap (Black, Aluminum), 2002-2014 WRX & 2004-2019 STi - $45.00 - Free Shipping!
- More Kartboy...
Subaru (OEM)
- Subaru (OEM) Donut Gasket (Large), 2002-2019 WRX & 2004-2019 STi & BRZ/FR-S/86 - $18.40
- Subaru (OEM) Turbo to Downpipe Gasket, 2002-2014 WRX & 2004-2019 STi - $22.50
- Subaru (OEM) Exhaust Gasket, 2015-2019 WRX & 2015-2019 STi - $5.61
- Subaru (OEM) Exhaust Flange Nut (Various Locations), Nearly All Subarus - $4.63
- Subaru (OEM) Muffler (Right), 2018 STi Type RA - $375.00 - Free Shipping!
- Subaru (OEM) Muffler (Left), 2018 STi Type RA - $375.00 - Free Shipping!
- Subaru (OEM) WRX Logo Valve Stem Caps, Subaru (All) - $14.95
- Subaru (OEM) Brake Fluid, Subaru (All) - $6.16
- Subaru (OEM) Spark Plug (NGKSILFR6A, Each), 2008-2014 WRX & 2008-2018 STi - $14.36
- Subaru (OEM) Ignition Coil Pack Assembly, 2011-2019 STi & 2011-2014 WRX - $98.56
- Subaru (OEM) Spark Plug (ILFR7H, Type RA, Each), 2018-2019 STi Type RA - $19.95
- Subaru (OEM) Front O2 Sensor, 2015-2019 STi - $203.28 - Free Shipping!
- Subaru (OEM) O2 Sensor (Rear), 2008-2019 STi - $144.46
- Subaru (OEM) Camshaft Sensor, 2004-2019 STi & 2006-2014 WRX - $100.38
- Subaru (OEM) STi Stiffer Shifter Bushings, 2010-2019 STi & 2010-2014 WRX - $25.95
- Subaru (OEM) Short Throw Shifter, 2004-2019 STi - $335.75 - Free Shipping!
- Subaru (OEM) Union Banjo Bolt, 2002-2018 WRX & 2004-2019 STi - $11.57
- Subaru (OEM) Union Bolt, 2004-2019 STi, 2006-2018 WRX & 2013+ BRZ - $7.03
- Subaru (OEM) Oil Pickup Strainer Tube, 2006-2019 STi & 2006-2014 WRX - $28.60
- Subaru (OEM) Oil Filter, 2002-2014 WRX & 2004-2019 STi - $8.88
- Subaru (OEM) Oil Pan, 2006-2019 STi & 2006-2014 WRX - $109.50
- Subaru (OEM) Oil Level Dip Stick, 2006-2019 STi - $14.32
- Subaru (OEM) Oil Pan Gasket, 2011-2019 STi - $7.65
- Subaru (OEM) Oil Pump (11mm), 2008-2019 STi - $160.96
- Subaru (OEM) Oil Pump Shim, 2002-2014 WRX & 2004-2019 STi - $0.99
- Subaru (OEM) STi 12mm Oil Pump, 2002-2014 WRX & 2004-2019 STi - $219.00 - Free Shipping!
- Subaru (OEM) Coolant Hose From Hardpipe to Oil Cooler, 2002-2014 WRX & 2004-2019 STi - $11.57
- Subaru (OEM) Oil Cooler Delete Fitting, 2002-2014 WRX, 2004-2019 STi & BRZ/FR-S/86 - $7.36
- Subaru (OEM) Water Pump & Cam Cap Bolts (Various), 2002-2014 WRX & 2004-2019 STi - $2.17
- Subaru (OEM) Timing Belt Cover Gasket (#1 Right), 2004-2019 STi & 2006-2014 WRX - $3.72
- Subaru (OEM) Timing Belt Cover Gasket (RHD, Lower), 2002-2014 WRX & 2004-2019 STi - $3.72
- Subaru (OEM) Timing Belt Cover Gasket (Behind RH Rear Cover), 2002-2014 WRX & 2004-2019 STi - $3.48
- Subaru (OEM) Timing Belt, 2002-2014 WRX & 2004-2019 STi - $127.46
- Subaru (OEM) AVCS Cam Sprocket Pulley (Intake, RH), 2004-2019 STi & 2006-2014 WRX - $179.00
- Subaru (OEM) Timing Belt Idler Pulley Bolt, 2002-2014 WRX & 2004-2019 STi - $1.94
- Subaru (OEM) Timing Belt Cover Gasket (#1 Right), 2004-2019 STi & 2006-2014 WRX - $4.17
- Subaru (OEM) Sealing Belt Cover, 2002-2014 WRX & 2004-2019 STi - $2.59
- Subaru (OEM) Crankshaft Pulley, 2004-2014 WRX & 2004-2019 STi - $179.96
- Subaru (OEM) Engine Mount Nut, 2013-2019 STi & 2015-2019 WRX - $3.71
- Subaru (OEM) STi Group N Pitching Stopper, 2002-2019 WRX & STi - $52.50
- Subaru (OEM) Water Pipe, 2006-2019 STi & 2006-2007 WRX - $132.12
- Subaru (OEM) STi High Pressure Radiator Cap (1.3 Bar), 2002-2014 WRX & 2004-2019 STi - $66.95
- Subaru (OEM) Coolant Over Flow Cap, 2002-2019 WRX & 2004-2019 STi & BRZ/FR-S/86 - $4.78
- Subaru (OEM) Radiator Cap, 2002-2019 WRX & 2004-2019 STi - $15.32
- Subaru (OEM) Long Life Coolant (1 Gallon), Universal - $26.69
- Subaru (OEM) Premixed Long Life Super Coolant (1 Gallon), Subaru Engines - $25.44
- Subaru (OEM) Thermostat (172 Degree), 2002-2014 WRX & 2004-2019 STi - $20.63
- Subaru (OEM) STi Group N Transmission Mount, 2004-2017 STi & 2008-2014 WRX - $83.00
- Subaru (OEM) Panel Air Filter Element, 2008-2018 WRX & STi & 2009-2013 Forester - $21.95
- Subaru (OEM) Fuel Filter, 2008-2014 WRX & 2008-2018 STi - $71.96
- Subaru (OEM) Fuel Injector Top Seals (Set/4), 2002-2014 WRX & 2007-2019 STi & BRZ/FR-S/86 - $44.60
- Subaru (OEM) Return Line Clamp, 2002-2014 WRX & 2004-2019 STi - $3.38
- Subaru (OEM) Turbo Oil Return Hard Line, 2004-2019 STi - $54.37
- Subaru (OEM) IHI VF48 Turbocharger, 2002-2007 WRX & 2004-2019 STi - $1,299.09 - Free Shipping!
- Subaru (OEM) O-Ring For Intake AVCS Sprocket, 2004-2019 STi & 2006-2014 WRX - $3.85
- Subaru (OEM) O RING, 2002-2014 WRX & 2004-2019 STi - $4.12
- Subaru (OEM) Cylinder Block Plug, 2002-2014 WRX & 2004-2019 STi - $11.37
- Subaru (OEM) Intake Manifold to TGV Gaskets (Pair), 2002-2014 WRX & 2004-2019 STi - $22.30
- Subaru (OEM) Engine Overhaul Gasket Kit, 2008-2018 STi - $289.23 - Free Shipping!
- Subaru (OEM) Engine Overhaul Gasket Kit, 2018 STi Type RA - $347.97 - Free Shipping!
- Subaru (OEM) AVCS Control Valve Gasket (Exhaust, Left Hand), 2008-2018 STi - $4.35
- Subaru (OEM) AVCS Control Valve Gasket (Exhaust, Right Hand), 2008-2018 STi - $4.35
- Subaru (OEM) Self Locking Nut (Top Of Strut Piston), 2002-2019 WRX & 2004-2019 STi & BRZ/FR-S/86 - $2.71
- Subaru (OEM) Flange Nut Front Strut Lower, 2018-2019 STi - $4.25
- Subaru (OEM) Self Locking Nut (Rear Strut Bottom), 2017-2019 STi - $4.80
- Subaru (OEM) Flange Nut (Strut Tops To Chassis), 2015-2019 STi & 2015-2019 WRX - $1.70
- Subaru (OEM) Nut For Strut Piston And Strut Top To Body, 2011-2019 WRX/STi & BRZ/FR-S/86 - $1.70
- Subaru (OEM) Strut Spacer Front, 2002-2019 WRX & 2004-2019 STi - $4.35
- Subaru (OEM) Rear Strut Top (Pair/2), 2008-2019 WRX/STi & 2013+ BRZ/FR-S/86 - $149.90
- Subaru (OEM) Front Strut Top (Each), 2008-2019 WRX & STi - $74.45
- Subaru (OEM) Upper Rubber Spring Seat, 2008-2019 WRX/STi & 2013+ BRZ/FR-S/86 - $15.13
- Subaru (OEM) Oil Return Cover, 2004-2019 STi & 2006-2014 WRX - $3.34
- Subaru (OEM) Oil Separator Cover Plate, 2002-2014 WRX & 2004-2019 STi - $33.60
- Subaru (OEM) EJ257 Engine Block (Case Half Castings Only), 2004-2019 STi & 2002-2014 WRX - $1,183.12 - Free Shipping!
- Subaru (OEM) Crankshaft Main Bearings (Set), 2002-2014 WRX & 2004-2020 STi - $171.29
- Subaru (OEM) Rod Bearings, 2004-2020 STi & 2006-2014 WRX - $142.48
- Subaru (OEM) Crankshaft EJ257 (Induction Hardened), 2004-2019 STi - $320.51 - Free Shipping!
- Subaru (OEM) Crankshaft EJ257 (Not Treated), 2004-2019 STi - $343.40 - Free Shipping!
- Subaru (OEM) Forged Crank Shaft, 2004-2019 STi & 2006-2014 WRX - $324.33 - Free Shipping!
- Subaru (OEM) Crankshaft EJ257, 2004-2019 STi - $320.51 - Free Shipping!
- Subaru (OEM) Piston Wrist Pin Access Cover, 2002-2014 WRX & 2004-2019 STi - $12.95
- Subaru (OEM) Piston Ring Set (Standard Size), 2008-2018 STi - $157.36
- Subaru (OEM) Exhaust Valve (Each), 2002-2014 WRX & 2004-2019 STi - $66.51
- Subaru (OEM) Valve Lifter Bucket (5.45mm, 0.2146"), 2003-2014 WRX & 2004-2019 STi - $32.55
- Subaru (OEM) Valve Lifter Bucket (4.79mm, 0.1886"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Lifter Bucket (5.33mm, 0.2098"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Lifter Bucket (5.13mm, 0.2020"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Lifter Bucket (5.16mm, 0.2031"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Lifter Bucket (4.97mm, 0.1957"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Lifter Bucket (5.01mm, 0.1972"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Lifter Bucket (5.14mm, 0.2024"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Lifter Bucket (5.61mm, 0.2209"), 2003-2014 WRX & 2004-2019 STi - $32.55
- Subaru (OEM) Valve Lifter Bucket (5.21mm, 0.2051"), 2003-2014 WRX & 2004-2019 STi - $29.58
- Subaru (OEM) Valve Lifter Bucket (5.31mm, 0.2091"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Lifter Bucket (5.20mm, 0.2047"), 2003-2014 WRX & 2004-2019 STi - $26.63
- Subaru (OEM) Valve Cover (Left), 2004-2019 STi & 2006-2014 WRX - $99.00
- Subaru (OEM) Cylinder Head Plug (M20), 2002-2014 WRX & 2004-2019 STi - $7.37
- Subaru (OEM) Boss-Traverse Link, 2004-2019 STi - $15.48
- Subaru (OEM) Brembo Caliper Bolt (Rear), 2008-2019 STi - $3.71
- Subaru (OEM) Brembo Seal Kit (Front), 2004-2017 STi - $114.14
- Subaru (OEM) Brembo Seal Kit (Front), 2018-2019 STi - $184.58
- Subaru (OEM) Brembo Seal Kit (Rear), 2018-2019 STi - $103.77
- Subaru (OEM) Slide Pin Clip (Brembo), 2004-2017 STi - $6.67
- Subaru (OEM) Slide Pin (6-Piston Brembo), 2018-2019 STi - $13.85
- Subaru (OEM) Brake Bleeder Screw, 2004-2019 STi - $7.63
- Subaru (OEM) Driveshaft to Flange Bolt, 2003-2019 WRX & 2004-2019 STi - $1.56
- Subaru (OEM) Driveshaft to Flange Nut, 2002-2019 WRX & STi & BRZ/FR-S/86 - $1.39
- Subaru (OEM) CV Boot Grease, Universal - $14.85
- Subaru (OEM) Vortex Generator, 2015-2019 WRX & 2015-2019 STi - $75.05
- Subaru (OEM) Clip, No. 5, 2006-2014 WRX & 2004-2016 STi - $2.11
- Subaru (OEM) PCV Hose, 2002-2007 WRX & 2004-2016 STi - $11.57
- Subaru (OEM) PCV Hose Assembly, 2004-2006 WRX & 2004-2016 STi - $36.13
- Subaru (OEM) Solenoid, 2004-2019 STi & 2006-2007 WRX - $107.52
- Subaru (OEM) Center Arm Rest Extension, 2008-2019 WRX & STi - $122.40
- Subaru (OEM) Shifter Boot, 2015-2019 WRX & STi - $74.07
- Subaru (OEM) Shifter Trim Ring, 2015-2017 WRX & STi - $49.37
- Subaru (OEM) All Weather Floor Mats, 2015-2018 STi & 2015-2018 WRX - $75.95
- Subaru (OEM) Lower Ball Joint Castle Nut, 2002-2019 WRX & STi & 2013-2019 BRZ/FR-S/86 - $1.80
- Subaru (OEM) Rain Guards, 2015-2019 WRX & 2015-2019 STi - $107.96
- Subaru (OEM) Power Steering Pump, 2008-2019 STi & 2015-2019 WRX - $409.99 - Free Shipping!
- Subaru (OEM) STi Carbon Fiber Trunk Trim, 2015-2019 WRX & STi - $189.05
- Subaru (OEM) 'Type RA' Front Emblem, 2018-2019 STi Type RA - $47.10
- Subaru (OEM) 'Type RA' Rear Letter Mark Emblem, 2018 STi Type RA - $61.68
- Subaru (OEM) Transmission Input Shaft Seal, 2004-2019 STi - $18.50
- Subaru (OEM) Transmission Bolt, 2004-2019 STi & 2002-2014 WRX - $2.30
- Subaru (OEM) Rear Differential Oil Seal, 2002-2019 WRX & 2004-2019 STi - $8.40
- Subaru (OEM) Rear Diff Front Flange For 6MT Swap, 2004-2019 STi - $95.00
- Subaru (OEM) Input Seal R180, 2004-2019 STi - $18.48
- Subaru (OEM) Rear Differential Drain Plug Gasket, 2008-2019 STi - $4.55
- Subaru (OEM) Cabin Air Filter, 2008-2019 WRX & 2008-2019 STi - $23.17
- Subaru (OEM) Steering Wheel, 2018 STi Type RA - $503.16 - Free Shipping!
- More Subaru (OEM)...
Company23
- Company23 Cam Lock Tool, 2002-2014 WRX & 2004-2020 STi - $44.96 - Free Shipping!
- Company23 v2 Crank Pulley Tool, 2002-2014 WRX & 2004-2020 STi - $57.95 - Free Shipping!
- Company23 AVCS Intake Cam Sprocket Tool, 2004-2020 STi & 2006-2014 WRX - $44.96
- Company23 Dual AVCS Exhaust Cam Sprocket Tool, 2008-2020 STi - $35.96
- Company23 AVCS Pulley 5-Sided Tool, 2004-2020 STi & 2006-2014 WRX - $9.95
- Company23 Crankshaft Socket Tool, 2002-2014 WRX & 2004-2020 STi - $35.96
- Company23 Fuel Line Disconnect Tool, 2005-2014 WRX/STi & 2013-2020 BRZ - $14.95
- Company23 Valve Spring Compressor Tool, 2002-2014 WRX & 2004-2020 STi - $76.46 - Free Shipping!
- Company23 Stretch Belt Tool, 2008-2017 WRX & 2008-2020 STi - $28.95 - Free Shipping!
- Company23 Sundial Bearing Carrier Tool 2, Most 1993-2020 Subaru Transmissions - $53.96
- Company23 Sundial Bearing Carrier Tool 1, Most 1993-2020 Subaru Transmissions - $44.96
- Company23 Timing Belt Guide Kit, 2002-2014 WRX & 2004-2020 STi - $49.46 - Free Shipping!
- Company23 Anti-Surge Boost Control Solenoid, 2008-2020 STi - $206.96 - Free Shipping!
- Company23 Standard Boost Control Solenoid, 2008-2020 STi - $71.96 - Free Shipping!
- Company23 Top Mount Intercooler Stud Kit, 2002-2007 WRX & 2004-2020 STi - $7.95
- Company23 Piston Ring Compressor (96.52mm-100.33mm), 2004-2020 STi & 2006-2014 WRX - $40.46
- Company23 Torque Plate (EJ25), 2004-2020 STi & 2006-2014 WRX - $265.46 - Free Shipping!
- More Company23...
Grimmspeed
- GrimmSpeed Turbo to Downpipe Gasket, 2002-2014 WRX & 2004-2019 STi - $17.00
- GrimmSpeed Up Pipe To Turbo Gasket, 2002-2014 WRX & 2004-2019 STi - $13.00
- GrimmSpeed Exhaust Manifold => Up Pipe Gasket, 2002-2014 WRX & 2004-2019 STi - $11.00
- GrimmSpeed Exhaust Manifold Gaskets (Pair), 2002-2019 WRX & 2004-2019 STi - $18.00
- GrimmSpeed 3" 2-Bolt Gasket, Extra Thick, Universal - $23.00
- GrimmSpeed 3" 2-Bolt Exhaust Gasket, Universal - $18.00
- GrimmSpeed Manifold to Up Pipe Gasket (2x Thick), 2002-2014 WRX & 2004-2019 STi - $21.00
- GrimmSpeed OEM Downpipe to 3" Cat-Back Adapter, 2002-2014 WRX & 2004-2019 STi - $39.00
- GrimmSpeed Manifolds To Cross Pipe Gaskets (pair), 2002-2014 WRX & 2004-2019 STi - $16.00
- GrimmSpeed Universal Exhaust Gasket (2.25"/2.5"), Universal - $20.00
- GrimmSpeed 3-Bolt Up Pipe Gasket, 2002-2014 WRX & 2004-2019 STi - $20.00
- GrimmSpeed Donut Gasket, 2002-2014 WRX & 2004-2019 STi & BRZ - $13.00
- GrimmSpeed Manifold to Cross Pipe Gaskets (2x Thick, Pair), 2002-2014 WRX & 2004-2019 STi - $26.00
- GrimmSpeed Exhaust Gasket Set, 2002-2014 WRX & 2004-2019 STi - $80.00
- GrimmSpeed Poly Exhaust Hanger (12mm, Two-Position, Set/4), Universal - $40.00
- GrimmSpeed Poly Exhaust Hanger (12mm, Two-Position, SINGLE), Universal - $13.00
- GrimmSpeed Up Pipe w/ Flex (Ceramic Coated), 2002-2014 WRX & 2004-2019 STi - $265.00 - Free Shipping!
- GrimmSpeed Up Pipe w/ Flex, 2002-2014 WRX & 2004-2019 STi - $220.00 - Free Shipping!
- GrimmSpeed EWG Up Pipe 38mm w/ Dump Tube, 2002-2014 WRX & 2004-2019 STi - $340.00 - Free Shipping!
- GrimmSpeed EWG Up Pipe 38mm w/ Dump Tube (Coated), 2002-2014 WRX & 2004-2019 STi - $380.00 - Free Shipping!
- GrimmSpeed EWG Up Pipe 44mm w/ Dump Tube, 2002-2014 WRX & 2004-2019 STi - $350.00 - Free Shipping!
- GrimmSpeed Up Pipe (3-Bolt, 38mm Ext. Wastegate), 2002-2014 WRX & 2004-2019 STi - $350.00 - Free Shipping!
- GrimmSpeed EWG Up Pipe w/ Dump Tube (44mm V-Band, Coated), 2002-2014 WRX & 2004-2019 STi - $390.00 - Free Shipping!
- GrimmSpeed Up Pipe (3-Bolt, 44mm EWG), 2002-2014 WRX & 2004-2019 STi - $360.00 - Free Shipping!
- GrimmSpeed Up Pipe (3-Bolt, Black Ceramic Coating), 2002-2014 WRX & 2004-2019 STi - $275.00 - Free Shipping!
- GrimmSpeed Up Pipe (3-Bolt, 38mm EWG, Black Ceramic), 2002-2014 WRX & 2004-2019 STi - $390.00 - Free Shipping!
- GrimmSpeed Up Pipe (3-Bolt Flange, w/ Flex Section), 2002-2014 WRX & 2004-2019 STi - $235.00 - Free Shipping!
- GrimmSpeed Up Pipe (3-Bolt, 44mm EWG, Black Ceramic), 2002-2014 WRX & 2004-2019 STi - $400.00 - Free Shipping!
- GrimmSpeed 3" Downpipe to OEM Midpipe Adapter Kit, 2002-2014 WRX & 2004-2019 STi - $39.00
- GrimmSpeed Downpipe (w/ Cat), 2008-2014 WRX & 2008-2019 STi - $570.00 - Free Shipping!
- GrimmSpeed Limited Downpipe (w/ Cat, Black Ceramic), 2008-2014 WRX & 2008-2019 STi - $775.00 - Free Shipping!
- GrimmSpeed Limited Downpipe (w/ Cat), 2008-2014 WRX & 2008-2019 STi - $599.00 - Free Shipping!
- GrimmSpeed Downpipe (w/ Cat, Black Ceramic), 2008-2014 WRX & 2008-2019 STi - $715.00 - Free Shipping!
- GrimmSpeed Exh Manifold Crosspipe (Coated), 2002-2005 WRX, 2008-2014 WRX & 2004-2018 STi - $259.00 - Free Shipping!
- GrimmSpeed Exhaust Manifold Crosspipe, 2002-2005 WRX, 2008-2014 WRX & 2004-2018 STi - $220.00 - Free Shipping!
- GrimmSpeed Catback Exhaust System (Resonated), 2011-2019 WRX & 2011-2019 STi (Sedan) - $1,360.00 - Free Shipping!
- GrimmSpeed Catback Exhaust System (Non-Resonated), 2011-2019 WRX & 2011-2019 STi (Sedan) - $1,255.00 - Free Shipping!
- GrimmSpeed Lightweight Battery Mount Kit w/ Battery (Black), 2008-2018 WRX & STi - $240.00 - Free Shipping!
- GrimmSpeed Lightweight Battery Mount Kit w/o Battery (Black), 2008-2018 WRX & STi - $99.00
- GrimmSpeed Lightweight Battery Mount Kit w/ Battery (Red), 2008-2018 WRX & STi - $240.00 - Free Shipping!
- Grimmspeed Lightweight Battery Mount Kit (Red), 2008-2018 WRX & STi - $99.00
- GrimmSpeed Lightweight Crank Pulley (Blue), 2002-2014 WRX & 2004-2019 STi - $125.00 - Free Shipping!
- GrimmSpeed Crank Pulley Removal/Install Tool, 2002-2014 WRX & 2004-2019 STi - $53.00
- GrimmSpeed Radiator Hose Kit (Black), 2008-2014 WRX & 2008-2019 STi - $110.00
- GrimmSpeed Radiator Hose Kit (Red), 2008-2014 WRX & 2008-2019 STi - $110.00
- Grimmspeed Radiator Shroud - Red, 2015-2019 WRX & STi - $89.00
- Grimmspeed Radiator Shroud - Black, 2015-2019 WRX & STi - $89.00
- GrimmSpeed License Plate Relocation Kit, 2015-2019 WRX & 2015-2017 STi - $79.00 - Free Shipping!
- GrimmSpeed License Plate Delete, 2015-2019 WRX & STi - $40.00
- GrimmSpeed Top Mount Intercooler Silicone Coupler Kit (Black), 2002-2007 WRX & 2004-2019 STi - $65.00 - Free Shipping!
- GrimmSpeed Top Mount Intercooler Silicone Coupler Kit (Red), 2002-2007 WRX & 2004-2019 STi - $65.00 - Free Shipping!
- GrimmSpeed StealthBox Cold Air Intake (Black), 2015-2018 STi - $309.00 - Free Shipping!
- GrimmSpeed StealthBox Cold Air Intake (Red), 2015-2018 STi - $309.00 - Free Shipping!
- GrimmSpeed Intake Manifold Phenolic Spacers (8mm w/ HW, Pair), 2002-2014 WRX & 2004-2019 STi - $60.00 - Free Shipping!
- GrimmSpeed Intake Manifold Phenolic Spacers (3mm, Pair), 2002-2014 WRX & 2004-2019 STi - $50.00 - Free Shipping!
- GrimmSpeed Aerosol Spray Paint (Rally Blue, 12oz.), Universal - $19.00
- GrimmSpeed Aerosol Spray Paint (Gold, 12oz.), Universal - $19.00
- GrimmSpeed Aerosol Spray Paint (Cherry Blossom Red aka. STi Pink, 12oz.), Universal - $18.00
- GrimmSpeed Aerosol Spray Paint (Platinum Silver, 12oz.), Universal - $22.00
- GrimmSpeed Aerosol Spray Paint (Clear Coat), Universal - $15.00
- GrimmSpeed TGV to Head Gasket (Pair), 2002-2014 WRX & 2004-2019 STi - $11.00
- GrimmSpeed Top Mount Intercooler Y-Pipe Gaskets (Pair), 2002-2007 WRX & 2004-2019 STi - $13.00
- GrimmSpeed Intake Manifold to TGV Gasket (Pair), 2002-2014 WRX & 2004-2019 STi - $11.00
- GrimmSpeed Throttle Body Gasket, 2004-2019 STi & 2006-2014 WRX - $8.00
- GrimmSpeed 3-Port Electronic Boost Control Solenoid (ECBS), 2008-2019 STi - $113.00 - Free Shipping!
- GrimmSpeed Manual Boost Controller (Black), Universal - $99.00 - Free Shipping!
- GrimmSpeed Manual Boost Controller (Blue), Universal - $99.00 - Free Shipping!
- GrimmSpeed Manual Boost Controller (Red), Universal - $99.00 - Free Shipping!
- GrimmSpeed Shift Knob (Stainless Steel), 2004-2019 STi, 2015+ WRX & 2013+ BRZ/FR-S - $55.00
- GrimmSpeed Shift Knob (Delrin), 2004-2019 STi, 2015+ WRX & 2013+ BRZ/FR-S - $45.00
- GrimmSpeed Stubby Shift Knob (Stainless Steel), 2004-2019 STi, 2002-2019 WRX & 2013+ BRZ/FR-S - $55.00
- GrimmSpeed Stubby Shift Knob (Delrin), 2004-2019 STi, 2002-2019 WRX & 2013+ BRZ/FR-S - $45.00
- GrimmSpeed Brotie Hella Horn Mounting Bracket, 2002-2019 WRX & 2004-2019 STi - $42.00
- GrimmSpeed Hella Horn Wiring Harness, 2015-2018 WRX & 2015-2018 STi - $39.00
- GrimmSpeed Hella Horn Wiring Harness, 2015-2019 WRX & STi - $39.00
- GrimmSpeed Air / Oil Separator (Blue), 2002-2007 WRX & 2004-2019 STi - $299.00 - Free Shipping!
- GrimmSpeed Air / Oil Separator (Red), 2002-2007 WRX & 2004-2019 STi - $299.00 - Free Shipping!
- GrimmSpeed Air / Oil Separator (Black), 2002-2007 WRX & 2004-2019 STi - $299.00 - Free Shipping!
- GrimmSpeed Top Mount Intercooler Kit, 2002-2007 WRX & 2004-2019 STi - $685.00 - Free Shipping!
- GrimmSpeed Top Mount Intercooler Kit (Black), 2002-2007 WRX & 2004-2019 STi - $785.00 - Free Shipping!
- GrimmSpeed Top Mount Intercooler (TMIC) Splitter (Fits GS TMIC), 2015-2018 STi - $199.00 - Free Shipping!
- Grimmspeed Lightweight Battery Tie Down, 2008-2019 WRX & STi - $38.00
- GrimmSpeed Boxer Style Aluminum Battery Tie Down (Silver), Subaru (All) - $58.00
- Grimmspeed Lightweight Battery Tie Down (Red), 2008-2019 WRX & STi - $38.00
- GrimmSpeed Alternator Cover (Black), 2002-2014 WRX & 2004-2019 STi - $90.00 - Free Shipping!
- GrimmSpeed Alternator Cover (Red), 2002-2014 WRX & 2004-2019 STi - $90.00 - Free Shipping!
- GrimmSpeed Alternator Cover (Stainless Steel), 2002-2014 WRX & 2004-2019 STi - $90.00 - Free Shipping!
- GrimmSpeed Delrin Cool Touch Oil Cap, 2002-2014 WRX & 2004-2019 STi - $58.00 - Free Shipping!
- More Grimmspeed...
Shipping time line:
