Subaru Impreza WRX STI Forums: IWSTI.com - View Single Post - HELP, street flooded out and stopped my STI :(
View Single Post
Old 06-17-19, 03:25 AM
Jay11STI
Advanced Mastery Level I
Car: 2011 SWP STi Sedan
Jay11STI has a spectacular aura aboutJay11STI has a spectacular aura about
Default Re: HELP, street flooded out and stopped my STI :(
Originally Posted by SubySal View Post
Pull the spark plugs before cranking it. If there is water in the cylinders it can escape from the spark plug ports. If the engine was in fact hydro-locked then do a compression check. I think I've heard it's possible engines can survive under light load, but hydrostatic lock under heavy load usually bends things.
Yes you are correct in that statement. I too have gotten other engines that have hydrolocked before to run. Sometime they run ok and sometimes they dont.
To the OP, i would remove the plugs and try to spin the engine by hand to see if you can get any water out. Then try cranking it. Replace the spark plugs and air filter. Change the oil and then attempt to start the engine. Its also possible the starter could have shorted due to water. If you do manage to get the engine to run, it may not be a bad idea to do a compression/leakdown just to verify engine health.
Jay11STI is offline
