View Single Post
Old 06-06-13, 07:54 PM
BlueScooby
Default BlueScooby's 06 STI - MODS list
Current Mods/Upgrades:
Suspension:
Fortune Auto 510 Coilovers with Swift Springs (7K/6K) and RDC
Whiteline 27mm Front Sway Bar
Eibach 25mm Rear Sway Bar
Kartboy Endlinks
Whiteline Anti-Lift Kit
Whiteline Steering Rack Bushings
Whiteline Roll Center/Bump Steer Kit
Whiteline Adjustable Rear Lateral Links
Oswald Performance Rear Triangle Brace
TIC Fender Braces
Alignment Specs: Toe: Zero; Camber: -2.0°F/-1.7°R
Brakes:
Ferodo DS2500 Pads (Street)
Carbotech XP10 Front/XP8 Rear (Track)
DBA 4000 Blank Rotors - "KNS Special" (Street)
DBA 4000 Rotors (Track)
Goodridge SS Brake Lines
TiC Master Cylinder Brace
Fog Light Brake Ducts, RooDucts, brake dust sheilds removed
Engine:
Stage 2 Protune 309WHP/321WTQ
Cobb Accessport (V3)
KS Tech Type-2 73mm Intake
GM EBCS
KillerBee Oil Pick-Up Tube
KillerBee Oil Baffle
IAG Air-Oil-Separator
Moore Performance Turbo Blanket
Maddad Whisper CBE (Custom mounted high and tight under car)
Invidia Catted-Divorced-Bellmouth, ceramic coated, downpipe
Grimmspeed ceramic coated uppipe
TiAL 44mm EWG - Dumptube routed back into downpipe
TGV Deletes, ceramic coated
AMR Turbo Inlet
AEM 320lph fuel pump
OEM fuel filter relocated into engine bay
Drivetrain:
Group N Engine Mounts
Group N Transmission Mount
Kartboy Transmission Crossmember Bushings
Kartboy Pitchstop
Goodridge SS Clutch Line (just because...)
Kartboy 6MT front shifter stay bushing
Kartboy Rear Shifter Stay Bushing
TiC 6MT Pivot Bushing
TiC 06+ Subaru Shift Linkage Bushings
Kartboy "Tallboy" Shifter with custom machined shifter extension
Cooling:
Mishimoto Aluminum Radiator and Silicone Radiator Hoses
Mishimoto Power Steering Cooler
Fluidyne Custom Oil Cooler with Mocal 200degF Sandwich Plate
Fluids:
AmsOil 10W-40 Engine Oil
Motul 90PA Diff Oil (Amsoil 75W-90 Severe Gear next)
Subaru Extra-S Trans Oil
Motul RBF600 Brake Fluid
ATE SuperBlue Clutch Fluid
Subaru green Coolant
Idemitsu ATF (Power Steering)
Interior:
Recaro Pole Position Drivers Seat
SMY Gauge Cluster
Defi Red Racer 52mm Oil Temp. Gauge
Defi Red Racer 52mm Oil Press. Gauge
Kenwood DDX6702X Head Unit
Red Key Ring
Red Climate Controls
Red Clock
Subaru Flip Key swap
Tinted Windows
H3R Halgaurd Fire Extinguisher mounted to drivers seat
Dynamat inside doors, under backseat, and on rear shock towers/wheel wells
FatMat under carpet
LED interior lights
Carbon Fiber Switch plate
Custom USB connectors mounted to center console
Custom Voltmeter display mounted to center console
Exterior:
V-Limited style Front Lip
Custom Aluminum Flat-Bottom Panels (Full length of car) (V3)
Custom Aluminum Rear Diffuser (V3)
Beatrush Undertray
GrilleCraft Lower grille
GrilleCraft Upper grilles
GrilleCraft Hood Scoop grille
(2) Perrin Wing Stiffies
Removed Pinstripping
Intake via NACA duct under bumper
Blacked-out (Painted) Headlight Housings
Hella Horns
04/05 Brake Lights
LED exterior lights
XPEL Clear Bra on Hood, Fenders, Lower half of Front Doors
Singular Motorsports Fender Vents (Paint matched)
Singular Motorsports Hood Vents (Paint matched)
JDM Power Folding Mirrors with Prova Yellow Convex Lenses
Oswald Performance Lightweight Front Bumper Beam
Wheels/Tires:
255/40/17 Bridgestone Potenza RE-71R (Track)
255/35/18 Michelin Pilot Sport AS/3+ (Street)
WedsSport TC105N 18x9 +35, powder coated "Spanish Gold" (Street)
WedsSport TC105N 17x9 +35, powder coated "Spanish Gold" (Track)
Future Mods/Upgrades:
Suspension:
Oswald Performance subframe
Whiteline adjustable Ball socket endlinks
Whiteline stout-mounts for rear sway bar
Brakes:
Essex Designed AP Racing Competition Brake Kit (Front CP8350/325)
Engine/Drivetrain:
No current plans
Interior:
DAMD D-shaped Steering Wheel
Exterior:
Swap for an Uncut front bumper (mine is cut for a FMIC)
Removable Front Splitter (Track-Day Only)
AeroFlow Dynamics V1 Sideskirt Extensions
Removed Mods:
FEAL revalved struts (Tarmac Spec - Mild Springs)
JDM Pink Springs
RCE Lowering Camber Plates (front)
Group N Tophats (rear)
Morosso Oil Catch Cans
JDM V7 STI Front Seats
Sparco EVO 2 Drivers Seat
Custom 25mm Wheel Adapter-Spacers
Custom ABS Plastic Flat Bottom Panels (Phase 2)
RallyArmor Mudflaps
Custom Aluminum UnderBody Panels/Diffuser (V1)
Custom Aluminum UnderBody Panels/Diffuser (V2)
Custom Stamped-Aluminum Hood Vents
Red Cig. Lighter (Cig. Lighter removed alltogether)
USB/AUX extension cord mounted in Center Console
SSR GTV02 17x9 +45 Wheels with 5mm spacers
Bluescooby's 06 STI Journal
IG: BlueScooby06
BlueScooby is offline
