Transmission/Drivetrain Mods for a S M O O T H ride: brands/quality? - Page 4 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Transmission/Drivetrain Mods for a S M O O T H ride: brands/quality?
Old 07-20-19, 10:58 AM   #31
t h i c c
Active Participant
Car: Black '15 WRX STi
t h i c c is an unknown quantity at this point
Default Re: Mods for a S M O O T H ride: brands/quality?
Thanks for all the advise guys, this thread was really informative. I've put in an order for the cobb shortshift and bushings. I'm gunna work at it one part at a time. The next cab off the rank will be a CF driveshaft, and then I'll do the mounts. I'll probably finish up with a tune.
I had a chat with a STi motorsports guy after getting him to drive it around, and he told me the clutch is probably getting messed up from hill assist. After I had a think about it, I live in an area where the main road is just slightly elevated, and every time I try to dart across from one end to the other the hill assist is probably engaging while I wait for gaps. He said my clutch biting point is also unusually high, but it's probably because it's on the way out. I asked if there was a way to lower the bite point permanently if I replaced the clutch with a heavier one, but he said it's pretty much a fixed stroke thing from the way the master cylinder works, and it can't be changed. Some people have suggested adjusting a nut near the clutch pedal to lower the biting point, but I read on these forums that it could cause problems with the cars computer systems
t h i c c is offline
Old 07-25-19, 07:13 AM   #32
the ambush
Advanced Contributor Level 5
Car: 2015 Audi S3
the ambush is on a distinguished road
Originally Posted by t h i c c View Post
My shifter doesn't really move around too much, but I struggle with stop starts occasionally due to a rotator cuff injury (RHD; 1st and 2nd can be a bit of a literal pain when the gearbox decides it's gunna be overly stiff and notchy, it's like shifting a truck sometimes). My hope is that I can make the gearbox feel more effortless, being able to flick from gear to gear with 2 fingers instead having to drive them in. Every now and then I can't even put the car into 3rd without double clutching, and this is just driving at normal speed.
VW products have buttery shifter.
but seriously, if you like your car, i think getting a cobb short throw shifter install it with the lower shaft as long as possible and the top shaft as short as possible. the result will be that the feel is very stiff but the throw will be very short and the shifter being low, you will be able to involve your wrist in to shifting and less arm/shoulder.
ps: i m no physio/ergotherapist/chiro. just and accountant but have had many injuries from sports...
2019 STI WRB
2016 Outback 3.6R
previous cars
-2015 Audi S3 dsg
-2015 STI Red
-2009 STI CWP
-2006 STI WRB
the ambush is offline
Old 08-01-19, 01:53 PM   #33
dromo3
Becoming A Contributor
dromo3 is on a distinguished road
Have you tried a weighted shift knob? I have had the ones from Chris at WC Lathewerks and they make any shifter feel amazingly smooth. 1 lbs steel knob helps with inputs so it requires less force on your end of things.
dromo3 is offline
Old 08-01-19, 10:24 PM   #34
SubySal
Advanced Mastery Level I
Feedback Score: 1 reviews
Fav Mod: everything done so far
SubySal has a spectacular aura aboutSubySal has a spectacular aura about
Originally Posted by VA STI View Post
Can you go into more detail about this mod? Did you just fill up the bushing with urethane?
Here's the post from my journal. It has more detail about this mod, but yes the short of it is I did fill the bushing with urethane.
Project Silverstreak: New diff and coilovers!
SubySal is offline
Old 08-01-19, 10:28 PM   #35
SubySal
Originally Posted by mheyman View Post
This is so misguided. Built and tuned properly your car will loose all signs of STI stumble which you just described perfectly (added: a mild case - it can be much worse and may vary day to day); and run far smoother every where, and make more power everywhere.
i'll admit I had some concerns before I did it - which engine wise was one gigantic leap. It's been 4 yrs and almost 50Kmi. Power-wise, drive-ability, and daily reliability have had no issues - IE I've never broken down on the road. I've made other choices, IE suspension and mounts that make my car - Uh, a little more special
To dhelman - it's all tune. 3port BC make response to the ecu faster - ie the waste-gate which it controls it will follow changes according to the tune faster. Yes it may well prevent overshoot if assuming that's what you are showing us.
I don't have the STI stumble and that is not what I'm talking about. Also I'm done arguing with you on these forums. You seem to miss the point on most of my posts.
SubySal is offline
Old 08-04-19, 03:11 PM   #36
adamfl
Advanced Contributor Level 1
Feedback Score: 2 reviews
Car: 05STi psm stage2
Fav Mod: DO IT!, DO IT!
adamfl is an unknown quantity at this point
same thought. Buy a caddy.
[QUOTE=Jedi03;4482028]i think that if you take your sti to the BMW dealer give it to them and return with a bmw it will be smooth!
adamfl is offline
