Exterior Turn signal failure - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
Turn signal failure
Turn signal failure
Go Back   STI Forums > > > Exterior Turn signal failure
Old 06-30-19, 03:04 PM   #11
Grandprix
Advanced Contributor Level 1
Car: 2017 Pure Red STI
Fav Mod: Interior exterior LEDs
Grandprix is on a distinguished road
Default Re: Turn signal failure
Sequential turn signal led lights ordered. We shall see.
Grandprix is offline
Old 07-03-19, 08:54 AM   #12
Grandprix
No luck. Still an intermittent failure.
Can somebody do me a favor and let me know if your hazard selector button in the car lights up when pressed? Mine does not and I was curious if that’s part of the problem. Nothing in the owners manual.
Thanks.
Old 07-09-19, 05:07 PM   #13
Grandprix
Thanks.
Anyone?
Old 07-10-19, 10:57 AM   #14
navin'swrxsti
Contributor
navin'swrxsti is an unknown quantity at this point
Hazard button itself does not blink when pressed
navin'swrxsti is offline
Old 07-10-19, 12:26 PM   #15
Grandprix
Thank you, that helps.
Old 07-11-19, 11:36 AM   #16
Grandprix
I am at a loss.
New Diode Dynamics flasher relay. Left circuit dead in turn signal and hazard mode. Right circuit perfect.
New Subispeed flasher relay. As above.
Original flasher relay Hyperblink and intermittent left circuit.
Valenti flasher relay. Intermittent left circuit in hazard and turn signal mode. Right circuit perfect. Works better than any other relay, but intermittent.
Checked all light housings, connections and wires.
Disconnected the battery.
Last hope is take to stealership and have them check the MFS and hope they replace under warranty.
Completely baffled. I hate chasing intermittent faults.
Old 07-15-19, 01:45 PM   #17
Grandprix
Stealership messed around for an hour and installed the original incandescent bulb. Blamed it on the LEDs.
I now think it may be a loose connection in the plastic plug where the bulb is installed.
Just going to tape everything tight and tie rap the excess wire before reinstalling the LED. This can’t be rocket science. Hopefully the Diode Dynamics flasher relay will work as advertised. Otherwise, I’ll have to sell it cheap.
Bright side, the dealer didn’t charge me for the diagnosis.
Old 07-17-19, 10:44 AM   #18
VA STI
Advanced Contributor Level 4
VA STI will become famous soon enough
Changing turn signals to LEDs may in fact be linked to why it doesn't work. I believe the turn signals use resistance in their timings (so when your bulb blows the indicator flashes faster). Maybe using LEDs instead of regular bulbs is making them act wonky?
VA STI is offline
Old 07-17-19, 12:34 PM   #19
Grandprix
The flasher relay compensates for the lower resistance.
Old 07-22-19, 01:52 PM   #20
Grandprix
That’s it! I am done chasing this effing problem. All good for a week. Today, the nonworking left circuit reappeared.
Going to switch my fronts back to incandescent. Obviously, my car's electrical system can’t handle full up LEDs.
Call me pissed in FLA.
