Maintenance: DAM Drop! HELP - Page 2 - Subaru Impreza WRX STI Forums: IWSTI.com
DAM Drop! HELP
DAM Drop! HELP
Go Back   STI Forums > > > Maintenance DAM Drop! HELP
Old 05-11-19, 09:19 PM   #11
Castrosubie
Active Participant
Castrosubie is an unknown quantity at this point
Default Re: DAM Drop! HELP
Originally Posted by yamahaSHO View Post
I'd start with a boost leak test. If that passes, do a compression test.
Thank you!
Sent from my SM-N960U using Tapatalk
Castrosubie is offline
Old 05-13-19, 12:49 PM   #12
Castrosubie
Active Participant
I won't comment until I see the next log, but what I've seen so far, seems all over the place.
So this is the 3rd gear pull. I had re-flashed the tune it was perfect at this point
datazap.me | Ccscrub14 | Log 1557780361
Old 05-13-19, 06:52 PM   #13
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
That log doesn't look bad. Timing is a little on the low side... What fuel are you running? Essentially a stage 1 car?
If it comes back like you originally described, I would do a compression test. The other is, without a WBO2, you don't really know what the AFR is as the stock sensor will just flat-line and is not accurate once you start getting into boost.
www.jaztuning.com
yamahaSHO is online now
Old 05-13-19, 07:14 PM   #14
Castrosubie
Active Participant
I'm in California so I think that's why the timing is a little low. Chevron 91. The car is stock. Now after reflash it runs great for a little while, prolonged even if I drive cruise at higher rpm. As soon as I drive under 3k rpm fine knock -11.45 feed back knock jumps around a little around 2.8 but sudden jumps to 10 sometimes. And then DAM fluctuates. .062, .500 and even 0.0. But it changes very quickly. If I jump on the freeway itll climb up to 1.0.. could this be a vacuum leak? A pebble stuck somewhere causing the knock? Or ringlands?if I can leave work early tomorrow I will be taking it to the dealer here who is aware of the issue and wanted me to bring it to do the compression and boost leak test.
Similar Threads
Engine Should I worry ? DAM drop bellow 1 SomeOneQC 2015+ STI Discussion 12 05-01-17 05:50 PM
Engine DAM Drop Silversti5 2015+ STI Discussion 8 08-17-15 12:54 PM
DAM drop to 1.0 to 0.0! Matteosti ECU Tuning & Performance Electronics 0 05-08-10 12:44 PM
Cat back exhaust + drop in filter tune or no need? asukadc 2.5 Liter/Litre Factory Motor 6 03-19-10 11:51 AM
Suspension/Stiffening advice on springs & drop STIstud2k7 GD-General 18 06-21-08 10:14 PM
