2016 Hyperblue IAG Built | Daily Driven | 530whp/508wtq - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > 2016 Hyperblue IAG Built | Daily Driven | 530whp/508wtq
Old 05-06-17, 02:48 PM   #1
///V3Dude
Advanced Contributor Level 5
Feedback Score: 1 reviews
Car: 16 Hyper Blue STI
Fav Mod: Snow Tires
///V3Dude is on a distinguished road
Default 2016 Hyperblue IAG Built | Daily Driven | 530whp/508wtq
I never really considered making a member journal as this car was never suppose to be this way!! I am way behind on this but this has been a very last minute build as my engine let go after 20k miles on stage 2 Flex Fuel.
I purchased the car new on Halloween of 2015 from Betera Subaru in CT.
Engine build list- Current
IAG Stage 3 Plus Shortblock-
Manley Turbo Tuff Pistons
Manley Turbo Tuff I-Beams
ACL race bearings w/ Stock Nitrated Crank
Killer Bee Oil Pick
Gates Racing Timing Kit
FP Black 82HTZ BB Stock Location
FP 84mm Turbo Inlet
IAG Street series AOS
IAG Top Feed Fuel Rails with Parallel Feed -6 Fuel Lines
Aeromotive FPR
Cobb Flex Fuel + Speed Density Tuned by JR
Perrin Cold Air Intake
Fathouse Fab 4" FMIC
Tial Q BOV
Perring Equal Length Headers
Grimspeed up-pipe with 38mm EWG
Invidia Catless Downpipe
Corsa Catback Exhaust
Competition Clutch Stage 4 6 Puck Clutch W/ Resurfaced Stock Flywheel
IAG Stage V Heads-
JE Pro Seal headgasket
Manley Extreme Duty 33mm Exhaust Valve Set
Manley Race Flow 37mm Intake Valve Set
GSC Valve Spring and Retainer Kit
IAG Stage V headwork with Multi Angle Valve Job/Port&Polish
Kelford Dual AVCS 272/268 11.30/10.50mm Lift Street Cams
IAG TGV Deletes with 8mm phenolic spacers
Airlift Performance Lift V2 Autopilot
Rays 57FXX Mag Blue 18x9.5 et38mm
265/35 Continental DW
I promise you it's slow! It's a stock location turbo
Ethanol Dyno Chart 587/567wtq tuned on winter blend E58 (JrTuned @ IAG Performance)
Ethanol Dyno Chart 530/508wtq on E74. Travis @ SnailPerformance California
Pump Dyno Chart 464/397wtq
2016 Hyperblue IAG Built | Daily Driven | 530whp/508wtq-stifrontleftcorner-2-iwsti-jpg
///V3Dude is offline
Likes 4 Dislikes 0
Old 05-06-17, 02:48 PM   #2
///V3Dude
Fav Mod: Snow Tires
Default Re: 2016 Hyperblue IAG Built | Daily Driven | 587whp/567wtq
Car waiting to be driven home 110 miles back to Albany
The first 24 hour of ownership!
After 1 month and 3,000 miles. I installed the Corsa Exhaust and Rally Armor Mudflaps, Cobb Stage 1 flashed.
Fast forward 2 months later. Flex Fuel kit was ordered along with Perrin Equal Length headers that I wrapped in DEI exhaust tape. Car made 337/367wtq
Installed Airlift Suspension and rolled/pulled rear fenders along with a slight pull on the front fender. I am one of the weird people to run an air suspension setup with meaty tires
August 2016- I purchased a 2000 Subaru RS that had an STI drivetrain installed. I pulled the hybrid SOHC turbo setup out of it and replaced it with an EJ207 V7 engine (project completed January 2017) Crappy iPhone Pano
October 2016- The engine let go after 20k miles on my way to work. Very weird feeling... Driving up to the last stop sign before the parking lot, the engine made a slight shudder on the stop and it began idling rough and my vacuum gauge on the cobb read -8.30 where it usually reads -9.9. I parked the car and opened the oil fill cap to find white puffs of smoke. I knew exactly what it was. I drove the car for an additional 3 days after this event until I saw one huge feedback knock of -7.7 on light cruising. Car remained parked until I decided what I wanted to do.
One week later... I made one of the most expensive phone calls ever
I spoke with Keith at IAG. The conversation started with lets get the car fixed and just back on the rode. After a week of ironing out all the details. The simple "lets slap a forge built block and upgrade some fueling mods" turned out to be a 600whp build. IAG was very busy at the time so my drop off date was December 22nd. Christmas present
Old 05-06-17, 03:00 PM   #3
///V3Dude
Fav Mod: Snow Tires
February 4th, 2017- Car was picked up and begin the long journey of 3,000 mile break in.
I drove the car home ~360 miles back to Albany and hated the 1 hour of traffic I got stuck in. Breaking in a brand new engine along with the 6 puck clutch was quite embarrassing!
Feb 16th, 2017- FP black turbo arrived after being backordered. The install for this was quite frustrating. See details below.
- The 84mm is massive trying to get it fit between the manifold/tgv delete.
- The clamp provided by FP was too small diameter wise to provide a tight clamp. ( reordered a new larger 4" zebra clamp that is half the width of the regular breeze clamp provided)
- The TGV delete was pushing on the inlet in a spot I did not like, so I purchased an 8mm phenolic spacer to raise TGV delete torwards the center of the inlet. The spacer also made the manifold much cooler also. I was never a believer of this until I was able to put my hand on the manifold after a long drive.
- I had to grind a nut down to be able to get it to screw onto the turbo bolt because the turbo hotside housing wasn't milled down enough to fit.
Next was to install the Fathouse Fab 4" FMIC with Tial Q BOV- This was less frustrating.
There is a mild modifications needed to the bumper. In my case I had to do some additional modification to the fog light bezel as I could not get the pipe to clear no matter what I did.
I plan on redoing my hack job on the bezel ( $12 dollars for a new one but it works )
Everything was back together and I completed 1,500 long and uneventful miles. Per some suggestions. I scheduled the car for a dyno tune to help give the pistons a good seat!
March 6th, 2017- The man JrTuned blessed the car! - Dyno graph in the first post. Car also made 464whp/397wtq on 93
Following the dyno session. I did another 1,500 long and uneventful miles on the break in oil. Finally 3,000 break in miles completed and I completed the oil change with Motul X-cess 5w40 synthetic oil.
Groceries aren't a problem either!
Likes 1 Dislikes 0
Old 05-08-17, 08:40 AM   #4
earth0
Feedback Score: 3 reviews
Car: 15 STI
Fav Mod: IAG/EWG/E85
earth0 will become famous soon enough
Very Nice! May i ask who did your build engine and tune your car btw?
earth0 is offline
Old 05-08-17, 10:45 AM   #5
Discobob
Feedback Score: 2 reviews
Car: WRB 09 STI Hatch
Fav Mod: 2015 steering rack:)
Discobob will become famous soon enough
Jebus christo, insane love the plates and the black intercooler pipes
Atleast if I sell mine I can live through guys like you and follow your threads!!!! Bet it's fun to drive, and scary for unsuspecting passengers....
Discobob is offline
Old 05-08-17, 11:54 AM   #6
///V3Dude
Fav Mod: Snow Tires
Thanks! I always get a laugh out of the plates! The car is a blast to drive, the boost comes on very fast and pulls like a freight train to about 130. I had a co-worker in the car car and his response was " holy sh**" I was not expecting that.
Build was done in-house by IAG and tuned by JR.
Likes 1 Dislikes 0
Old 05-09-17, 07:33 AM   #7
MuffnMan
Becoming A Contributor
MuffnMan is an unknown quantity at this point
Serious question.... how is the gas mileage? 😅
MuffnMan is offline
Old 05-09-17, 11:16 AM   #8
///V3Dude
Fav Mod: Snow Tires
Originally Posted by MuffnMan View Post
Serious question.... how is the gas mileage? 2016 Hyperblue IAG Built | Daily Driven | 530whp/508wtq
I average about 16 mpg on ethanol and pump is about 20 mpg.
Old 05-09-17, 08:34 PM   #9
db8typer
Joined the Conversation
db8typer is an unknown quantity at this point
Awesome build!
db8typer is offline
Old 05-10-17, 11:03 AM   #10
MuffnMan
What size injectors are you runnin? I just dropped in a blouch turbo with 1000cc injectors and a 255 pump... for some reason I'm getting around 10-12. It's kinda frustrating! Maybe you could offer me some advice. Thanks in advance
MuffnMan is offline
Similar Threads
GR Hatch: '08 JDM Sti - NZ Superlap 2018/19 JeremySmith220 GR-Members' Journals 1376 08-12-19 07:34 PM
Thoughts/Review/Comparison Heuberger's 2016 Subaru WRX/STi Post Custom Order Thread HeubergerMotors 2015+ STI Discussion 400 02-08-18 11:57 AM
GR Hatch: IAG Built 400+WHP on 19psi (2008 Silver STI) themule08 GR-Members' Journals 85 07-29-17 02:17 PM
[2008 STi] 550whp daily driven, HTA86, IAG Built user1029 Power Bragging 14 04-20-15 09:54 AM
570whp, 93oct 50/50 meth, 30psi, HTA86, IAG Built, DD user1029 Power Bragging 13 04-05-14 04:21 PM
