Contemplating a new project - Building an Engine - Page 5 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Contemplating a new project - Building an Engine
Old 10-01-19, 08:04 AM   #41
viper_crazy
Advanced Contributor Level 1
Car: 08 WRX Premium Wagon
Fav Mod: Forge shortblock
viper_crazy is on a distinguished road
Default Re: Contemplating a new project - Building an Engine
Originally Posted by Soltis187 View Post
Correct. I was aware of the what the letters meant. For some reason I was under the impression that the WRX case halves used different lettering. It is a single AVCS engine. Could that be what makes it a WRX engine and not a STI engine?
AFAIK, all EJ25 block use that lettering. Not sure about any other EJ-series though. I never bothered to look as I've never owned one. There are quite a few differences between EJ255 (WRX) and EJ257 (STi), S(ingle)-AVCS vs. D(ual)-AVCS are one of them. Internals were slightly different, STi ran slightly lower static compression, and then there's the external differences like turbo and intercooler.
Sent from my SM-G955W using Tapatalk
viper_crazy is offline
Old 10-01-19, 12:29 PM   #42
Leemanfor
Developing Advanced Mastery
Fav Mod: EFR 7163 Turbo
Leemanfor has a spectacular aura aboutLeemanfor has a spectacular aura aboutLeemanfor has a spectacular aura about
Correct
the EJ255 and EJ257 are the same case halves. Just lower compression pistons in the STi.
the WRX use Single AVCS heads, B25 IIRC. The STi uses dual AVCS heads, W25 heads.
Leemanfor is offline
Likes 1 Dislikes 0
Old 10-02-19, 04:27 AM   #43
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber! Power! Wide ratio gearing! The rest is just support :)
after 05
IMHO, to justify its' price, the S209 needs to perform at least as well as my moderately powered 05 built beater, and even that might not convince me to buy one cause my next STI isn't likely to be moderately powered.
I'm putting IAG back in here. Engine wise the car hase been trouble free for 56K. My STI is nearing the 60K minimum JJ led meto expect from a 2618 piston equipped block and it's still running strong.
mheyman is offline
Old 10-02-19, 05:12 AM   #44
Soltis187
Car: PBP 2014 STI
Fav Mod: Heavy Right Foot
Soltis187 is an unknown quantity at this point
Okay. So it is definitely a WRX Block. What distinguishes the lower compression pistons from the higher compression pistons?
Long-term. I will purchase W25 heads. There is also D25 head right?
Soltis187 is offline
Old 10-07-19, 11:41 AM   #45
Soltis187
Car: PBP 2014 STI
With all other engine specs kept OEM, what sorts of adjustments need to be factored for running 99.5mm, 8.5:1 CR piston in stead of 99.5mm, 8.2:1 CR pistons?
Old 10-07-19, 12:12 PM   #46
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
Originally Posted by Leemanfor View Post
Correct
WRX has smaller rods too... Although, they are forged as well.
jaz|TUNING
yamahaSHO is online now
Old 10-07-19, 12:18 PM   #47
Soltis187
Car: PBP 2014 STI
Yes. I don't plan on reusing the rotating assembly. The Crank, Rods, & Pistons will all be new. Like going with an OEM 79mm CS, forged STI rods, and forged pistons. I'd prefer to go with forged pistons that won't expand as much.
Old 10-08-19, 11:37 AM   #48
Leemanfor
check out 4032 forged pistons then. they are a semi-forged piston. still stronger than hyperuetic but not as strong as 2618 forged.
CP, Manley, JE etc are all 2618 forged.
Arias, Supertech, Mahle and Cosworth are all 4032 forged type pistons.
My next build will be Cosworth,H-tuff and closed deck.
Likes 1 Dislikes 0
Old 10-21-19, 05:30 AM   #49
Soltis187
Car: PBP 2014 STI
Here are some pictures I took this week of what $350 got me.
Contemplating a new project - Building an Engine-img_0194-jpg   Contemplating a new project - Building an Engine-img_0193-jpg   Contemplating a new project - Building an Engine-img_0192-jpg
