2011 STi Oil Flow Control Solenoid Valve - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > 2011 STi Oil Flow Control Solenoid Valve
Old 05-28-19, 05:16 PM   #1
fletcher
Becoming A Contributor
Car: SWP 11 GR Hatch
fletcher is an unknown quantity at this point
Default 2011 STi Oil Flow Control Solenoid Valve
Hey all,
I've noticed a slow oil leak coming from around the left Exhaust Solenoid valve which is part number 10917AA070. I'm going to replace the gasket (10924AA011) to see if it helps however I've been reading threads of the solenoid itself wearing out, as it is may be a wear item.
My question therefore is, seeing as I have no CEL or codes corresponding to bank 2 issues, is it likely that the AVCS solenoid is worn out? Should I purchase one before starting the job or just stick with the gasket and wait for results?
Thanks!
Also, links that I found useful for info: 1 2
fletcher is offline
Old 05-29-19, 05:34 AM   #2
Jedi03
Advanced Contributor Level 1
Car: Blue 2009 STi Hatch
Jedi03 is an unknown quantity at this point
Default Re: 2011 STi Oil Flow Control Solenoid Valve
personally i would start with the gasket...but up to you, if the solenoid is failing somewhere other than the gasket then you will need to do the work again...you could also try to clean it and let the car idle to see where its leaking, whether at the gasket or somewhere else
Jedi03 is offline
Old 05-29-19, 12:08 PM   #3
UrdnotWrexSTi
Feedback Score: 2 reviews
Car: Aspen White GR STi
Fav Mod: Coilovers
UrdnotWrexSTi will become famous soon enough
How many miles are on your engine?
UrdnotWrexSTi is offline
Old 05-29-19, 12:12 PM   #4
fletcher
Just under 140,000 KM, so roughly 87K miles.
fletcher is offline
Old 05-29-19, 06:09 PM   #5
UrdnotWrexSTi
Fav Mod: Coilovers
You shouldn't need new OCV's at that mileage. Typically, you should either change them when you spin a bearing or change them if your car is telling you there is an actual fault with them. Otherwise, if you're leaking from the gasket, just change the gasket.
Old 05-29-19, 11:57 PM   #6
fletcher
Alright this is reassuring for sure. I'll get to the gasket and see how it holds. Thank you!
fletcher is offline
Old 06-04-19, 02:01 AM   #7
fletcher
So I got under the car and upon further investigation this is what I saw. Seems like the gasket is ok but the plastic connector is leaving which I understand to be the sign of a failing unit requiring full replacement of the assembly. Is that correct?
https://ibb.co/album/evz9bF wasn't able to hyperlink on mobile. Pls ignore last pic.
fletcher is offline
Old 06-04-19, 03:33 PM   #8
UrdnotWrexSTi
Fav Mod: Coilovers
Ocv — imgbb.com wasn't able to hyperlink on mobile. Pls ignore last pic.
What do you mean by "leaving"? Have you cleaned up that entire area with a cleaner and then checked again?
Old 06-04-19, 03:35 PM   #9
fletcher
Sorry, meant leaking***.
Yes, I have cleaned it and noticed it looks similar every time I get under the car, similar to what I posted in the album.
fletcher is offline
Old 06-05-19, 05:44 AM   #10
UrdnotWrexSTi
Fav Mod: Coilovers
Hmmm I’ve never seen one leak from the actual solenoid o-ring. But anything is possible. If you have the money, I’d just replace the whole thing so you never worry about it again, but if you want save I’d pull out the solenoid itself and check the o-ring and replace just that if you can find one
