P0328 code after air pump delete - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > P0328 code after air pump delete
Old 05-02-19, 12:23 PM   #1
DougSTi
Becoming A Contributor
DougSTi is an unknown quantity at this point
Default P0328 code after air pump delete
I just had my local shop complete an air pump delete on my 2012 STi. Car seems to run fine, but now it's giving me a knock sensor P0328 code. Feedback knock on the goes straight to -5.0 under 30%-40% throttle, DAM remains at 1.0 and fine knock learn is 0.0
Any ideas? Also, if someone could let me know the location of this sensor that would be super helpful.
Thanks!
DougSTi is offline
Old 05-02-19, 01:15 PM   #2
DougSTi
Default Re: P0328 code after air pump delete
Also wanted to add that I had spark plugs replaced at the same time with new OEM plugs
DougSTi is offline
Old 05-02-19, 02:04 PM   #3
[email protected]
Car: 2011 STI Sedan
Fav Mod: Arcflash LLC Ohlins Coilovers
joshua@arcflashllc is on a distinguished road
Sounds like the knock sensor is unplugged...
COBB Pro-Tuner/Dealer <-E-tuning and in house dyno tuning available
Custom valved and sprung Ohlins Coilovers
Antigravity Battery <-- SAVE 22 LBS!!
SPL Suspension Components
joshua@arcflashllc is offline
Old 05-02-19, 02:54 PM   #4
crick0234
Master Contributor Level 2
Feedback Score: 1 reviews
Car: DGM '12 WRX STI 5DR
Fav Mod: shortThrow Shifter
crick0234 is on a distinguished road
curious did they reinstall the baro sensor? dunno if lack of baro sensor would lead to that code or not.
crick0234 is offline
Old 05-02-19, 05:49 PM   #5
DougSTi
I asked him to leave the valve with the baro sensor intact, everything else is removed. I'm running a map with all of the air pump codes disabled
Not sure if this is significant or not, but the feedback knock goes to -5.0 and ONLY -5.0 like an on-off switch. It doesn't change from that value even at WOT.
I can feather the throttle lightly through the RPM range without getting a knock reading, but when the car gets under load thats when I see the knock.
DougSTi is offline
Old 05-07-19, 05:13 AM   #6
DougSTi
*Update* turns out the knock sensor had been damaged during the air pump removal, the inner wire was exposed. Had the sensor replaced, all is good
Thanks for the help!
DougSTi is offline
Likes 2 Dislikes 0
Similar Threads
07 STi Secondary Air Pump Delete enash965 FAQ/Newbie Forum 4 06-02-18 06:14 AM
GR Sedan: Without the “Ambassador” mask on Dspin_1080 GR-Members' Journals 3272 10-29-16 06:44 PM
FS (USA,NJ): VF48 > 30k miles BNIB AMR turbo inlet & TS Air pump delete + OEM TGV and turbo inlt RancerEvorution Engine/Drivetrain/Performance Parts For Sale 31 02-10-14 04:34 PM
P&L Motorsports New Product Release: Emission Air Pump Block Off Plates P&L Motorsports Vendor Announcements & Project Buildups 14 10-15-08 08:05 PM
