Oil temps way high after header install - Page 9 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Oil temps way high after header install
Old 05-17-19, 01:29 PM   #81
raisingAnarchy
Becoming A Master Contributor
Car: CBS '16 STI
Fav Mod: Driver mod
raisingAnarchy will become famous soon enough
Default Re: Oil temps way high after header install
Originally Posted by brapp View Post
Well that helps explain why normal temps are lower
I haven't checked into this thread in a while, but have you already verified your temp gauge readings are accurate? Do you have an oil pressure gauge to corroborate the temp readings? If you're getting big spikes in oil temps, but your oil pressure is staying steady, then that might imply it's just your temperature sensor being affected and not the oil.
raisingAnarchy is offline
Old 05-17-19, 01:47 PM   #82
brapp
Car: 2005 STi
Fav Mod: going from GR -> GD
brapp will become famous soon enoughbrapp will become famous soon enough
No pressure gauge, but the oil temp gauge was checked using a high-end IR thermometer. Readings from the thermometer at the sensor spot were within 5-8 degrees of what the gauge was reading.
brapp is offline
Old 05-17-19, 02:08 PM   #83
Noximus
Advanced Mastery Level II
Feedback Score: 3 reviews
Fav Mod: 2015 STI Steering Rack!
Noximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really nice
Originally Posted by yamahaSHO View Post
Sorry, was talking to the guy above my post.
OEM pan and OEM undertray
Noximus is offline
Old 06-04-19, 11:46 AM   #84
brapp
Car: 2005 STi
Well... another update.
Wrapped the headers -- no change in temps. Actually, temps are higher now than ever, but it's been getting warmer out so that makes sense. Today driving across town... zero boost, casual driving, all under 4k rpm in 78 degree weather got me 230 degree oil temps.
So seems that I can rule out the headers heating things up. I'm thinking that no matter what, if the radiant heat from them was heating up the oil then the wrap would have SOME effect.
But now this leads, again, to a very odd situation where the oil is getting hot but there doesn't seem to be any cause that I or anyone else can think of.
I'm going to check the gauge sender again... it was checked via IR thermometer but I'm thinking to test with boiling water as well.
Other than that... the only things that changed around the same time were adding an AOS, changing to Grimmspeed intake from SPT, and getting a retune.
Any thoughts or ideas are super welcomed :/
brapp is offline
Old 06-04-19, 02:46 PM   #85
Noximus
Like I said before, it’s either the sensor or the tune. I think like you said, you have no choice to troubleshoot your sensor first.
Noximus is offline
Old 06-04-19, 03:03 PM   #86
brapp
Car: 2005 STi
I hope you are right.
How do you think the tune could affect the temp though? AFR's look pretty normal...
brapp is offline
Old 06-04-19, 05:44 PM   #87
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber
timing?
mheyman is offline
Old 06-04-19, 05:52 PM   #88
Noximus
The AFR itself is a ratio independant of heat. It follows the tune, so if all incoming data after the meters stay the same or don’t vary more than 25% from the tune, then the AFR will always be perfect.
It really depends on many things. The basic generalization is that a more agressive tune makes the engine perform harder which creates more heat. The tuner can control EGTs, cooling, timing, etc in different drive cycles. If the tune isn’t as efficient performance wise for the engine, as it could or used to be, then the extra energy has to go somewhere and most often that’s seen with a temperature change.
Noximus is offline
Old 06-04-19, 06:13 PM   #89
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
I don't see this as tune related. A hard part was installed that should really make things cooler, aside from radiant heat. Also, the tune will only correct to *50% in closed loop, but you also don't want it to be there.
Have you tried a new sender and new wires?
www.jaztuning.com
yamahaSHO is offline
Old 06-04-19, 08:10 PM   #90
lowbee
Advanced Contributor Level 1
Car: DGM 11 STi hatchback
lowbee is an unknown quantity at this point
Is your oil cooler working properly?
lowbee is offline
Similar Threads
GR Sedan: Without the “Ambassador” mask on Dspin_1080 GR-Members' Journals 3272 10-29-16 06:44 PM
Lets Talk Motor Oil It Is So Very Misunderstood Dspin_1080 2.5 Liter/Litre Factory Motor 44 01-12-12 05:14 AM
Free APS Manifold Offer for Limited Time. Big APS Shipment with New Lower Pricing! RallySportDirect GD-Vendor Classified Ads 31 05-12-09 12:37 PM
High Oil temps topend 2.5 Liter/Litre Factory Motor 12 06-30-07 05:49 PM
