Oil temps way high after header install - Page 8 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Oil temps way high after header install
Old 05-17-19, 09:57 AM   #71
Noximus
Advanced Mastery Level II
Feedback Score: 3 reviews
Fav Mod: 2015 STI Steering Rack!
Noximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really niceNoximus is just really nice
Default Re: Oil temps way high after header install
Originally Posted by brapp View Post
If you look a few posts up, sensor has been confirmed to be accurate. Reads within about 5-ish degrees of a high-end IR thermometer.
I'm curious about your setup... so far I haven't run across anyone who is running unwrapped, uncoated headers who is monitoring oil temps and has seen no change since the headers went in.
If you wouldn't mind sharing, what are your mods, usage, and normal oil temps? Headers uncoated and unwrapped?
It could certainly be something else. But I'm really leaning towards the headers as the temp change happened immediately after they went in... that and that no one else seems to have any idea what else could be causing it.
I have uncoated and unwrapped IAG spec GTSpec EL headers. I’ve been monitoring temps since my gauges went in at Stage 2 through a sandwich plate at the oil filter with the wire routed up to the block back to the firewall. This was 4-5 years ago now. The headers went on 2 years ago. The headers and the EWG with a retune was the only thing that was done at that time. There were zero changes in oil temps. I haven’t done anything to the car since then, temps are still the same since I was Stage 2 five years ago.
Normal temps are around 95C (203F), roam around 100C (212F) on hot days, and go up to 105-110C (221-230F) during heavy driving or autox on 30-40C (86-104F) days.
Noximus is offline
Old 05-17-19, 10:35 AM   #72
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
Are you on a steel or aluminum pan?
jaz|TUNING
yamahaSHO is online now
Old 05-17-19, 11:01 AM   #73
lowbee
Advanced Contributor Level 1
Car: DGM 11 STi hatchback
lowbee is an unknown quantity at this point
....If you wouldn't mind sharing, what are your mods, usage, and normal oil temps? Headers uncoated and unwrapped?
I have uncoated and unwrapped (KillerB ELH + custom UpPipe), Invidia CATTED downpipe and 3" Borla catback. Oil temp sensor installed in a oil filter sandwich plate adaptor.
Normal Oil temp is around 190F and I have never seen it goes over 200F (spring time outside temp). When I have Oil temp at 190F my Water temp is usually around 200F. I have a conservative tune with peak wheel torque of 320 lb-ft and peak WHP 295.
lowbee is offline
Old 05-17-19, 11:26 AM   #74
brapp
Becoming A Master Contributor
Car: 2005 STi
Fav Mod: going from GR -> GD
brapp will become famous soon enoughbrapp will become famous soon enough
Wow that's different. Stock my car would hit 200ish around town.
I do live at 6500 ft which I imagine makes a difference.
Does the car see track use?
brapp is offline
Old 05-17-19, 11:28 AM   #75
brapp
Car: 2005 STi
Appreciate the reply.
That sounds fairly close to what I see around town... a bit lower but not too drastic. Do you track the car?
I have heard the Killer B ones should run hotter than other EL designs due to being a 4-1 design. I'm also wondering how much effect elevation is having as I live at 6500 ft. I know that will make cooling harder, but I'm not sure by how much.
brapp is offline
Old 05-17-19, 11:35 AM   #76
Noximus
This car has only seen autox. I’ve never been willing to push this car on a road course on the stock cooling system. It doesn’t help that I have to travel 2.5hrs one way to the closest track.
I’m right at sea level.
Noximus is offline
Old 05-17-19, 11:36 AM   #77
lowbee
It's my winter car, it is parked and stored in the summer so no track use
lowbee is offline
Old 05-17-19, 12:28 PM   #78
brapp
Car: 2005 STi
Beatrush aluminum pan.
Though temps were essentially the same with the stock plastic one.
brapp is offline
Old 05-17-19, 12:30 PM   #79
brapp
Car: 2005 STi
Well that helps explain why normal temps are lower
brapp is offline
Old 05-17-19, 01:17 PM   #80
yamahaSHO
BROtuner
Car: 2005 WRB
Sorry, was talking to the guy above my post.
jaz|TUNING
Similar Threads
GR Sedan: Without the “Ambassador” mask on Dspin_1080 GR-Members' Journals 3272 10-29-16 06:44 PM
Lets Talk Motor Oil It Is So Very Misunderstood Dspin_1080 2.5 Liter/Litre Factory Motor 44 01-12-12 05:14 AM
Free APS Manifold Offer for Limited Time. Big APS Shipment with New Lower Pricing! RallySportDirect GD-Vendor Classified Ads 31 05-12-09 12:37 PM
High Oil temps topend 2.5 Liter/Litre Factory Motor 12 06-30-07 05:49 PM
