Oil temps way high after header install - Page 7 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > Oil temps way high after header install
Old 05-16-19, 05:48 AM   #61
yamahaSHO
BROtuner
Feedback Score: 7 reviews
Car: 2005 WRB
Fav Mod: Equal Length Header
Default Re: Oil temps way high after header install
Originally Posted by brapp View Post
I'm not even really racing though... I just want to be able to run a full 20 minute track session in a stock motor, stock turbo car with headers and a downpipe without having to spend 60+% of the session doing cooldown laps.
"Racing" is expensive.
This is where I harp on people about building a car for cooling. For track, cooling should be a HUGE focus if you want it to last. That is why my S2000 is setup the way it is.
Originally Posted by Noximus View Post
It’s impossible to run straight 20mins even on a stock car. Those that do it aren’t monitoring.
I could melt down a stock car pretty quickly. I've ridden passenger in some stock cars with novices and even they were overheating their cars.
www.jaztuning.com
yamahaSHO is offline
Likes 1 Dislikes 0
Old 05-16-19, 07:27 AM   #62
brapp
Becoming A Master Contributor
Car: 2005 STi
Fav Mod: going from GR -> GD
brapp will become famous soon enoughbrapp will become famous soon enough
I'm aware, thanks.
I'd feel my car is pretty well prepared. My issue is after the headers got put on the temps jumped drastically. That's what I'm trying to figure out.
brapp is offline
Old 05-16-19, 07:31 AM   #63
Leemanfor
Master Contributor Level 1
Fav Mod: EFR 7163 Turbo
Leemanfor has a spectacular aura aboutLeemanfor has a spectacular aura about
a simple test would be to put your old header on just to verify that is the issue.
if you have done that, and I missed the post, my apologies.
Leemanfor is online now
Old 05-16-19, 07:33 AM   #64
brapp
Car: 2005 STi
Yup.
As currently set up, with the stock header I could run 20 minutes last season without worry for oil or coolant temps. If it came down to paying close to a grand for heat shields, I think I'd just put the stock header back on.
brapp is offline
Old 05-16-19, 07:35 AM   #65
brapp
Car: 2005 STi
Totally -- and something I've thought of. Issue was I took the time while the car was down to switch intakes and add an IAG AOS. So I'd need to get retuned again for the stock header.
brapp is offline
Old 05-16-19, 07:37 AM   #66
yamahaSHO
BROtuner
Car: 2005 WRB
Yup.
You can wrap the header instead.
www.jaztuning.com
Old 05-16-19, 10:33 AM   #67
mheyman
Feedback Score: 4 reviews
Fav Mod: Camber Camber Camber
Deleted
mheyman is offline
Old 05-16-19, 05:52 PM   #68
brapp
Car: 2005 STi
I think that's what I'm going to do.
I was shying away from it as Killer B was recommending not to, but at this point I'm not sure what else to try.
brapp is offline
Old 05-16-19, 08:15 PM   #69
lowbee
Advanced Contributor Level 1
Car: DGM 11 STi hatchback
lowbee is an unknown quantity at this point
Many killerB headers installed including mine have seen no or marginal increase in oil temp so it has to be something else causing your problem. Faulty oil temp sensor maybe ?
lowbee is offline
Old 05-17-19, 09:26 AM   #70
brapp
Car: 2005 STi
If you look a few posts up, sensor has been confirmed to be accurate. Reads within about 5-ish degrees of a high-end IR thermometer.
I'm curious about your setup... so far I haven't run across anyone who is running unwrapped, uncoated headers who is monitoring oil temps and has seen no change since the headers went in.
If you wouldn't mind sharing, what are your mods, usage, and normal oil temps? Headers uncoated and unwrapped?
It could certainly be something else. But I'm really leaning towards the headers as the temp change happened immediately after they went in... that and that no one else seems to have any idea what else could be causing it.
brapp is offline
Similar Threads
GR Sedan: Without the “Ambassador” mask on Dspin_1080 GR-Members' Journals 3272 10-29-16 06:44 PM
Lets Talk Motor Oil It Is So Very Misunderstood Dspin_1080 2.5 Liter/Litre Factory Motor 44 01-12-12 05:14 AM
Free APS Manifold Offer for Limited Time. Big APS Shipment with New Lower Pricing! RallySportDirect GD-Vendor Classified Ads 31 05-12-09 12:37 PM
High Oil temps topend 2.5 Liter/Litre Factory Motor 12 06-30-07 05:49 PM
